Lithium Battery Upgrade ?
29 replies to this topic
#1 TonyDevil
Posted 28 June 2020 - 01:43 pm
hey folks, has anyone tried a lithium battery instead of the gel type in a 9er?
https://smile.amazon...k/dp/B073CW43YS
I havent ridden in years but still have 3 TDMs and i'm out of work at mo so thought i'd get 1 or 2 of them back on the road while I have the time.
#2 dablik
  • 10,878 posts
Posted 28 June 2020 - 02:14 pm
Lee Henty is ya man Tony, he has fitted one.. welcome back stranger :good:
#3 chrisr
  • 1,778 posts
Posted 28 June 2020 - 02:35 pm
Amazing, I was just looking at these this morning and wondering........
#4 TonyDevil
Posted 28 June 2020 - 02:37 pm
i ordered a yusa for the moment, as i'm intending to sell the 2nd 9er at some point.
but if people have good things to say about the lithium i'll get one for the old 9er
tanks mate
#5 leehenty
  • 5,265 posts
Posted 28 June 2020 - 03:29 pm
I fitted a lithium battery very good starting torque. But you can't use a normal optimate on it.
I went for the Shido LT12B-BS 60Wh. Which is effectively 5 ah at 12 volts.
The advantage is you can use 95% of that instead of the 40% of lead acid.
Also it's the same physical size as the old one. No sticky spacers or anything.
They are Lithium Iron Phosphate so they don't blow up or catch fire.
They also put back the charge you used to start the bike in the first six mins of running.
Edited by leehenty, 28 June 2020 - 03:45 pm.
#6 TonyDevil
Posted 28 June 2020 - 03:44 pm
.....But you can't use a normal optimate on it.
didnt know that! thanks for info
went for the same battery as you that also came with the shido charger.
#7 leehenty
  • 5,265 posts
Posted 28 June 2020 - 03:47 pm
Something to do with normal optimate using high volts pulse to stop sulphation. LiPO4 don't like it.
#8 fixitsan
  • 4,827 posts
Posted 29 June 2020 - 01:56 pm
The self discharge rate for lithium phosphate is much less than lead acid, meaning the need for maintenance charging is much reduced.
Lead acid self discharges at about 3% - 4% per week. Lithium phosphate at about 3% - 4%  per month.
I bought a used LiFePo4 (lithium iron phosphate) Shido for my KTM, it's been great. The overall capacity of the battery I would say is less than the equivalent lead acid, but it provides a good starting current, and recharges very quickly.  Good for £20, ithad been fitted to an unfinished project and never abused.
#9 TonyDevil
Posted 29 June 2020 - 03:39 pm
thanks mate
oh well so much for having time to sort out bikes, can you start new job wednesday morning.... back on the road i go :cool:
#10 AliG
  • 1,457 posts
Posted 29 June 2020 - 04:10 pm
thanks mate
Well done on the new job, Tony. Ali
#11 leehenty
  • 5,265 posts
Posted 29 June 2020 - 05:52 pm
Well done on new job, extra beer tokens for bike fixing
#12 dandywarhol
Posted 29 June 2020 - 09:58 pm
I use a JMT 12v 36Wh in my KTM 690 Duke and charge it with an Oxford Oximiser 3X. Works well and brings the weight below 150kg  :pimp:
#13 fixitsan
  • 4,827 posts
Posted 30 June 2020 - 05:57 pm
I thought the 690 was heavier than that. If they are that light I'm back interested in one again. After the 620 I've been running I don't want to carry more weight but a tad more power for the straights would be fun !
#14 dandywarhol
Posted 30 June 2020 - 06:33 pm
If you do, go for a post 2016 model with an additional balancer shaft on the camshaft https://www.bennetts...test-and-review
#15 fixitsan
  • 4,827 posts
Posted 30 June 2020 - 06:38 pm
After a 620 and huge vibes anything is an improvement. I was tempted to go for the silly bugger ktm 660, but that vibrates even worse. Bit of a jump in prices for the 690 but I saw a couple last year below £2700
#16 dandywarhol
Posted 01 July 2020 - 05:08 pm
You're welcome to have a try on mine
#17 fixitsan
  • 4,827 posts
Posted 01 July 2020 - 06:37 pm
That would be great thanks. Maybe later in the year. ?
#18 dandywarhol
Posted 01 July 2020 - 09:55 pm
PM me - taking it for a trackday on the 17th at Knockhill - hopefully still in one piece after it...................................  :pimp:
#19 fixitsan
  • 4,827 posts
Posted 02 July 2020 - 08:34 am
Would love to go but I'm working in Cornwall for three weeks starting on Monday. Keep it one piece !
#20 MickC
MickC
  • 427 posts
  • TDM model: 1995
Posted 02 July 2020 - 09:12 am
Use them in my  Husky good starting power,will turn over faster as they warm up,cant use pulsating current as Lee says but they do ok on an over charge so if needed I just use the 2amp level on the car charger for 5mins to give a boost if needed (sometimes the old 450 I used didnt want to start).They dont like the cold so if parked outside may cause issues but in a garage no.Far lighter than a normal battery,hold the charge well and I have two that are 5 years old and still working.
