Tps Adjustment
4 replies to this topic
#1 Pj180
Pj180
  • 6 posts
Posted 22 July 2020 - 10:50 pm
Hi All,
Just got an '96 850.
Previous owner said slow speed running wasn't that great along with weird noise from drive train when running.
That noise was down to a really worn front sprocket and chain so every so often it would catch rather than mesh.
I've changed both sprockets and chain so that should be good.
So on to the slow running - I had a bunch that the tps might not be correct, so ran the test according to the manual and its showing 1 on the rev counter so need to adjust to get it to 4.
BUT how do you get at the fastners with the engine in the frame?? I thought I might be able to take the carbs off and then adjust but that looks just as bad as gettimg to the TPS itself !!
So thought I'd ask the people that know 😁👍
#2 wicklamulla
  • 11,987 posts
Posted 23 July 2020 - 07:04 am
Hi All,
 fiddly pig of a job and i bet you struggle to attain 4k,  more like 4300rpm may be the final outcome.  good luck with it.
#3 Studley Ramrod
  • 18,433 posts
Posted 23 July 2020 - 08:45 am
Have you tried using a torx bit, sure someone on here used one in the past.
#4 drewpy
  • 1,341 posts
Posted 23 July 2020 - 12:34 pm
you need to take the carbs off, had to do it twice and yes, its a pain.
Once done though should be sorted for  a while as they don't usually go out
adjust it with the carbs off and tighten down
Edited by drewpy, 23 July 2020 - 12:34 pm.
Mods; Oil pressure switch, neoprene rear inner mudguard, scottoiler, highway pegs,  fenda extenda, silicone airbox connectors, 15w fork oil, later clutch springs, LED lamps, Metmachex swingarm, Hagon Shock, Oxford heated grips, USB, 4 way fused accessory Bus, R6 electric fuel pump (5EB, kept seizing), 17" 3CV front wheel, Michellin R5 tyres, EXUP speedo.
#5 Pj180
Pj180
  • 6 posts
Posted 23 July 2020 - 02:27 pm
Cheers - It'll have to wait until afterweekend festivities that have been planned
