850 Electric Gremlins
3 replies to this topic
#1 Kezzr
Kezzr
  • 1 posts
Posted 24 July 2020 - 11:26 am
Just about to set off for a good long ride, Ignition on, Fuel pump working fired twice and stopped. When I now turn on the ignition and press start both low petrol and low coolant lights come on? Lights, flashers and horn all working starter motor will turn the engine when I connect terminals on the solenoid. Have checked all connections and fuses appear to be all ok. Maybe dodgy ignition switch? Anyone else had this happen or what do I look at next? Thanks in anticipation. Keren
#2 divvxj
divvxj
  • 1,296 posts
Posted 24 July 2020 - 05:04 pm
I had this happen on my niner, ignition key problem , wiggle the key and away she went ,problem was to much crap on my key ring (weight) i did have a problem of not starting but that was the fuel pump wire corroding and snapped , took the mechanic ages to sus, hope this helps but someone with more knowledge than i will be along anytime :good:
#3 dablik
Posted 24 July 2020 - 06:28 pm
Check the ignition live in the switch, been known to become unsoldered on a few occasions ! and give all the fuse box wires a good tug..
#4 wicklamulla
Posted 27 July 2020 - 12:37 pm
is the starter relay going click click when you press the starter button? I'd remove it off of the bike and disassemble, inspect and clean it as it's easy enough to do.
