Battery Removal
16 replies to this topic
#1 DaveW
DaveW
  • 59 posts
Posted 28 July 2020 - 12:55 pm
My 4TX has braided hoses fitted by a previous owner. The larger than standard joint onto the rear caliper means that there is not enough room to extract the battery in the way described in manual. (Not the best design feature of the bike in any case.)
Does anybody know from experience whether I could get enough clearance by deflating tyre rather than having to take the wheel right out?
Thanks once again.
#2 Andy25
Andy25
  • 344 posts
Posted 28 July 2020 - 06:21 pm
Removing the battery is like a Krypton Factor challenge on the 4tx at the Best of Times
It will come out quite easily after you've scraped all the skin from your knuckles etc
then pop back in without any problems
All about getting the right angle
Not really helping am I
#3 ortogo
ortogo
  • 19 posts
Posted 28 July 2020 - 07:15 pm
Its a little while since I had to change the battery on my 4tx but it was a right pain in butt. I took the rear wheel out which made things much easier and I would have taken the rear shock out if the lower mounting bolt wasn,t seized solid, (but that's another can of worms). I eventually managed to wriggle the battery out but I,m not sure you would get it out without removing the back wheel. The strange things is that the new battery went in very easily. If I had to do the job again I would take out the back wheel and having since sorted the the shock mounting bolts I would remove the rear shock as well
#4 Gdogg
Gdogg
  • 1,204 posts
Thanks once again.
Hi DaveW,
just sent you a PM chap
#5 sayhello
sayhello
  • 54 posts
Posted 25 January 2025 - 11:43 pm
dear friends
well i have to change the battery on a TDM 900 - model 2010
a friend told me:
Unscrew the screws from the connections - and screw in long screws (or a piece of threaded rod) that you can grab. Of course they aren't allowed to touch each other. And before installing, stick a neat fabric tape underneath, the front end of which is sticking out, so that you can pull it next time...
well  I'll definitely try that too - I'll take a small one. Threaded rod and then put it on - as suggested: Should it be an M6 threaded rod - or!?
well i hope that i can go round a long procedure
look forward to hear  from you
#6 steve27bha
  • 797 posts
Posted 26 January 2025 - 12:30 am
I used a pair of nylon zip-ties with screw eyes in the "head" for my 900. Holes were the right 6mm size and long enough to get a good grip.
I was about to bolt on a strip of metal, then I engaged brain and woke up!
Pic shows my long-ago addition of duct tape that ripped as soon as I pulled on it. Perhaps helicopter tape would work.
Attached File  DSC03451.JPG   126.39KB   0 downloads
Edited by steve27bha, 26 January 2025 - 12:36 am.
#7 sayhello
sayhello
  • 54 posts
Posted 26 January 2025 - 06:41 pm
hi there - many thanks dear Steve.
this looks really awessome!  i will do it like you.
thanks for the data - i will take 6 mm "screws"
thank you so much -
btw: this forum is absolutly great
greetings
#8 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 26 January 2025 - 08:56 pm
I remove the hugger and and rear brake caliper, perching the caliper out of the way. Then twiddle around in the mysterious depths for 30 minutes or so... It really helps if the bike is close to vertical, not leaning drunkenly on the side stand.
If it's any consolation. The battery on my Gasgas is in the bottom of the air box, so rear wheel has to come out and the air box stripped down. Even then removing the battery and replacing it is done by touch. The battery is the size of a packet of fags and shrugs off this mortal coil if left uncharged for a month. Proper pita.
Edited by harvey krumpet, 26 January 2025 - 09:00 pm.
#9 fixitsan
  • 4,855 posts
Posted 27 January 2025 - 11:06 am
Is it likely that one of the first mods for Gas Gas owners is to fit an external charging  lead ? ;)  Does the bike come with one already ?
#10 chrisr
Posted 28 January 2025 - 07:51 am
I just thread the cable ties through the holes in the terminals and yank - seems to work.
#11 sayhello
sayhello
  • 54 posts
Posted 28 January 2025 - 03:55 pm
dear Harvey
first of all - ,many thanks for the reply
well - your posting makes me a bit frightened - its a TDM 850  i guess.
plz do me a favour - tell us - that this is not necesary for the tdm 900--
Edited by sayhello, 28 January 2025 - 03:58 pm.
#12 leehenty
  • 5,325 posts
Posted 29 January 2025 - 09:14 am
No 900s ate much easier
#13 Snowbird
  • 1,484 posts
Posted 29 January 2025 - 10:23 am
On the 900 you simply remove a bar end weight and pick the battery out with a teaspoon and a toothpick, they need to be very long and flexible as the battery is mounted inside the oil filter.......
(I may be lying) :huh:
#14 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 30 January 2025 - 09:10 pm
Exacary what I have done. Fed a couple of wires from the terminals and tucked them away behind the side panel.
#15 sayhello
sayhello
  • 54 posts
Posted 01 February 2025 - 09:40 pm
thank you so much - i am so happy to be part of this forum
greetings
#16 sayhello
sayhello
  • 54 posts
Posted 08 February 2025 - 04:06 pm
Hello dear friends, :)
- it took about 30 minutes and now it's inside
However: on the MINUS terminal, 3 "locking" nuts - i.e. the ones under the pole cap - fell through.
That was really a bit inconvenient - because the BATTERY was (or was) already inside at this point.
They are, so to speak, at the bottom of the "side cover" -
The question is: can they ever fall through to the CHAIN ​​- that wouldn't be so practical.
I'm looking forward to hearing from you.
Best regards :rolleyes:
#17 Dannyboy
Dannyboy
  • 628 posts
Posted 20 June 2025 - 11:49 am
After watching the video 📹 I think I'll just sell the bike if the battery 🔋 goes dead 🤔 What a palaver!!
