3Vd Front Sprocket
Posted 04 April 2023 - 02:33 am
Posted 04 April 2023 - 04:57 am
AFAM has internal spline profile the same as OEM.
JT has internal spline profile of a 5 year olds drawing.
Sorry don't know AFAM codes.
Posted 04 April 2023 - 07:07 am
Hello all, wondering what people are using for a front sprocket. I have already ordered a poor fitting jt that will not be installed. Just trying to prevent ordering junk again. I have found an afam sprocket with the part number 28401-16. Does this ring a bell for anyone?
When you say it was poor fitting, do you mean it flopped about on the output shaft ?
On the later 850 there were two types of sprocket, a wide and a narrow, I made the mistake of ordering the wrong one and thought all JT sprockets were rubbish after that. Depends where you buy from too, some list different dates for the wide and the narrow, I never found a definitive list, only that there are 2 types for 850's
Posted 04 April 2023 - 09:56 pm
It was both too thick for the lock washer to fit, and loose fitting on the shaft. I will proceed with the afam branded one that I found. Hopefully it's the correct spline pattern
Edited by IrkinBollikans, 04 April 2023 - 09:56 pm.
Posted 05 April 2023 - 08:04 am
You may have to use a very small splodge of loctite 638, it is 638 innit daps ?
1991 MK1 in need of some TLC watch this space Gone to Heaven Sorted and on the Road Mick
it's the bike that Jack built
Posted 05 April 2023 - 07:29 pm
I have searched through old threads and found the same advice. I will order some before finishing this "simple chain swap" haha. Should this be used on the threads of the shaft as well, or is loctite 243 the better choice?
Posted 05 April 2023 - 08:35 pm
Loctite Hawaii 520....ya gorrit dabbers. You dont need to sploodge this stuff. There was helluva debate aboot where to stick it at the time but small amount threads small amount inter should do it. Gentle heat will help when removal requiredYou may have to use a very small splodge of loctite 638, it is 638 innit daps ?
Lots of info ear http://www.carpe-tdm...e=8#entry279080
Posted 06 April 2023 - 03:38 pm
Posted 06 April 2023 - 07:38 pm
Good to know chaps, me grey cells are working, at least on this occasion
