Another Stripped Thread On The Oil Filter Cover
21 replies to this topic
#1 Johnners
Johnners
  • 120 posts
Posted 09 April 2023 - 03:48 pm
Hi folks,
Has anyone inserted a helicoil for the long bolt on the outside of the filter cover? If so, did you need to remove the oil strainer cover (sump)? The reason I ask is that this bolt goes through the strainer and into the crank case by the looks of it. Just hoping I can get away without removing the strainer cover to insert a helicoil. Problem is knowing how far to drill, tap and wind in the coil.
Thanks for any advice,
J.
#2 leehenty
  • 5,306 posts
Posted 09 April 2023 - 04:53 pm
Is this the M10x1.25 long tank drain bolt ? Or the M6 one.
#3 dablik
  • 10,885 posts
Posted 09 April 2023 - 06:28 pm
Think he means the M6 ?
#4 Johnners
Johnners
  • 120 posts
Posted 09 April 2023 - 07:59 pm
It's the m6 bolt
#5 Catteeclan
  • 2,550 posts
Posted 10 April 2023 - 07:50 am
Worth trying a stud first? 6mm studding inserted with some loctite to catch the good threads behind the damaged. Can saw off the remaining studding once the lactate has set all back together.
#6 leehenty
  • 5,306 posts
Posted 10 April 2023 - 08:53 am
Take off cover poke a bit of wire in hole to get depth, take off 2mm, set your drill stop to that depth or use a piece of tube over drill to make a stop. Off you go. Helicoil size is 6.3mm
#7 trevini
trevini
  • 1,882 posts
Posted 10 April 2023 - 09:59 am
Brilliant typo mate  :rotflmmfao:
#8 drewpy
Posted 10 April 2023 - 10:09 am
he's milking the thread for all he's got  :lol:
#9 dapleb
  • 18,362 posts
Posted 10 April 2023 - 10:40 am
Skimmed?
#10 Johnners
Johnners
  • 120 posts
Posted 10 April 2023 - 12:44 pm
Thanks for replies, any gotchyas with removing the strainer cover? From the parts diagram, looks like there are a few components in there that may prove difficult to get back in place. Presumably it needs a new gasket on re-assembly?
Cheers,
J.
#11 Studley Ramrod
Posted 10 April 2023 - 05:01 pm
:lol:
Skimmed?
:lol:
#12 dablik
  • 10,885 posts
Posted 10 April 2023 - 06:31 pm
Cheers,
J.
Strainer is inside  the sump cover, dont  need to go in.
#13 Catteeclan
  • 2,550 posts
Posted 11 April 2023 - 11:51 am
Piss taking buggers :lol:
#14 dablik
  • 10,885 posts
Posted 12 April 2023 - 08:28 am
Arses aint they Dave, i would never take the piss out of you fella  :angel:
#15 Johnners
Johnners
  • 120 posts
Posted 12 April 2023 - 02:45 pm
Soo, exhaust is nearly off. Managed to get all the header bolts off, but pipes corroded into exhaust ports and can't make the buggers move. Does anyone know where the o2 sensor connector is located?
Thanks 😊
#16 Johnners
Johnners
  • 120 posts
Posted 12 April 2023 - 04:36 pm
Nevermind the sensor plug. Anyone have any ideas on getting the headers out of the exhaust ports. All the studs are out as well as the bolt into the frame underneath, but the headers will not move. I've never experienced this before. Normally the studs are the difficult bit.
#17 fixitsan
  • 4,839 posts
Posted 13 April 2023 - 07:59 am
Dribble some brake fluid around them (it's a great creeping penetrating fluid), let them soak a few hours, then use a computer keyboard 'air duster' inverted - the liquid which comes out goes down to temperatures as low as -50C I believe.
And then after the clever stuff, if it doesn't work, go back to using brute force and ignorance
#18 Johnners
Johnners
  • 120 posts
Posted 13 April 2023 - 08:03 am
Thanks Fixitsan, I'll give that a try.
#19 Johnners
Johnners
  • 120 posts
Posted 14 April 2023 - 07:37 pm
Finally the headers ard off, thankfully without damaging the ports. I can get on with the original job of thread repair now (assuming I can get the oil strainer cover off). Thanks for the help and suggestions folks.
#20 Johnners
Johnners
  • 120 posts
Posted 17 April 2023 - 02:31 pm
It worked! Enjun is oil tight again. Thanks for the advice, made things much easier. 😀
