Headlight Improvement
Posted 08 May 2023 - 09:14 am
My previous bike (Fazer 600) was well known for having poor lighting with only 1 of the 2 lights lit up with the main beam on. There is a well documented fix for this to have both lights on for main and still have the full beam available.
I've searched around but not found anything similar for a TDM 900 - is this fix possible?
Posted 08 May 2023 - 12:16 pm
Greece tdm'ers have loads of modified headlights. See if I can find a photo
Cats
Posted 08 May 2023 - 12:38 pm
The common approach is to fit an HID bulb (the H7R has a shield to reduce the risk of dazzling people) or whatever the LED equivalent is. Also a lot of people fit additional spots. I have mine mounted on brakcets on the engine mounts and a switch on the dash via a relay to let me have them on with main beam or with dipped beam only.
The Greek approach looks better but a lot more work.
Posted 10 May 2023 - 07:33 am
The Blue One : 2004 model owned 2010-2018 much loved, much missed and now living with a man in Scotland Spain.
Posted 10 May 2023 - 07:46 am
LED - cheap effective & legal, a direct swap if you ensure the correct focal length.
Posted 10 May 2023 - 12:47 pm
I fitted one to my dip, and the result was absolutely crap - light everywhere. AFAIK I fitted it correctly.
If you have a proven fitting and item to use I'd appreciate the details to try again.
I had an HID fitted until they were declared non-MOT-able. Shame because it worked perfectly.
Posted 10 May 2023 - 02:10 pm
HID is OK for MOT .. new rules are for beam pattern/scatter not light source and about time too.
Posted 10 May 2023 - 06:44 pm
Steve dont know what Favs is referencing but have a look at this site to see if it helps, better options than China i think ? they have them made to order possibly.
1991 MK1 in need of some TLC watch this space Gone to Heaven Sorted and on the Road Mick
it's the bike that Jack built
Posted 10 May 2023 - 09:06 pm
I use some like these with the mounting ring moved to the correct focal position (ooo errr not 9er speak ) Need to male a spacer to allow the spring clip to grip the lamp properly. They pass the MOT on the beam pattern machine.
Linkydinky
https://www.ebay.co....:Bk9SR5DSnPeAYg
Posted 10 May 2023 - 09:25 pm
Favs, dablik,
I thank you for the info. I'll ponder and research.
And dig out the HID bulb and spacer. I left the starter units on the bike so it should (ha!) be a simple refit - plus adjust the beam height IIRC. Got the marks on the wall for that.
My LEDs looked like Fav's and I got a spacer recommended by someone. I got exasperated fitting the thing purely by feel and then there was light all over the place. Ran out of patience so I wish you all the best!
PS The revised MOT rules for upgrading with HID or LED are summarised in this article:- https://www.classicb...-lights-the-law
Edited by steve27bha, 10 May 2023 - 09:44 pm.
Posted 11 May 2023 - 06:06 pm
Pic shows the same thing done to my Fazer.
Posted 12 May 2023 - 06:59 am
