3Dv Parts For Sale
No replies to this topic
#1 madmopedracer
madmopedracer
  • 473 posts
Posted 25 July 2023 - 04:06 pm
Having sold my 92/93 TDM850 3VD recently I'm selling spares gathered over the years
Postage extra
Too many to post pictures but if interested I can send some
  1. Starship enterprise exhaust it's had some welding done £100
  1. Nexxus exhaust small dent in one of the tubes got it but never fitted  SOLD
  1. Front forks no pitting on the seal surface could probably use new seals £150
  1. Swinging arm SOLD
  1. Silver spot callipers xjr1300 master cylinder and venhill stainless lines £100
  1. Speedo instrument cluster £40
  1. Oil filter new 3 off £10
  1. Sprocket plastic cover £5
  1. Plug leads with amalgamated tape £5
  1. Unobtanium rubber spark plug seals £5
  1. 2 Fuel pumps I'm fairly certain both work but not 100% £15 each
  1. Fuel tap from 4TX I think £10
  1. Fuel tap 3vd £20
  1. Fuel tap 3vd needs the brass bits araldited £15
  1. Genuine Clutch cable £10
  1. Tick over adjuster cable £5
  1. Bar end weights £10
  1. Brake line bracket mounts on forks at mudguard £15
  1. Petrol cap with 1 key £10
  1. Inlet rubbers free cost postage
  1. New fuel tank outlet seal £1
  1. 2 x Fuel Pipe Clip Genuine 90467-090A2 £3
  1. Emulsion tubes 22k on them only change because I was given some factory pro ones £5
  1. Yamaha OEM 3aj-24534-01-00 Seal Cock new £5
  1. TRK breaking kits bsk o78 o30 for bluespots £10
  1. Bikers toolbox set seals for 2 x bluespots  £5
  1. Selection of seals for carbs new £5
  1. Headlights £20
  1. Stand like an abba but mounts further up £30
  1. Front wheel £35
  1. Rear wheel £40
  1. rear wheel sprocket and carrier only done 9200 miles £25
  2.
IMG-20230725-142727117.jpg IMG-20230725-142722273.jpg IMG-20230725-142716023.jpg IMG-20230725-142706839.jpg IMG-20230725-142544443.jpg IMG-20230725-142536941.jpg IMG-20230725-142516914.jpg IMG-20230725-142458672.jpg IMG-20230725-141213742.jpg IMG-20230725-141201312.jpg IMG-20230725-141128930.jpg IMG-20230725-141135384.jpg IMG-20230725-141120459.jpg IMG-20230725-141124404.jpg IMG-20230725-141102823.jpg IMG-20230725-141107946.jpg IMG-20230725-140610223.jpg IMG-20230725-140418018.jpg IMG-20230725-140412409.jpg IMG-20230725-135238677.jpg IMG-20230725-135141058.jpg IMG-20230725-134927714.jpg IMG-20230725-134901785.jpg IMG-20230725-134840227.jpg IMG-20230725-134833078.jpg IMG-20230725-134821898.jpg IMG-20230725-134816401.jpg IMG-20230725-134756920.jpg IMG-20230725-134803223.jpg IMG-20230725-134740680.jpg IMG-20230725-134736222.jpg IMG-20230725-134719629.jpg https://i.ibb.co/xjQ...5-134715065.jpg https://i.ibb.co/tZR...5-134709439.jpg https://i.ibb.co/gv7...5-134703771.jpg https://i.ibb.co/R3D...5-134649287.jpg https://i.ibb.co/3sz...5-134658021.jpg https://i.ibb.co/jGY...5-134631240.jpg https://i.ibb.co/mBj...5-134643749.jpg https://i.ibb.co/y5H...5-134625327.jpg https://i.ibb.co/F0h...5-134616335.jpg https://i.ibb.co/cXS...5-134559775.jpg https://i.ibb.co/BVG...5-134609989.jpg https://i.ibb.co/1G4...5-134557590.jpg https://i.ibb.co/rx7...5-133859191.jpg https://i.ibb.co/2k7...5-133851123.jpg https://i.ibb.co/Zhf...5-133846456.jpg https://i.ibb.co/kDN...5-133839136.jpg https://i.ibb.co/kBG...5-132303897.jpg https://i.ibb.co/Jnm...5-133827243.jpg https://i.ibb.co/Y45...5-132250935.jpg https://i.ibb.co/7VR...5-132239817.jpg https://i.ibb.co/Kzw...5-132226218.jpg https://i.ibb.co/Xtd...5-132138373.jpg https://i.ibb.co/syz...5-132134618.jpg https://i.ibb.co/mtV...5-132127794.jpg
Edited by madmopedracer, 27 July 2023 - 06:25 pm.
