Tdm 900 Advice?
22 replies to this topic
#1 doc44
doc44
  • 3 posts
Posted 22 December 2024 - 08:56 am
Hey chaps, nice to meet you all and hope you are ready for Christmas! Im interested in buying a tdm900 and wondered if there are any major differences over the years apart from colours? The later models with the black frame are better looking in my opinion. Thanks.
#2 leehenty
  • 5,306 posts
Posted 22 December 2024 - 10:26 am
At the risk of getting flamed. The 900 is the best for modern fuels, EFI no carbs, do not burn oil. Blue Spot brakes.
The 850 Mk 1 have lots of character as do the 270° crank MK2a.
On the 900 always check the lower frame bush is free as soon as you get it. After 2004 they had a more secure rfid ecu so having the red key with the bike is essential.
Others will chime in Im sure.
Edited by leehenty, 22 December 2024 - 02:58 pm.
#3 fixitsan
  • 4,839 posts
Posted 22 December 2024 - 10:43 am
There was a change at some point in the lower fork clamp design, which was flat in the early models and then became cranked in order to hold the forks lower down the stanchions, which gives a bit better control at the front. And it is only a little bit of improvement. I changed mine from flat to cranked and only noticed a small difference, it probably wouldn't make a difference to me when buying one, which type it had.
The fact that there are few differences over the whole production run probably speaks a lot about how well it was made in the first place.
#4 leehenty
  • 5,306 posts
Posted 22 December 2024 - 11:06 am
Brake master cylinders changed from 14mm to a bigger size at some point
#5 Rallyist
Posted 22 December 2024 - 11:30 am
Lee I think it was from 2004 on following the introduction of ABS models
#6 leehenty
  • 5,306 posts
Posted 22 December 2024 - 03:01 pm
A well sorted 900 will see you ok for years, its strange lots of others are now making parallel twins now, the TDM was years ahead of its time and is known to be reliable.
#7 JerryS
JerryS
  • 143 posts
Posted 22 December 2024 - 05:54 pm
Yellow 9ers are the best  :lol:
Fuel Cans, Baglux tank cover, Givi E21 panniers, Givi Flow top box, Yamaha centre stand, Garmin Zumo SatNav,, Givi engine bars, Barkbuster S1 handguards, Powerbronze Fender Extender and Headlight guards.
#8 leehenty
  • 5,306 posts
Posted 22 December 2024 - 06:09 pm
I thought red ones are fastest
#9 trevini
trevini
  • 1,882 posts
Posted 22 December 2024 - 06:25 pm
Definitely Blue 😂
#10 dapleb
  • 18,362 posts
Posted 22 December 2024 - 06:26 pm
Hello dare and welcome doc.
Can't help ya with 9er differences... whatever the differences they ain't not a patch on da mk1. It takes peeps a long time to learn this...but the 9er is a good enough place to start the learnin. (⁠⁠‿⁠⁠)
#11 leehenty
  • 5,306 posts
Posted 22 December 2024 - 07:08 pm
Yer a brave man dappers
#12 LAURENCEAUX
LAURENCEAUX
  • 233 posts
Posted 22 December 2024 - 07:37 pm
There have been many changes over the years, on the various models, but being a biased person, I'd nominate the TDM 900A for safety, availability of bits (not that you'll need them very often if you buy wisely), for looks (personal preference), comfort, easy to maintain and relatively cheap to insure. On a 900 you can easily do 250 miles a day, with reasonable consumption as they are supreme "mini" tourers. I bought mine 3rd-hand in 2016 and have enjoyed faultless motoring across the UK and Europe since. Good luck with your new choice.
Edited by LAURENCEAUX, 23 December 2024 - 09:35 am.
#13 doc44
doc44
  • 3 posts
Posted 23 December 2024 - 11:11 am
Thanks for all of the replies. I think a post 2004 bike might be the way to go, need to offload a Triumph first then Ill start looking seriously. Cheers!
#14 Muppdog
Muppdog
  • 305 posts
Posted 24 December 2024 - 09:18 am
On that red key, never had one and had a copy made from the black key by a locksmith. No problem anymore these days.
Merry Xmas
#15 leehenty
  • 5,306 posts
Posted 24 December 2024 - 05:40 pm
Isnt the red key to program new keys to the bike ?
#16 LAURENCEAUX
LAURENCEAUX
  • 233 posts
Posted 25 December 2024 - 03:56 am
Yup - always keep the red key for emergencies and to create new secure keys.
#17 laughin in a windstorm
  • 842 posts
Posted 25 December 2024 - 04:18 am
my 2002 model doesn't have the red key for the ignition, just 2 black keys nice and simple, I had an MT03 that had a red key ignition and the ignition barrel was faulty,
to replace a 'red key' ignition barrel costs hundreds of pounds because of the computings or whatever is built into it, the older 2 black key ignition barrel can be replaced for about fifteen quid,
luckily with perseverance and singing some soft songs to my not so good MT03 ignition barrel it eventually surrendered and I was able put the sword away again
#18 leehenty
  • 5,306 posts
Posted 25 December 2024 - 09:50 am
Mines a 2002 simple as it gets
#19 trevini
trevini
  • 1,882 posts
Posted 25 December 2024 - 10:37 am
Lee, you do know the red key secretly unlocks another 50bhp if you with the ign on and off in the right sequence. That's why the blue ones are faster  :rotflmmfao:
Edited by trevini, 25 December 2024 - 10:38 am.
#20 leehenty
  • 5,306 posts
Posted 25 December 2024 - 01:29 pm
130 odd horses out of a 900 twin is a bit of a stretch
Edited by leehenty, 25 December 2024 - 01:29 pm.
