Drive chain and sprocket specifications by year.
15 replies to this topic
#1 dapleb
  • 18,378 posts
Posted 03 June 2007 - 08:46 am
POSTED BY: danceswithmopeds. Taken from this thread: http://www.carpe-tdm...o...0&hl=noggin
QUOTE(danceswithmopeds @ Wed 18th Apr 2007, 11:18 AM) <{POST_SNAPBACK}>
year front sprocket rear sprocket chain links
teeth teeth
92-96 16 44 114
96-98 17 42 114
99-01 16 43 114
02-05 16 42 118
chain pitch of all is 525
sorry about that, spacing between columns did not appear in posting
#2 Sparra
Sparra
  • 490 posts
Posted 03 June 2007 - 11:51 pm
Excellent timing dapleb, I was going to look for these details sometime this week. banana.gif
#3 Tyler
Tyler
  • 86 posts
Posted 15 October 2007 - 10:02 pm
Do you know if mk2 sprockets fit a mk 1? i want the gearing on my mk 1. Thanks guys.
#4 wicklamulla
Posted 15 October 2007 - 11:42 pm
QUOTE(Tyler @ Mon 15th Oct 2007, 10:47 PM) <{POST_SNAPBACK}>
thought ya were selling it ?? as far as i know the MKI and MKIIa (TDM 850 from 1999-2001) sprockets are the same sizes but i aint 100% shua.
#5 TonyDevil
Posted 16 October 2007 - 09:18 am
they are the same, mk2 96-99 has a diff front sprocket but i think the rest is the same
#6 sidestand
Posted 16 October 2007 - 09:43 am
Edited by sidestand, 16 October 2007 - 09:44 am.
#7 TonyDevil
Posted 16 October 2007 - 10:14 am
QUOTE(sidestand @ Tue 16th Oct 2007, 10:28 AM) <{POST_SNAPBACK}>
#8 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 04 November 2007 - 03:18 pm
all you want to know about sprockets, codes etc on here
you can search by bike
or you can search by sprocket code to see what other bikes it is fitted to
you can also see what other sizes are available and what bikes they were fitted to
Top site
#9 dapleb
  • 18,378 posts
Posted 04 November 2007 - 03:37 pm
No width info on the mkI front sprocket. But a diff part number to the mkII!
#10 robgosty
robgosty
  • 187 posts
Posted 04 November 2007 - 05:47 pm
TDM 900 was hoping maybe a 44 rear but----------
Front sprocket available in: 16 teeth
Rear sprocket available in: 39, 42, 43, 47, 48, 49 teeth
OOPS
Yamaha XV 1000
Kawasaki GPZ 750
Honda CBR 1000F
Yamaha XV1100 Virago
Yamaha Yellow TDM 900
Suzuki Hayabusa
Current
2000 Yamaha XJR 1300
#11 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 04 November 2007 - 07:23 pm
QUOTE(dapleb @ Sun 4th Nov 2007, 03:22 PM) <{POST_SNAPBACK}>
As its flat (ie no boss around the the splined hole) it'll be 7.2 as its a 525 chain
It tells you this on the MkII front sprocket for the thickness of the outer section
#12 Guest_Catteeclan_*
Guest_Catteeclan_*
Posted 14 December 2007 - 04:11 pm
I've changed my rear sprocket for a 39 tooth. Gives me a liitle lower revs at 70. But the main reason was to get the speedo a little more accurate. I could sit at 70 and tomtom would say my speed was 65mph. Almost spot on now.
#13 GregakaDM54
GregakaDM54
  • 52 posts
Posted 10 February 2009 - 05:35 am
Righto!! Spell it out like I'm a 6 year old, I'm after a RK chain (XSO). If my model (2007) requires a 118 link chain, do I buy the 120 link chain and get 2 links taken out?? blink.gif or, if they say 114 and 120, is the sizes they make between these sizes??? Tttttthhhhhaaaaaannnnkkkkssssss
Edited by GregakaDM54, 10 February 2009 - 05:46 am.
#14 AussieTeeDeeMmm
AussieTeeDeeMmm
  • 56 posts
Posted 10 February 2009 - 11:39 am
QUOTE(GregakaDM54 @ Tue 10th Feb 2009, 03:35 PM) <{POST_SNAPBACK}>
Hi Greg,
For Me personally i would buy a chain with a joining link and just take the 2 links out if that is what is required, Just make sure the open ends of the side clip face backwards from the direction of rotation of the chain, This prevents them being flicked off by an object hitting them. This is what i did when i replaced the chain on my DR650 prior to my Cape York trip last August.
Edited by AussieTeeDeeMmm, 10 February 2009 - 11:39 am.
#15 tdm850rider
Posted 10 February 2009 - 11:45 am
QUOTE(GregakaDM54 @ Tue 10th Feb 2009, 12:35 AM) <{POST_SNAPBACK}>
You take 3 links out... don't forget the connecting link. 117+1=118
#16 dallasRUS
dallasRUS
  • 52 posts
Posted 15 June 2009 - 03:12 am
QUOTE(TonyDevil @ Tue 16th Oct 2007, 04:18 PM) <{POST_SNAPBACK}>
QUOTE(GuyGraham @ Mon 5th Nov 2007, 02:23 AM) <{POST_SNAPBACK}>
Guys what do you think any bad if I replace 'thick' (at center mount point) 10.8mm
( http://www.jtsprocke...all/jtf1586.jpg )
sprocket from Mk2 '98 to flat one 7.2mm ? Just I've already purchased spare Renthal 15T
but never thought it can be different before checked mine, as Renthal specified to fit 96-06 years.
As result there are will be (10.8-7.2)/2 = 1.8mm shift to center, seems not a big deal?
I do not know if this affordable misalignment value, or maybe it will be more reliable
to put 1.8mm washer? When properly tightened I guess nothing happens and this
variant with washer looks better to me. Thanks
Edited by dallasRUS, 15 June 2009 - 03:49 am.
