Valve clearances
19 replies to this topic
#1 oiler
oiler
  • 205 posts
Posted 14 May 2006 - 02:53 pm
Can anyone help? Checking clearances on my 92, found i had to change shims, so removed cams. On reassembly i have released tensioner, aligned static time marks, faced lobes away from each other on no. 1 but find it impossible to align timing mark letters on cam sprockets with cylinder head. Marks on inlet sprocket are approx. half a tooth out, no matter what i do. Is this normal? Could it be due to worn cam chain, tho i did,nt think it was- no rattles, 35k. Dare i rebuild it like this? Would appreciate any advice.
Message came back from the great beyond..........57 channels an nothin on..........
#2 dapleb
  • 18,321 posts
Posted 14 May 2006 - 03:17 pm
One of my favourite ever threads.... http://www.carpe-tdm...light=cam chain
The markings at the top are just not THAT accurate......as long as you have the static marks spot on and are using the correct "E" and "I" markings all should be fine!
It is best to mark across the spockets and chain so that you are confident everything is going back in the same place.
I guess you have done yer shims now? If not I have a free shim exchange program.....lemme know what shim sizes you need and I'll swapsie with the sizes you need...if I have em.
G'luck.
#3 dapleb
  • 18,321 posts
Posted 14 May 2006 - 03:36 pm
Static timing marker:
Attached File  Timing1.JPG   61.51KB   198 downloads
Even a rough splattering of tipex helps to make sure all is in order on reassembly:
Attached File  Timing2.JPG   147.37KB   243 downloads
Notice inlet marker doesnt line up as well as exhaust (but they are as they were on dismantle):
Attached File  Timing3.JPG   74.42KB   249 downloads
Boop
#4 Dazzo
Dazzo
  • 206 posts
Posted 14 May 2006 - 04:13 pm
QUOTE(dapleb @ Sun 14th May 2006, 04:02 PM) <{POST_SNAPBACK}>
G'luck.
#5 ChrisG
  • 8,281 posts
Posted 14 May 2006 - 05:28 pm
I had exactly the same with mine, fortunatly before I took out the cam tensioner I was a bit paranoid and took some photos so was able to check that I put it back together the same as I took it apart. Mine definatly looks like it's about half a tooth out.
Edited by ChrisG, 14 May 2006 - 05:28 pm.
#6 aytcat
aytcat
  • 131 posts
Posted 14 May 2006 - 06:22 pm
QUOTE(Dazzo @ Sun 14th May 2006, 04:58 PM) <{POST_SNAPBACK}>
#7 oiler
oiler
  • 205 posts
Posted 14 May 2006 - 07:33 pm
Thanks Dapleb, will feel a bit happier putting it back together now, forgot all about splashing the tipex about. I think your marks are as bad as mine, far out man!
#8 ROB1
ROB1
  • 539 posts
Posted 15 May 2006 - 08:19 pm
QUOTE(oiler @ Sun 14th May 2006, 10:18 PM) <{POST_SNAPBACK}>
i think 2 get a perfect alignment you need adjustable sprockets & a vernier dial like they use in race engines.Yours will be fine the way youve done it
#9 oiler
oiler
  • 205 posts
Posted 15 May 2006 - 08:42 pm
QUOTE(ROB1 @ Mon 15th May 2006, 03:04 PM) <{POST_SNAPBACK}>
Must have a detrimental effect on the performance, shirley.
#10 SteveGlover
SteveGlover
  • 857 posts
Posted 16 May 2006 - 11:12 am
Do the same shims fit the 900? May be interested in about 12k miles time. It won't be long at the rate I'm clocking up miles!
#11 dapleb
  • 18,321 posts
Posted 16 May 2006 - 04:49 pm
Sorry I know nothing about 900's, would guess they are. Lemme know when ya have the lille burgers out and we can find out.
#12 dandywarhol
Posted 16 May 2006 - 06:26 pm
QUOTE(dapleb @ Tue 16th May 2006, 03:34 PM) <{POST_SNAPBACK}>
Yep.......same as the 850
#13 oiler
oiler
  • 205 posts
Posted 16 May 2006 - 07:32 pm
Cept pink.
#14 SteveGlover
SteveGlover
  • 857 posts
Posted 16 May 2006 - 09:31 pm
QUOTE(dapleb @ Tue 16th May 2006, 05:34 PM) <{POST_SNAPBACK}>
OK, thanks.
#15 Guest_Emmett_*
Guest_Emmett_*
Posted 16 May 2006 - 09:33 pm
QUOTE(oiler @ Tue 16th May 2006, 08:17 PM) <{POST_SNAPBACK}>
Cept pink.
#16 guydewdney
guydewdney
  • 19 posts
Posted 19 May 2006 - 08:29 am
Has anyone else got Kent cams in their Mk2? I have - and did the shims twice - and it sounds very 'clattery' - is this normal?
#17 wicklamulla
Posted 19 May 2006 - 08:32 am
QUOTE(guydewdney @ Fri 19th May 2006, 09:14 AM) <{POST_SNAPBACK}>
dunno Guy as i haven't got Kents, was interested in sourcing some though but ££££ a guy told me i cud send off the stock cams and have them reground to a new spec. Bob Farnham tooning does it i believe.
#18 tdm850rider
Posted 19 May 2006 - 10:29 am
QUOTE(oiler @ Mon 15th May 2006, 03:27 PM) <{POST_SNAPBACK}>
#19 dandywarhol
Posted 19 May 2006 - 02:25 pm
QUOTE(wicklamulla @ Fri 19th May 2006, 09:17 AM) <{POST_SNAPBACK}>
Send them straight to Kent.................why line Uncle Bob's pockets?????????
#20 wicklamulla
Posted 19 May 2006 - 05:53 pm
QUOTE(dandywarhol @ Fri 19th May 2006, 03:10 PM) <{POST_SNAPBACK}>
