Fitting a acumen gear indicator DG8 to the 900
27 replies to this topic
#1 Geordie Guy
Posted 09 December 2007 - 12:53 pm
Being a absolute novice with electrical soldering and the black art.
This is how I fitted my DG8 I got from the Motorbike show last week.
Acumen do not have the TDM electrical wiring on their web site. So I posted the diagram from JBX
and Paul from acumen came up trumps with the following.
Acumen wire colours soldered to TDM 900 colours
Acumen Brown to Grey into ECU ( Tacho)
Acumen Orange to White / yelow into ECU (Speed)
Acumen Red to Red /white into ECU ( +ve)
Acumen Black to Black / white into ECU (-ve )
Acumen Green to light green into Dash board cluster ( neutral light)
ECU is on LHS under side panel, you have to unwrap the bundle to get to the wires.
The dash board cluster is the bundel above that goes off to the Dash board.
Soldering was fiddley, especialy since it was my first go at soldering ever !!!
Once you have soldered the correct wire to each other, switch the engine on to see if it works
I fitted it here on the dash as there was no need to drill to fit it.
Once it's in, make sure everything is wrapped up again, off you go.....
#2 Sparky
Sparky
  • 809 posts
Posted 09 December 2007 - 01:07 pm
My tip when making these kind of joints: After taping up the soldered connection, gently run the side of the soldering iron tip over the end of the tape. This seals it and stops it from peeling away in the cold weather. good.gif
Ex-TDM owner. Now riding a Sprint ST 1050
#3 Baron
Baron
  • 1,076 posts
Posted 16 March 2008 - 10:46 pm
I fitted a DG8 to my 2007 ABS 9'er yesterday and thought I'd pass some additional info on for others to use.
When you look behind the left side fairing panel you'll see more electrical gubbins than those pictured above but the connection table below still mostly holds true. The only difference being the neutral light wire which is no longer light green but is now sky blue (a very light blue).
Acumen Green to SKY BLUE into Dash board cluster ( neutral light) see pic
### Any chance of moving this topic into the knowledge base as I found it to be a very useful script? ###
Edited by Baron, 17 March 2008 - 08:54 pm.
#4 tdm850rider
Posted 16 March 2008 - 11:06 pm
QUOTE(Baron @ Sun 16th Mar 2008, 06:31 PM) <{POST_SNAPBACK}>
Agreed, (If any Mods or Admins do not agree just move it back here All About TDM). To KB pursuant to 'fact checking'.
#5 robgosty
robgosty
  • 187 posts
Posted 28 March 2008 - 07:38 pm
Fitted mine this evening, just a bit of info for others, mine is a 2002 900 and there are two grey wires going to ECU, if you connect to wrong one (like i did) wub.gif unit will not learn gears, if this happens no harm done just swop to the other one
Edited by robgosty, 28 March 2008 - 07:39 pm.
Yamaha XV 1000
Kawasaki GPZ 750
Honda CBR 1000F
Yamaha XV1100 Virago
Yamaha Yellow TDM 900
Suzuki Hayabusa
Current
2000 Yamaha XJR 1300
#6 Saga Lout
Posted 30 March 2008 - 11:01 am
QUOTE(Sparky @ Sun 9th Dec 2007, 01:52 PM) <{POST_SNAPBACK}>
Better still is to use heat shrink tubing; slide it over the cable, make solder or crimp joint, slide tubing over joint and shrink using a heat gun or hair dryer. You can buy this in different sizes from most electrical wholesalers.
#7 Landy
Landy
  • 1,387 posts
Posted 30 March 2008 - 11:17 am
wifgeni.gif and if you want a waterproofed connection you can get heat shrink tubing with heat activated glue as well. Maplin Link
#8 Saga Lout
Posted 30 March 2008 - 11:26 am
QUOTE(Landy @ Sun 30th Mar 2008, 12:02 PM) <{POST_SNAPBACK}>
Good point, forgot to mention that one and I was only using this 3 days ago whilst wiring some water treatment units...must be old age creeping in help.gif
#9 Sparky
Sparky
  • 809 posts
Posted 31 March 2008 - 02:30 am
QUOTE(Saga Lout @ Sun 30th Mar 2008, 11:46 AM) <{POST_SNAPBACK}>
That's the best thing to use when joining ends, but when piggybacking onto existing wiring (as in this topic), you can't fit heatshrink unless you cut the wire you intend to join onto. I prefer not to do that. dry.gif
#10 Buzz
Buzz
  • 321 posts
Posted 09 August 2008 - 08:50 pm
Self amalgamating tape has always done the job for me, always carry a roll, bloody marvellous for a get you home temp fix for all sorts of ills
NOSTALGIA IS NOT WHAT IT USED TO BE
#11 Toraneko
Toraneko
  • 364 posts
Posted 06 February 2009 - 01:29 am
Surely there's a connector housing where each pin can be removed, soldered to & then re-inserted ? Easy & neat. good.gif
Edited by TDMtoraneko, 11 April 2009 - 01:10 pm.
cheers, Shane from Tassie
#12 SpeedDevil
SpeedDevil
  • 20 posts
Posted 15 December 2010 - 11:35 am
I'm sorry if I sound a bit stupid, but from what I see the only connections are +ve, -ve, tachometer, speed and neutral.
How does the gear indicator know what gear you are in?
Edited by SpeedDevil, 15 December 2010 - 11:39 am.
#13 catsbum
Posted 15 December 2010 - 01:49 pm
Why is the LED unit so bloody huge?
Surely there must be a slimline version.
If there was I would be tempted
#14 3vd
Posted 15 December 2010 - 03:20 pm
What do you need a gear position indicator for anyway?
#15 Geordie Guy
Posted 15 December 2010 - 05:02 pm
QUOTE(maximuspetrolhead @ Wed 15th Dec 2010, 03:20 PM) <{POST_SNAPBACK}>
I would not be without one now.
Its handy going into corners in the right gear, makes the riding a lot smoother and I used to forget to go into 6th gear on the motorway.
Ride for miles in 5th.
Personal preferance realy . BM fookin W's have them, why not my TDM.
#16 hallrob1
hallrob1
  • 1,112 posts
Posted 15 December 2010 - 05:10 pm
QUOTE(SpeedDevil @ Wed 15th Dec 2010, 11:35 AM) <{POST_SNAPBACK}>
It compares the speed with the revs (ie 80 mph @ 4000 revs = 6th gear) - if I remember correctly you have to go through a learning process to set it up.
I tried one on a Bandit I used to have but couldn't get a reliable reading - I used to spend my time working out myself what gear I was in then checking the unit. Decided that wasn't the idea and removed it.
#17 Backonthebike
Backonthebike
  • 14 posts
Posted 19 December 2010 - 01:22 am
QUOTE(hallrob1 @ Thu 16th Dec 2010, 02:40 AM) <{POST_SNAPBACK}>
I'm from the side of the fence that likes a gear indicator. I put one on my Honda Blackbird because it was so smooth and free revving in the tight stuff you didn't know whether you were in 2nd or 4th, and like someone else said, you would ride for miles in 5th and forget to change up.
I had no problems calibrating it. The only time it gets confused is if you pop the clutch and coast up to a set of lights; zero revs and 40km/h it can't work out.
I have taken it off the Blackbird as it's for sale, and will keep it for my planned TDM.
Better get a lawyer son, better get a REAL good one..........
#18 magneto
magneto
  • 65 posts
Posted 07 February 2011 - 09:17 pm
I just wish someone would make a 'You are now in top' indicator. Some Yamaha's (eg 900 Divvies) have a gearshift which gives free travel when in 1st or top - therefore you can tell with your foot instantly whether another gear is still available without shutting the throttle or pulling the clutch. Admittedly, I reckon if I only ever rode the same bike it would be unnecessary, but I don't. Gear indicators seem to suffer from lag, but if the parameter was simply rpm in relation to roadspeed surely that can't be too complex to find top gears range and light an led?
#19 Rocco
Rocco
  • 38 posts
Posted 28 February 2011 - 04:20 pm
I'm not interested in cutting main installation before ECU, would rather connect it to wires before dash board...
There should be tacho and speed signal too?
By the way, does anyone have service manual for 2008 ABS model, the one on jbx doesn't work for me...
#20 SteveK
SteveK
  • 664 posts
Posted 01 March 2011 - 09:36 pm
QUOTE(magneto @ Mon 7th Feb 2011, 09:17 PM) <{POST_SNAPBACK}>
I did the JBX gear indicator mod but for 6th gear only. Just one small green LED on the dash is all i need.
Steve
Link - http://jbx9.free.fr/...x.php?page=GIND
Edited by SteveK, 01 March 2011 - 09:38 pm.
