Engine overhaul
26 replies to this topic
#1 ChrisG
Posted 18 March 2006 - 05:35 pm
In response to a comment on another thread, I thought I'd put up some detail of my rebuild.
Oil consumption on my 92 Mk1 was getting silly, an 1100 mile long weekend to Ireland got through 1.8 litres, and people were starting to comment on the amount of smoke it was producing under acceleration.
Prime suspect was the piston rings, and £35 to M&P for a compression tester (needed to unbolt the radiator and drop it foreward a bit to get enough access for the tester) showed over 1.5 bar increase in pressure when I bunged some oil down the barrels, a sure sign of ring problems I'm told.
Apart from the cam chain tensioner being behind a engine mounting bracket it's pretty easy to get the head off a Mk1. Exhaust, fuel tank, airbox, carbs, radiator and thermostat housing all need to come off first, then you can get the valve cover off. Turn the engine to TDC (the Mk1 is a 360 degree crank unlike the Mk2 which is 270), take out the cam chain tensioner and front guide, take off the cam sprockets and oil banjo bolt and the head unbolts and lifts off. After struggling to get the block off for 10 minutes, undo the coolant union on the front of the block and the head pops off easily. 2 circlips on the ends of the piston pins and the pistons pop off.
My pistons were filthy, but cleaned up nicely with some Mr Muscle oven cleaner and a toothbrush. The head and barrels I took down to a local bike shop who sent the barrels off to be honed, cleaned up the head, and leak tested all the valves. I also ordered all the new gaskets and o-rings from him. Took him a couple of weeks to get everything and the total cost was about £270 I think.
New piston rings went on easily enough but getting the head on (with 2 new o-rings and a new gasket) took a while with a mate helping, the bottom of the barrels is chamfered to make it easier but it's still a struggle, and the only piston ring compressors I could find didn't open fully so are only any use if you've disconnected the con rod from the crank rather than from the piston (I'm told this is the usual method in cars). Once the barrels were on, the head went on pretty easily with a new head gasket. Getting the cam sprockets on and lined up properly is a bit fiddly but not too bad. I got a new seal for the valve cover, but probably didn't need it, and found that you need to stick the seal to the cover with a few dabs of sealant or otherwise it falls off when you're getting the cover in to position. From there it's a fairly simple matter of refitting all the ancillary bits (getting the throttle cables on the carb is far from simple though)...then taking the valve cover back off when you find the cam chain front guide still sitting in a crate in your garage. I damaged an o-ring putting the coolant union back on the front of the block, so had to wait a week to get another one from Yam at the rather high price of £1.75 (nowhere near me seemed to stock sensible sized o-rings). New oil and filter, plus the o-rings in the filter housing (get the filter from Halfords, it comes with the large o-ring), and some coolant and it was pretty much done. My exhaust is a bit knackered and I needed some sealant on some of the joints, so I actually used a high temperature sealant instead of exhaust gaskets, mainly because I'd completely forgotten to order them and couldn't be bothered to wait another week.
So far I've only done about 50 miles, using cheap Halford own brand oil and keeping it to about 5000 rpm without too much hard acceleration. I intend to do an oil change before doing many more miles and then gradually start working the engine a bit harder for the next few hundred miles, but I'm moving house this week so it might be a while before I do this or use the bike much. It's worth checking the oil very regularly to begin with, it dropped very quickly in the first few miles, presumably a bit gets past the rings before they bed in and there's a lot of places in the engine for oil to go that it probably doesn't get to until the engine's running.
Total cost was probably around £350, something like £120 of that was the gaskets, and I could have saved some cash if I'd done the work on the head myself and found someone to hone the barrels rather than having the bike shop take a cut for sending them to someone else. Plus that included a few tools like the compression tester and a rubber mallet. In terms of the amount of time taken I reckon if I'd pulled my finger out I could have probably got it apart in a day and got it back together in another day, but because it's the first time I've done anything like that and I'm lazy and don't do weekend mornings in the garage in the middle of winter, it took more or a less a weekend to strip and another weekend to rebuild. Getting the head on and off is defintaly a 2 man job. I would class myself as reasonably technical but I'd never attempted any work like thisbefore. I learned loads, enjoyed doing it, and was suprised how easy it actually was.
Didn't intend this to be quite such a long essay, but hope it's of interest to someone. If you made it this far I've even included some pictures.
Pistons when they came out
And after cleaning
Head when it came off
Head after cleaning
Bike stripped down
#2 SteveGlover
SteveGlover
  • 857 posts
Posted 18 March 2006 - 06:03 pm
Nice job ChrisG
Looks like you had a lot of leakage past the rings looking at the colour of the piston.
Regarding running in - wasn't there a topic on the old forum about running in where you thrash the b*llocks off it for 50 miles or something?
#3 Guest_Emmett_*
Guest_Emmett_*
Posted 18 March 2006 - 06:10 pm
#4 ChrisG
Posted 18 March 2006 - 06:23 pm
QUOTE(SteveGlover @ Sat 18th Mar 2006, 05:48 PM) <{POST_SNAPBACK}>
Nice job ChrisG
Yeah, the Motoman website reckons you give it as much accelleration and engine braking as you can to start with. I can see the principle behind it, and he seems to have a reasonable amount of evidence, but he is talking about race bikes that get stripped down regularly, and I don't know of anyone who'd tried his method so I chickened out and went for the gentle breakin method.
The only other vehicle I've ever broken in was a 6 litre straight 6 diesel tractor, and the manufacturers recomendation was go and do a weeks ploughing to put a really heavy load on it, which would seem to agree with the motoman
#5 dapleb
  • 18,372 posts
Posted 18 March 2006 - 06:51 pm
Great job Chris. Like you say, it ain't that difficult to do and is very rewarding when it fires back up!
Why did you think head was a 2 man job?
As for running in..........
#6 wicklamulla
Posted 18 March 2006 - 07:55 pm
thats brilliant Chris, tanks fer takin' the time to document and photograph the process. d'only thing is im shitting meself if and when i decide to do it !!! i was hoping to get away with spending £200 on the same job you have just done but it sounds like im being too optimistic !!!
#7 JBX
Posted 18 March 2006 - 08:34 pm
Nice post ChrisG, good work !
I'm impressed by the before/after cleaning pics. wink.gif
#8 MrNice
MrNice
  • 17 posts
Posted 18 March 2006 - 10:37 pm
Yeah nice one GhrisG, what a good feeling it is too when it works, eh?
#9 Guest_Emmett_*
Guest_Emmett_*
Posted 18 March 2006 - 11:27 pm
QUOTE(wicklamulla @ Sat 18th Mar 2006, 07:40 PM) <{POST_SNAPBACK}>
Best wait till after summer now Wicky, It'd be a shame to go through a bit o summer with no bike, it's short enough as it is. sad.gif
#10 wicklamulla
Posted 19 March 2006 - 11:06 am
QUOTE(Emmett @ Sat 18th Mar 2006, 11:12 PM) <{POST_SNAPBACK}>
well thats prob whats goin to hapen anyway tbh as i canna motivate meself to do it rolleyes.gif
#11 Guest_Emmett_*
Guest_Emmett_*
Posted 19 March 2006 - 11:12 am
I know what ya mean, I got a fender extender and hand guards from kedo about 2 weeks ago fer the black tdm, I put on the hand guards, cause they're a nice clean job. but I cannae be bothered to put on the fender extender, my hands 'll get dirty. If I can't be bothered with that, I'd never even consider going into de motor.
#12 wicklamulla
Posted 19 March 2006 - 11:16 am
fender extenda is quicker to fit imo than the hand guards, 4 bolts out, tek it in doors and clean it up, drill the small holes (if ya decide the sticky stuff aint enuf) afix the above mentioned item....... mudguard back on.........jobs a turnip
#13 Guest_Emmett_*
Guest_Emmett_*
Posted 19 March 2006 - 11:19 am
It's the cleanin it up that I've got a problem with, think I'll rivet it on though, I don't like the idea of self tappers that close to me tyre. unsure.gif
#14 wicklamulla
Posted 19 March 2006 - 11:26 am
QUOTE(Emmett @ Sun 19th Mar 2006, 11:04 AM) <{POST_SNAPBACK}>
well don't do what some idiot i know did wub.gif and drill the holes small so as the tiny nuts and bolts were a very tight fit and after a ride out the vibes caused cracks to appear all around the holes, he removed said nuts and bolts and glued the feckin' thang in situ. holes and cracks (lol) look terrible now though..... ohmy.gif
#15 ChrisG
Posted 19 March 2006 - 01:30 pm
QUOTE(dapleb @ Sat 18th Mar 2006, 06:36 PM) <{POST_SNAPBACK}>
I found it really needed 3 hands, and possibly a spare leg. You could (and presumably from your comment and other posts you have) do it with one person but it would probably involve keep running round the bike as I found it needed a good wiggle from both sides. Getting it back on without using piston ring compressors involve me feeding one piston in while my mate did the other one. On an Mk2 it's probably eaiser as the pistons aren't both together.
I replaced the crank/barrel gasket, the head gasket and the valve cover seal, I could have got away with only the head gasket as the other 2 are reusable a few times and were in pretty good nick, but I figured for the sake of a few quid I may as well do it properly. I got genuine Yam o-rings which were way more than I'd have paid if I could get them from another source (I used to pay peanuts for o-rings from a manufacturer in Loughborough), and you can anneal and reuse copper washers but I got new ones. I also replaced the airbox rubbers 'cos they were knackered. I also spend £35 on the the compression tester, plus 2 oil filters and oil, and then there were a few other random trips to Halfords for things I'd forgotten. The bill from the bike shop for doing the head and getting the barrels honed was a fair bit, but I didn't fancy tackling the head myself, and I couldn't find anywhere local to do the honing for me, which would have been cheaper than sending it through the bike shop. I reckon if you shop around for the parts and do the head yourself you could shave a fair bit off the price.
QUOTE(Emmett @ Sun 19th Mar 2006, 10:57 AM) <{POST_SNAPBACK}>
... but I cannae be bothered to put on the fender extender, my hands 'll get dirty. If I can't be bothered with that, I'd never even consider going into de motor.
Note the customs and excise gloves in the photos, makes the job so much more pleasant biggrin.gif
QUOTE(MrNice @ Sat 18th Mar 2006, 10:22 PM) <{POST_SNAPBACK}>
Yeah, its a nice sense of achievement, as well as having saved me several hundred quid in labour. There is a nagging doubt in the back of my mind that it's going to goBANG though unsure.gif biggrin.gif
#16 dapleb
  • 18,372 posts
Posted 19 March 2006 - 02:39 pm
QUOTE(ChrisG @ Sun 19th Mar 2006, 01:15 PM) <{POST_SNAPBACK}>
Ahh ok you were talkin about the barrels...yeah thats def the most fiddly part.....such delicate parts and lots of juggling to get it right.
That'll pass as you get a few more miles on the clock.
Again great work and writeup Chris.
Edited by dapleb, 19 March 2006 - 02:41 pm.
#17 tdm850rider
Posted 19 March 2006 - 05:48 pm
Even I can follow it and I am seriously 'mechanically-challenged'
ADMIN: Do we have a 'HOW TO' section?
This would be a good post to start one with.
Splendid post Chris.
#18 dandywarhol
Posted 20 March 2006 - 02:18 am
#19 Walt_M.
Walt_M.
  • 41 posts
Posted 20 March 2006 - 11:42 am
That was a lot of work but I can't help thinking you should have replaced the pistons. Were they within specified clearance with the new barrel hone job? If they were, you'll probably be ok. If not, it'll be smoking again soon.
#20 dapleb
  • 18,372 posts
Posted 20 March 2006 - 11:46 am
The few high mileage TDM enjuns I've delved into have had very little/no ovalling of the bores, rings within spec and piston/ring clearance within spec....I think Chris found the same?
