Wifey has difficulty reaching the clutch lever ( not brake oddly !), so I bought a Kawasaki ER500 span clutch lever and its post. Whipped off the TDM, slid on the Kawasaki one with 5 adjustment positions.
The clutch switches are not the same but you just remove the spades out of the TDM 'male' terminal block connector and insulate them with heat shrink and then push the loose tails into the ER5 switch. The ER5 has 3 connection terminals and its the outer 2 you use for the TDM conversion.
Everything else fits where it was - switch cluster and grip plus the clutch cable nipple is the same fit too !!
See the pix on these links for the end result. ( ER5 lever £9 off ebay)
M.M.
http://www.bikepics....ctures/1178671/
http://www.bikepics....ctures/1178673/
http://www.bikepics....ctures/1178676/
http://www.bikepics....ctures/1178679/
Edited by Matrix Monkey, 10 February 2008 - 04:29 pm.
