Fuel Injection setting
60 replies to this topic
#1 alloypiston
alloypiston
  • 123 posts
Posted 12 June 2006 - 09:49 am
Hi all,
has anyone noted the CO setting for TDM 900. I seems to be having bit of fuelling problem and would just like to compare notes
My original setting were C1=5 and C2=22.
There is a difference between C1 and C2 this is primarily because the C2 Runs hotter than the C1
Has anyone changed the setting and if so was there a difference.
Thanks,
A
TDM 900
XJR1300SP
SRX6
SRX4
TZR250 Reverse Cylinder
YX600 Radian
BROS 650
SDR 200
#2 Minty Hippo
Minty Hippo
  • 725 posts
Posted 12 June 2006 - 12:40 pm
QUOTE(athula wilson @ Mon 12th Jun 2006, 08:34 AM) <{POST_SNAPBACK}>
Hi all,
Thanks,
A
Mine are now set at 10 and 10, but I might fiddle with that again. Dandy will give you the gen on this.....
Edited by Minty Hippo, 12 June 2006 - 12:40 pm.
#3 mr grumpy 2
mr grumpy 2
  • 99 posts
Posted 12 June 2006 - 02:01 pm
25 and 20, good responce.
30 and 25, smoother also 15 and 10 works well.
i found 10 and 10 a bit vibey on my bike.
you will have to give it a try, each bike might like slightly different settings.
#4 alloypiston
alloypiston
  • 123 posts
Posted 12 June 2006 - 02:58 pm
QUOTE(mr grumpy 2 @ Mon 12th Jun 2006, 02:46 PM) <{POST_SNAPBACK}>
Do you mean C1=30 and C2=25.
I have found that TDM900, 850 and TRX850 run hotter in C2 which can be seen in the slighly more discolouration of the C2 header pipe and therefore the TDM 900 are set to run richer on C2.
Any ideas/
athula
TDM 900
XJR1300SP
SRX6
SRX4
YX600 Radian
BROS 650
SDR 200
#5 boisty
boisty
  • 15 posts
Posted 12 June 2006 - 08:27 pm
Has anyone seen the plot?
#6 wicklamulla
Posted 12 June 2006 - 10:32 pm
QUOTE(boisty @ Mon 12th Jun 2006, 09:12 PM) <{POST_SNAPBACK}>
#7 mr grumpy 2
mr grumpy 2
  • 99 posts
Posted 19 June 2006 - 09:12 am
QUOTE(mr grumpy 2 @ Mon 12th Jun 2006, 01:46 PM) <{POST_SNAPBACK}>
C1=25 and C2=20, good responce.
C1=30 and C2=25, smoother also C1=15 and C2=10 works well.
i found C1=10 and C2=10 a bit vibey on my bike.
currently running C1=25 and C2=20. good responce and good starting, got the airbox mod as well.
#8 slimjim
slimjim
  • 62 posts
Posted 23 June 2006 - 11:51 am
Any ideas off a good setting with K&N ,airbox mod and exhaust with baffles removed . Im off to Skye tomorrow and wouldnt mind doing it before i go . good.gif
#9 wicklamulla
Posted 23 June 2006 - 04:50 pm
QUOTE(slimjim @ Fri 23rd Jun 2006, 12:36 PM) <{POST_SNAPBACK}>
well i dunno Jim, but why no try a new setting and just change it every now and again on yer trip to see if ya find a goodun 4u ??
#10 slimjim
slimjim
  • 62 posts
Posted 23 June 2006 - 07:46 pm
Will i notice much on a run or is it more riding around town ?
#11 wicklamulla
Posted 23 June 2006 - 09:56 pm
Dunno, try and see. make a note of every setting you try though and hi lite the better ones.
#12 mr grumpy 2
mr grumpy 2
  • 99 posts
Posted 23 June 2006 - 10:17 pm
is this not setting the level of CO in the exhaust?
so would the injection not compensate for minor mods and maintain the desired CO level??
is this why there is a sensor on the exhaust???
#13 Pict
Posted 24 June 2006 - 06:47 am
QUOTE(mr grumpy 2 @ Fri 23rd Jun 2006, 11:02 PM) <{POST_SNAPBACK}>
'Scuse my confusion, but I thought that was the point - to set the "burn" rate (CO level) for the performance you want, and the sensor will then keep the injectors informed and behaving themselves so as to target that setting?
(Still new and willing to learn - nervously moving towards actually doing some of this stuff)
#14 muddy
Posted 28 June 2006 - 02:15 pm
QUOTE(Pict @ Sat 24th Jun 2006, 07:32 AM) <{POST_SNAPBACK}>
Well I changed my settings last summer from C1 17 & C2 25 to C1 10 & C2 10. I've just gone into CO mode to find, lo and behold, C1 was now at 3 and C2 remained 10. So does that mean that it self regulates???
#15 dandywarhol
Posted 28 June 2006 - 04:20 pm
QUOTE(muddy @ Wed 28th Jun 2006, 03:00 PM) <{POST_SNAPBACK}>
Hmmmmmmm - weird, shouldn't self regulate muddy....yo sure you didn't press the button back instead of changing cylinder?
#16 muddy
Posted 28 June 2006 - 04:53 pm
QUOTE(dandywarhol @ Wed 28th Jun 2006, 05:05 PM) <{POST_SNAPBACK}>
Nope. I followed the sequence diligently. Last time I set both C1 & C2 at 10 for sure. And C1 was now at 3!? So I don't know what's going on there.
As an aside I just did the airbox mod as well (I unhooked the wire from the flap rather than disconnect the hose). Took it out for a spin, having set CO to C1 14 and C2 22, and there was a marked improvement in throttle response. Also it needed much less throttle to start. Just slight blip as oppossed to a handful that I normally have to give it.
#17 dandywarhol
Posted 28 June 2006 - 05:19 pm
QUOTE(muddy @ Wed 28th Jun 2006, 05:38 PM) <{POST_SNAPBACK}>
Even weirder muddy..........FI shouldn't need any throttle to start - sure you aren't drawing air somewhere?? unsure.gif
#18 wicklamulla
Posted 28 June 2006 - 06:29 pm
wood the CO setting revert to a default setting if the battery was removed perhaps ??? or if she stalled and the clocks reset like has happened to a few of you wonderful, lovely 900 riders ????
#19 alloypiston
alloypiston
  • 123 posts
Posted 29 June 2006 - 11:45 am
So the TDM has been in the Yamaha London Dealer last 2-3 days and They found nothing wrong with the ECU. Yamaha technical department has suggested to replace the Trottle Possitioning Sensor(TPS). This will happen middle of next week I have been told. has anyone had problem with the TPS,
regards,
A ranting.gif An angry man!
TDM 900
XJR1300SP
SRX6
SRX4
YX600 Radian
BROS 650
SDR 200
#20 Minty Hippo
Minty Hippo
  • 725 posts
Posted 29 June 2006 - 12:12 pm
QUOTE(athula wilson @ Thu 29th Jun 2006, 10:30 AM) <{POST_SNAPBACK}>
regards,
I did wonder if this might turn out to be TPS rather than ECU. TPS probs are known about on the early 9's but I thought they were sorted by now. I sometimes wonder if mine operates the way it should. There is stuff on the old site about this I think... unsure.gif Dappers, Alan, over to you... help.gif
