Scottoiler
Guest_nils_*
Posted 12 June 2006 - 11:41 am
Most of all I would replace the chain for a belt drive, but I cannot find any conversion kit for the 900.
My questions are:
o Will a Scottoiler leave less oil residue on the rim?
o Is it difficult to set up the Scottoiler for rigth amount of oil?
o Do you have to tweek these settings every 100 kms?
o Are you all happy with your Scottoiler?
Thanks for any feedback
/Nils
Posted 12 June 2006 - 12:28 pm
My questions are:
/Nils
1=yes
2=no
3=no. only winter/spring when weather is colder or warmer
4=yes very
Posted 12 June 2006 - 12:36 pm
- probably not
- in my experience, yes but I'm a klutz
- no, about every 300kms
- yes, amazingly, given my answers above.
The Scottoiler is definitely better than spray on lubricants, but it is not pefect. Its hard to get mine to deliver just the right amount, its usually too much or too little. But I've had several bikes with Scottoilers and the chains definitely last longer. Of the spray on types I reckon Castrol chain wax is pretty good, doesn't shift much, not in normal Scottish temperatures anyway.
Posted 12 June 2006 - 02:08 pm
if adjusted as temperature changes/when wet or dry
its a balance between wet looking chain and messy wheel
just have to look and chain and wheel when you remember
yes
i have the touring kit and dual injector. means longer between top up and i think better oiling of chain for less mess on the wheel.
even riding through all weathers i get more than 20k miles from a chain.
Posted 12 June 2006 - 04:23 pm
yes, it actually did more to clean my bike than i have.
can be a little tricky, but patience is a virtue
only when the ambient temp or altitude changes significantly
yes, but i wish i'd got a mechanic to install it for me, coz i'm also a clutz
Posted 12 June 2006 - 06:38 pm
yes, wipes off easily
no
no only change setting during winter as oil gets thicker as temperature falls
very happy
Just noticed my answers are the same as Aytcat
are you thinking of fitting the touring version (fits behind number plate), easy to view oil level.
2007 Triumph Tiger 955i
Posted 12 June 2006 - 07:51 pm
The oil actually keeps the sprockets & chain clean, & there's minimal oil on yer wheel rim once it's set up right.
The only thing I've found that's better is the shaft drive on me Beemer
The older I get, the better I was
Guest_nils_*
Posted 12 June 2006 - 08:03 pm
I read somewhere that some people go back to single injector after using dual for a while. Is it more difficult to adjust the oil flow when using dual injectors? What are the pros and cons?
Thanks again!
/Nils
Posted 12 June 2006 - 09:56 pm
The single injector is much more solid & mounts to the side of the sprocket. It can be set more accurately, but relies on capilliary action to get the oil across the other side of the chain.
Having tried both, I prefer the single injector, but it's entirely personal choice, as both are effective .
Posted 12 June 2006 - 10:01 pm
My questions are:
/Nils
Nils have you contacted these people??? http://www.vh-motorr....php?content=34
Posted 12 June 2006 - 10:07 pm
Oi likes that belt drive Fazer
Posted 12 June 2006 - 10:27 pm
Posted 12 June 2006 - 10:33 pm
To stop oil on my rear rim I "borrowed" a plastic ie tupperware bowl or similar from the kitchen cupboard (silently
I then used approx a third of the bowl, bent up an aluminium angle bracket and bolted it to the chain tensioner nuts at the rear of the swing arm, pop rivetted the plastic to the bracket and bolted the top to the chain guard for easy wheel removal.
Works a treat.
Can even colour match the bowl to ya bike eh???
Will take a photo when the camera is repaired.
"Beauty is in the eye of the beer holder"
click here to read: "Adventure Riding Assumption of Risk"
Posted 12 June 2006 - 10:35 pm
Works a treat.
ahhhh s'funny i was tinking of doin just that
Posted 12 June 2006 - 10:43 pm
An' den yer jes need a poipe from der tupperware bowl to yer oil filler cap - yes could save yersen hours every week, Wicky
Posted 12 June 2006 - 10:45 pm
u feckin mindreader
#17
Guest_nils_*
Posted 13 June 2006 - 06:41 am
/Nils
#18
Posted 13 June 2006 - 12:08 pm
Whatever you use... there will always be some fling.
I think the Scottoilers probably put a lot more oil on than the chain actually needs.
No.
Extremely. You pay ~£70 open the box... and think is that all it is... lol. But then when you've seen it working and you can see how clean and wet your chain is it's worth every penny.
If they reckon that the chains will last about 20K miles with a Scotty.... then it's not worth having a belt drive is it?
Previously Owned: 1997 Yamaha SR125, 1998 Yamaha XJ600S Diversion
Currently Own: 2003 Yamaha TDM900, 1981 Honda CX500 US Custom, 1995 Yamaha XJ600S Diversion
#19
Posted 13 June 2006 - 12:23 pm
Most definitely
No. The mechanic who fitted it for me told me that if you have oil on your tyre it is set too high. If the chain is dry it is set too low.
No.
Really happy. The chain is clean and damp with oil all the time now.
#20
Guest_E.T._*
Posted 13 June 2006 - 03:38 pm
Am I happy with the Scotoiler? Yep
