3vd/mk1 - Periodic Servicing Part Numbers
No replies to this topic
#1 TonyDevil
Posted 21 July 2008 - 04:08 pm
SPARK PLUGS
standard : DPR9EA-9 NGK part#: 5329
IRIDIUM : DPR8EIX-9 NGK part#: 2202
OIL FILTERS
OEM part#: 4X7-13440-90-00
HiFlo part#: HF145
K&N part#: KN-145
AIR FILTER
OEM part#: 1AE-14451-00-00
HiFlo part#: HFA4403
K&N part#: YA-7585
FRONT SPROCKET, WASHER & NUT PART NUMBERS
locking tab washer 90215-21022-00 - replace each time you refit the nut
Front sprocket nut 90179-18020-00 - old part number
unofficial front sprocket nut upgrade 90179-18667-00 (its larger and uses the whole of the outputshaft thread) - YZF750/YZF1000 part, also listed as a FZR6 (?) official upgrade
front sprocket number 3VD-17460-00-00 - IMHO (rolleyes.gif) aftermarket front sprockets aint worth using on a mk1
especially JT which seems the most common in the UK and aint a good fit on the splines
CARBURETOR SERVICE PARTS
Airbox rubbers 3GM-14453-00-00 (need 2 of them) these get hard over time, normally last a good few years
emulsion tube / needle jet 3GM-14141-94-00 (need 2 of them but get factory pro parts from straightline racing instead as they dont wear like the yammie ones)
float bowl gaskets 3GM-14997-00-00 (still need to confirm this part number sorry.gif EDIT: confirmed on 2009/07/15- same part# for mk2 aswell) - if you're having the carbs apart and dont replace them chances are you'll have the carbs apart again in a few hundred clicks dry.gif just like me elf and catsbum
Carb rubbers 3LD-13597-00-00 (need 2 of them)
ps. i believe these are the same on mk2 up to 1999)
pps. a how-to guide for carb servicing is here
