Disappearing Coolant
Posted 20 September 2008 - 08:00 pm
Neil
#2 Guest_Catteeclan_*
Posted 20 September 2008 - 08:10 pm
Rad cap sealing rings in good order?
Posted 20 September 2008 - 08:28 pm
Neil
replace the rad cap that should do it ok
Posted 20 September 2008 - 10:48 pm
Posted 21 September 2008 - 07:42 am
Posted 21 September 2008 - 04:37 pm
You can get the coolant tested to check for signs of engine gasses in it but I had a chat with the bloke who services my car and he said he's got one of the kits to do it but they're fairly unreliable, in the end I just decided it was going to be cheaper and easier for me to replace the head gasket and hope that fixed it than spend a fortune for Woking Yamaha to diagnose the problem.
Edited by ChrisG, 21 September 2008 - 04:40 pm.
Posted 21 September 2008 - 08:56 pm
Neil
Posted 21 September 2008 - 09:06 pm
if your realy concerned have a compression test on the engine and that will reveal all , i did and mine was well within the limits
#10 Guest_celticbiker_*
Posted 21 September 2008 - 09:21 pm
Wot he said.
So long as the temp is OK I would'nt worry about the behaviour of the coolant.
As long as the expansion tank is above minimum and no higher than maximum when the coolant is cold then it's OK
#11 Guest_Catteeclan_*
Posted 22 September 2008 - 08:00 am
Best test I've found so far is to get each piston at TDC, stick it in 4th with the handbrake on and shove 150psi down the plug hole. If the air leaks into the water jacket the water level will rise, or in some cases fire out of the rad like a gusher. I made the tool by breaking the middle out of a spark plug and soldering in a 10mm pipe.
Yet to try it on a bike though.
Edited by Catteeclan, 22 September 2008 - 08:01 am.
Posted 22 September 2008 - 05:17 pm
Posted 22 September 2008 - 08:36 pm
Thanks for the assuring words, i may be overeacting i hopei,m wrong.
Thanks fellow TDM riders
Neil
Posted 24 September 2008 - 08:40 pm
confused
Neil
Posted 24 September 2008 - 08:53 pm
#16
Posted 25 September 2008 - 06:59 pm
i think the leaking head gasket is causing a air lock ,
anyways I stripped the bike in my lunch hour and i am going to check the torque of the head bolts first but i think its going to need a new gasket at the end of the day , i feel like pants on a fat man at the moment and as usual its at a time when money cant be spent on bikes..
so who knows a good place to get pattern gaskets ????
#17
Posted 25 September 2008 - 07:16 pm
Nope. I'd go orig for the head gasket. £30 ish?
#18
Posted 25 September 2008 - 07:54 pm
#19
Posted 25 September 2008 - 08:20 pm
Neil
#20
Posted 25 September 2008 - 09:56 pm
