Rear wheel bearings
73 replies to this topic
#21 wicklamulla
Posted 23 December 2006 - 05:40 pm
apparently KTM fit custom size/style bearings on their bikes and this proves a nightmare fer peeps trying to replace bearings on the cheap.
#22 fluteplayer
fluteplayer
  • 68 posts
Posted 24 December 2006 - 06:41 am
QUOTE(GuyGraham @ Sat 23rd Dec 2006, 03:48 PM) <{POST_SNAPBACK}>
Sorry Fluteplayer - local bike shop said they are specials only available from Yamaha at present
Oh well, I will have to bite the bullet and pay yamaha prices then! Thanks so much for taking the trouble to enquire on my behalf.
You could try taking the measurements to a local bearing factor to see if they can help, as Yamaha sure ain't making the bearings themselves, they are sourcing them from somewhere in Japan.
I will, and see if they can be matched. If so I will post the details up here, I am sure they will be useful to people in the future.
Thanks again for trying!
Fluteplayer
(\__/)
(")0(")
This is Bunny. Copy and paste Bunny into your signature to help her gain world domination
#23 TDMTAM
Posted 24 December 2006 - 10:51 am
If you have taken the bearing s out , then measure the inside Dia, outside Dia and the width of the bearing, note if theey have seals on the (probably will) Then good to a bearing supplier like BSL and they should be able to sort you out.
#24 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 24 December 2006 - 12:03 pm
QUOTE(TDMTAM @ Sun 24th Dec 2006, 10:36 AM) <{POST_SNAPBACK}>
Not always true - BSL can source most bearings inc all of the common ones, but as I stated in an earlier post, some bearings are specials not available in this country through normal distributors (ie they are non standard sizes), meaning you have to buy them through Yamaha or Suzuki etc at their inflated prices.
They do this to stop you buying std bearings - so more profit for them. Bastards ranting.gif
Edited by GuyGraham, 13 February 2008 - 07:39 pm.
#25 TDMTAM
Posted 24 December 2006 - 12:25 pm
QUOTE(GuyGraham @ Sun 24th Dec 2006, 11:48 AM) <{POST_SNAPBACK}>
Thats why I did say "should" they have let me down before with the cush drive bearing on my mk1 .So I'll have to bow down to your experiance of the 900. just thought in may help.
#26 fluteplayer
fluteplayer
  • 68 posts
Posted 28 December 2006 - 11:02 am
The quest continues!
I finally gave in and bought some Yamaha rear wheel bearings, I will use the sizing and other information to try and find out whether there is a pattern replacement available.
The bearings are marked Koyo 60/28RK
They are sealed (both sides)
At room temperature, the following sizes were measured:
OD: 49.5 mm
Depth: 9.5 mm
The sprocket carrier bearing is widely available and is # 6206
I will report back with any further information!
Fluteplayer
(\__/)
(")0(")
#27 dapleb
  • 18,389 posts
Posted 28 December 2006 - 11:44 am
Thanks FP.
Koyo seem to do alot of the OEM bearings for Yamaha.
That Koyo part number would allow you to cut out the middle man (Yamaha) and prolly half the cost by going to any good bearing supplier....though you may not want to know that now unsure.gif They will also be able to cross reference to other bearing manufacturers.
Moved to Knowledgebase so others don't have to go throught he hassle you have. good.gif
#28 dandywarhol
Posted 28 December 2006 - 04:27 pm
QUOTE(fluteplayer @ Thu 28th Dec 2006, 10:47 AM) <{POST_SNAPBACK}>
OD: 49.5 mm
Depth: 9.5 mm
Fluteplayer
#29 fluteplayer
fluteplayer
  • 68 posts
Posted 28 December 2006 - 07:16 pm
QUOTE(dandywarhol @ Thu 28th Dec 2006, 04:12 PM) <{POST_SNAPBACK}>
Fluteplayer
(\__/)
(")0(")
#30 Hartside Man
Posted 28 December 2006 - 07:24 pm
QUOTE(fluteplayer @ Thu 28th Dec 2006, 07:01 PM) <{POST_SNAPBACK}>
Fluteplayer
now you have quoted the part number of the odd bearing here is some info i found on google
http://www.google.co...q...earch&meta=
top one is interesting
#31 sidestand
Posted 29 December 2006 - 06:06 pm
I found this on the Foc-U forum - if they're good fer Fazers, they should be OK fer TDM's
http://www.bikebearings.co.uk/
#32 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 31 December 2006 - 04:13 pm
QUOTE(dapleb @ Thu 28th Dec 2006, 11:29 AM) <{POST_SNAPBACK}>
KOYO do bearings for all the jap bike manufacturers, because they are one of the worlds best manufactures of bearings. they are top quality bearings and you won't buy better even if you spend more.
B&C Express http://www.bandcexpr...?cat=BE-KOYOMTN quote the 60/28 2RS at £8.48 ea
Edited by GuyGraham, 31 December 2006 - 04:24 pm.
#33 fluteplayer
fluteplayer
  • 68 posts
Posted 31 December 2006 - 04:26 pm
QUOTE(sidestand @ Fri 29th Dec 2006, 05:51 PM) <{POST_SNAPBACK}>
They were the people who wrongly supplied in the first place!
Fluteplayer
(\__/)
(")0(")
#34 Guest_celticbiker_*
Guest_celticbiker_*
Posted 13 February 2008 - 06:42 pm
Anyone know what the part number of the rear wheel bearing is for an '02 900, eg 6206(sprocket carrier) or 6004(front wheel)
Can't seem to find it listed anywhere.
CB
#35 Sparky
Sparky
  • 809 posts
Posted 13 February 2008 - 07:23 pm
QUOTE(celticbiker @ Wed 13th Feb 2008, 06:27 PM) <{POST_SNAPBACK}>
CB
Taken from the '04 parts list, but I presume it's the same bearing:
93306-07806-00
Ex-TDM owner. Now riding a Sprint ST 1050
#36 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 13 February 2008 - 07:28 pm
CB
seem to remember this discussion a while back and that it was a special, but then it was found at B&C Express
Let me find the thread
Here it is in the knowledge base
http://www.carpe-tdm...?showtopic=2657
Rear wheel bearings are 60/28 2RS - £8.48 from B&C, although should be able to get them from any bearing factor
Seems a std 60/28 bearing is 28x52x12mm, but according to Fluteplayer, he measured his wheel bearings (which were marked as 60/28 as 25.5x49.5x9.5mm, so it seems another case of bearings marked with a std number but are actually different (see below)
Suzuki are pulling the same stunt with the main bearings for my DRZ400. they are marked as 6306's
They are the same as std 6306, but 18mm thick instead of the normal 19mm. - std 6306's are about a tenner from a bearing factor or generic Koyo from the bike shop, but these specials are Suzuki supply only at £45 ea.... WTF!
£90 for a pair of main bearings - robbing bastards
Edited by GuyGraham, 14 February 2008 - 01:06 pm.
#37 Guest_celticbiker_*
Guest_celticbiker_*
Posted 13 February 2008 - 08:21 pm
QUOTE(Sparky @ Wed 13th Feb 2008, 07:08 PM) <{POST_SNAPBACK}>
93306-07806-00
Thanx sparx, but I've got that that number I was after the BEA number(see GG's ppost above) but it is, as I feared a special bearing.
CB
#38 Guest_celticbiker_*
Guest_celticbiker_*
Posted 13 February 2008 - 08:41 pm
QUOTE
whats the yamaha part no's then
usually the bearing code is embedded into the yamaha part no somewhere
ie if it were a 6204 bearing, then those numbers would be somewhere in the yamaha part no.
My bike shop always look at the yamaha part number then comes up with the std bearing number this way
this is from the link in GG's post above, and if this is the case then:-
We know the front wheel bearing is a 6004 and the yamaha part# is-93306-00420-00
So if we follow that rationale then the rear wheel bearing part number being 93306-07806-00
should make the bearing a 6078.
I'll call in at my local factors tomorrow and try out this exiting new theory.
CB
#39 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 14 February 2008 - 08:29 am
QUOTE(celticbiker @ Wed 13th Feb 2008, 08:26 PM) <{POST_SNAPBACK}>
CB
Yes - I agree it should be, but if you look in the thread I linked to in my post above, you'll see we've been there
6078 isn't a bearing
Actually bearing is a 60/28 but the std 60/28 isn't ther same as the ones fitted to the 9'er rear wheel - unless anyone confimr otherwise
Edited by GuyGraham, 14 February 2008 - 08:29 am.
#40 Galilee
Galilee
  • 892 posts
Posted 14 February 2008 - 11:00 am
Measure the bearing and buy SKF.
I'm sure you'll find a local dealer on their webpage.
