Rear wheel bearings
73 replies to this topic
#1 fluteplayer
fluteplayer
  • 68 posts
Posted 11 December 2006 - 07:03 pm
Can anyone supply the bearing numbers for the three rear wheel bearings for a 900?
None of the after-market parts books list em, and , although I thought I had found someone who knew what they were doing, I found myself with a rear wheel out, and bearings for an 850 (I assume) in my hand. Rather frustrating ranting.gif
Anyone able to help?
Standard after market bearing numbers would be great, I have the Yamaha numbers, but they are pretty expensive.
Fluteplayer
(\__/)
(")0(")
This is Bunny. Copy and paste Bunny into your signature to help her gain world domination
#2 ROB1
ROB1
  • 539 posts
Posted 11 December 2006 - 07:58 pm
are you by anychance the flutplayer off little britain?
#3 PICARD
  • 1,785 posts
Posted 11 December 2006 - 08:01 pm
QUOTE(ROB1 @ Mon 11th Dec 2006, 09:43 PM) <{POST_SNAPBACK}>
maybe he is, maybe he isn't, no doubt he'll answer you with a riddle !!!
#4 fluteplayer
fluteplayer
  • 68 posts
Posted 11 December 2006 - 09:42 pm
QUOTE(ROB1 @ Mon 11th Dec 2006, 07:43 PM) <{POST_SNAPBACK}>
Riddle me no riddles, and I will tell you no lies!!!
Fluteplayer
(not gay BTW!)
(\__/)
(")0(")
#5 Doc
Doc
  • 231 posts
Posted 11 December 2006 - 09:55 pm
Have you tried the JBX Tech pages? You should find the part Number there, assuming your 2003 model is the same as the 2004.
http://jbx9.free.fr/TDM/index.php?show=_text&page=DL00 ://http://jbx9.free.fr/TDM/index.php?s...;page=DL00
#6 PICARD
  • 1,785 posts
Posted 11 December 2006 - 09:57 pm
no, that'd be picolo player !!
what kinda mileage did you get out of the original wheel bearing?
there's a place i use where, if you take a bearing or seal / o ring in, they'll measure and match...dead cheap and never got it wrong. may be the way to go. (have even been known to give away the odd o ring etc if i mention biking!!)
#7 robsue20
robsue20
  • 147 posts
Posted 11 December 2006 - 11:14 pm
just take all the numbers off the edge of the bearing ,and take them too your local bearing stockist, they should be able too match them.(if they end in -1,that means they have a seal on one side,so you can buy-2 and take a seal off on one side)hope this helps.
#8 fluteplayer
fluteplayer
  • 68 posts
Posted 12 December 2006 - 07:15 am
QUOTE(robsue20 @ Mon 11th Dec 2006, 10:59 PM) <{POST_SNAPBACK}>
Trouble is the bearings are in the wheel, and the wheel is on the bike, and the bike is my only means of transport to go and get more bearings!
Catch 22 I need to get em in advance really!
Fluteplayer
QUOTE(Doc @ Mon 11th Dec 2006, 09:40 PM) <{POST_SNAPBACK}>
TheYamaha fiches only show the Yamaha part numbers, and I kinda begrudge paying 70 odd quid for a 15 quid set of bearings!!
fluteplayer
(\__/)
(")0(")
#9 robsue20
robsue20
  • 147 posts
Posted 12 December 2006 - 08:12 am
not got any friends then?
#10 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 12 December 2006 - 12:49 pm
whats the yamaha part no's then
usually the bearing code is embedded into the yamaha part no somewhere
ie if it were a 6204 bearing, then those numbers would be somewhere in the yamaha part no.
My bike shop always look at the yamaha part number then comes up with the std bearing number this way
#11 Landy
Landy
  • 1,387 posts
Posted 12 December 2006 - 01:21 pm
The two wheel bearings are 93306-07806-00
and the drive assembly one is 93306-20644-00
Can you pick the bones out of that.
[attachment=218:attachment]
#12 David H
David H
  • 539 posts
Posted 12 December 2006 - 07:18 pm
Probably no use whatsoever................
http://shop.wemoto.c...earings&flag=19
#13 fluteplayer
fluteplayer
  • 68 posts
Posted 12 December 2006 - 07:35 pm
QUOTE(David H @ Tue 12th Dec 2006, 07:03 PM) <{POST_SNAPBACK}>
Hee, pretty obscure!!
As a web designer - it made my eyes bleed y' bstrd ;-)
Fluteplayer
(\__/)
(")0(")
#14 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 12 December 2006 - 08:20 pm
QUOTE(Andy K @ Tue 12th Dec 2006, 01:06 PM) <{POST_SNAPBACK}>
Well, going on the previous way they are coded the wheel bearings would be 6078's and the cush drive bearing would be 6206.
Never heard of 6078, but 6206 is a std sized bearing freely available from your local friendly bearing stockist.
Maybe Yamaha have used a 'special' to force you to buy them from Yamaha - they did it with the shock linkage on my moto-xer. The one bearing was a total special that was only available in Japan. Bastards.
Just looked at a 850 parts list and the sprocket carrier bearing is decoded as 6372, but the bearing is actually a 6322, so seems Yamaha don't always play ball.
If you can wait til Sat, I can go down my local shop and see if they know what they are.
Edited by GuyGraham, 12 December 2006 - 08:24 pm.
#15 fluteplayer
fluteplayer
  • 68 posts
Posted 13 December 2006 - 05:39 pm
QUOTE(GuyGraham @ Tue 12th Dec 2006, 08:05 PM) <{POST_SNAPBACK}>
If you have time, that would be great - I seems to be hitting dead ends everywhere else!!
Fluteplayer
(\__/)
(")0(")
#16 dapleb
  • 18,376 posts
Posted 13 December 2006 - 08:10 pm
You could always try phoning Yamaha, and ask.
#17 fluteplayer
fluteplayer
  • 68 posts
Posted 13 December 2006 - 08:29 pm
QUOTE(dapleb @ Wed 13th Dec 2006, 07:55 PM) <{POST_SNAPBACK}>
Hee hee
I am sure that would go down very well
"Can you give me the after market part numbers for TDM wheel bearings!!"
Dont fink so ;-)
Fluteplayer
(\__/)
(")0(")
#18 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 18 December 2006 - 07:26 pm
I will do it next w/end - no excuses this time
#19 fluteplayer
fluteplayer
  • 68 posts
Posted 19 December 2006 - 07:51 am
QUOTE(GuyGraham @ Mon 18th Dec 2006, 07:11 PM) <{POST_SNAPBACK}>
No worries, and dont bust a gut, it's not that urgent, I aint in a hurry to take my back wheel out again in the pouring rain, although it will need doing eventually.
Fluteplayer
(\__/)
(")0(")
#20 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 23 December 2006 - 04:03 pm
Sorry Fluteplayer - local bike shop said they are specials only available from Yamaha at present
You could try taking the measurements to a local bearing factor to see if they can help, as Yamaha sure ain't making the bearings themselves, they are sourcing them from somewhere in Japan.
I did this when trying to avoid paying Yamaha's rip off prices for the shock linkage bearings on my YZ250. It turned out 1 of them was a total special that was only available in Japan. They said they had a rep in Japan and would contact him to see if he could source it there, but I gave in and paid Yamaha's price. I thought that by the time shipping had been added, plus the wait I might have, it was better to get the Yam bearing as it was holding up my rebuild.
I hate it when they do this - robbin' bastards.
Its the same with oil seals - they're std of the shelf parts which are also available from your freindly local bearing stockist
