Rear Suspension Bush, Let This Be A Lesson To You!
113 replies to this topic
#21 dablik
Posted 08 October 2014 - 08:21 am
Cheers Lee, need to have a ponder about this and when it can get done......
#22 m0rt
m0rt
  • 97 posts
Posted 08 October 2014 - 12:23 pm
mmm. Not a pleasant thing to come across.
So this has now got me thinking I had better grease mine. Is there a schematic or a methodology for greasing the suspension linkage? Or, if no issues, this is a fairly straight forward job?
Edited by m0rt, 08 October 2014 - 12:23 pm.
#23 leehenty
  • 5,325 posts
Posted 08 October 2014 - 08:47 pm
straightforward job. Support wheel undo the bolts, push out the sleeves apply grease to the needle rollers put them back. The only one that might give trouble is the bottom one attached to the frame.
#24 m0rt
m0rt
  • 97 posts
Posted 09 October 2014 - 06:02 am
Cheers.
Anyone know the torque values of those bolts when doing back up? (I really need to get a manual :/ )
#25 m0rt
m0rt
  • 97 posts
Posted 09 October 2014 - 07:04 am
Ok - so this is where I am at.
All bolts removed, thought the swingarm dogbone side is now loose but haven't removed yet. The two bushes that we can get to are fine, the rollers seem fine.
I now know what everyone else has been saying! How do I even start to remove the frame side bush?? I can't get a purchase on it, the section where it mates with the t'other side is to smooth go get any purchase on...
The condition of everything is ok other than a little bit of surface rust on the steel bolt and in the bush.
Currently I have left it with some ACF 50 on the outer side for the hell of it before I try and see how to get a purchase to exert some force....
#26 m0rt
m0rt
  • 97 posts
Posted 09 October 2014 - 08:21 am
OK. Sorry to hijack this as a blog.
I has Rawl bolts.
M6 to be precise....
Going in...
#27 dablik
Posted 09 October 2014 - 08:29 am
I has Rawl bolts.
Going in...
You might be fine m0rt, does'nt seem to be very many effected with the problem, well till maybe now when they all go check  :)
#28 Studley Ramrod
Posted 09 October 2014 - 08:47 am
Cheers.
You can download a copy of the service manual from JBX's site. :)  You'll need to register before you can download, but it's free.
http://www.jbx9.t15.org/
#29 m0rt
m0rt
  • 97 posts
Posted 09 October 2014 - 09:24 am
Cheers for the comments guys.
I have it out.
M6 Rawl bolt, smoothed head down with bolt in drill and file.
TIghten up in hole, use 20mm ID 2mm thick washers and I have it. I am just cleaning up the bush to see if it is ok.
Edited by m0rt, 09 October 2014 - 11:27 am.
#30 m0rt
m0rt
  • 97 posts
Posted 09 October 2014 - 09:42 am
Autosol whilst still in drill polished it a treat.
#31 m0rt
m0rt
  • 97 posts
Posted 09 October 2014 - 10:58 am
Wahey!
I need to check the torque to see what my "Bloody Tight" equates to, but apart from about 1 hour to go get the Rawl bolt and use it to extract, job was fairly straight forward.
This was on a '07 with 16k on the clock and that was as awkward as I would want it to be. So if you HAVEN'T done this yet and you don't know the provenance, I suggest you start thinking about it. If I had to commute and especially through the winter, I can guarantee this would have been a lot worse.
PS - if the eagle-eyed amongst you spot something not quite right with the boike, it is deliberate because it is coming off right now.
Edited by m0rt, 09 October 2014 - 11:00 am.
#32 Rallyist
Posted 09 October 2014 - 12:46 pm
should look after yer nuts. :huh:
#33 m0rt
m0rt
  • 97 posts
Posted 09 October 2014 - 12:57 pm
What nuts?
#34 leehenty
  • 5,325 posts
Posted 09 October 2014 - 05:40 pm
well done M0rt, yours was reasonably free. ChrisR's was in there tighter than a nuns chuff.
All my efforts at pulling it out with expanding tools failed.
Hope you was generous with the grease putting it back.
#35 ramo
ramo
  • 1,194 posts
Posted 09 October 2014 - 06:31 pm
are the nuts missing from the centre stand bolts? (don't know I've not got one :rolleyes: )
anyway re-greased my bush/bearings today, so hope fully a bit less to fail on me  :good:
some good info on this site eh  :signthankspin:
#36 leehenty
  • 5,325 posts
Posted 09 October 2014 - 07:17 pm
um them centre stand pivot bolts usually have nyloc nuts on them
#37 m0rt
m0rt
  • 97 posts
Posted 09 October 2014 - 07:44 pm
Seems the eagle eyed on a pic aren't so eagle eyed on the text below the pic:
"PS - if the eagle-eyed amongst you spot something not quite right with the boike, it is deliberate because it is coming off right now."
#38 muddy
Posted 10 October 2014 - 12:18 pm
had a look at the suspension linkage while I washed the bike down. Looks to be plenty of chain oil fling there to coat the general area, so I hope that's protecting it.
#39 dablik
Posted 10 October 2014 - 05:06 pm
I certainly would'nt bank on it, mines also had a scottoiler since before i owned it with, plenty of fling and that collar is stuck fast mate, a visual inspection wont cut it.
#40 gilly
gilly
  • 61 posts
Posted 14 November 2014 - 08:42 pm
Posted 09 October 2014 - 09:24 AM
I have it out.
Sorry about this and hope doesn,t sound too daft but how ? and what are the 20mm washers for?
I have never done this work on the bike before and wish to have ago
gilly
ps did the bush just push back in ? again sorry for asking daft questions
Edited by gilly, 14 November 2014 - 08:47 pm.
A shin is a device for finding furniture in a dark room
A sure cure for seasickness is to sit under a tree
