Tdm900 Rear Suspension Linkage Service
43 replies to this topic
#21 muddy
Posted 29 October 2016 - 12:21 pm
I'm sure we could sort summat out. :good:   Might help us hard working admins if you could stick with the same topic instead of posting up a noo wan on the same subject, please. :)  Also makes finding contributions much easier.
Sorted now. :good:
I've been meaning to say and this seems a good time to do so. There is a problem with the trend to start these mega threads, as in 'What Did You Do To Your ******Today' in that good information gets swallowed up in them. They almost become a forum within a forum, but without the orderliness. Same with Facebook posts. A forum is a resource as much as it's a hangout.
#22 dapleb
  • 18,376 posts
Posted 29 October 2016 - 12:36 pm
Couldn't agree more muddy.
#23 Riggers
Riggers
  • 531 posts
Posted 29 October 2016 - 03:05 pm
Sorted now. :good:
Many thanks Studley, that's absolutely fabulous!
And I'll consider myself suitably and severely reprimanded for doubling up on the topic!
Cheers mate,
Riggers
#24 hyde900
hyde900
  • 9 posts
Posted 08 January 2017 - 02:36 pm
I've just done linkage service to my '05. Quite easy job as none of the parts were stuck.
But I found that shock absorber has eaten nasty looking grooves on the aluminium thingy. Probably the shock absorber has been tightened too tight.
I could not find torque values for linkage bolts, except for connecting arms 49 Nm.  :help:
EDIT: Torque values: for shock bolt 40 Nm, front frame bolt 40 Nm, connecting arms 49 Nm.
Edited by hyde900, 08 January 2017 - 02:58 pm.
#25 Matlock
Posted 08 January 2017 - 05:15 pm
I'd check you're not missing a spacer there, or the wrong one is fitted. There shouldn't be any contact between those two bits.
#26 hyde900
hyde900
  • 9 posts
Posted 08 January 2017 - 06:32 pm
I thought too that there should be a spacer between shock mount and arm block to avoid contact. But the exploded view drawing does not have any spacer (part 20 is oil seal).
#27 Riggers
Riggers
  • 531 posts
Posted 10 January 2017 - 01:59 pm
Could it be that you have the wrong pin fitted? (31 in your diagram). No matter how hard the nut and bolt are tightened there should be no contact between the two components. If the shocker is grinding on the aluminium rocker arm there is something wrong.  :unsure2:
Riggers.
#28 adamg
adamg
  • 116 posts
Posted 18 January 2017 - 06:28 pm
Heat sorted mine too. Good work!
#29 Robk321
Robk321
  • 28 posts
Posted 05 February 2020 - 07:25 pm
Hi all,
Been trying to service grease these links and was quite positive about the rawlbolt method.
Just bought some m6 which are the smallest that you can get as qfar as I can see.
Trouble is the frame hole is Bush is smaller than the other two which just pushed out.
The m6 doesn't go anywhere near fitting in the hole.
Am I missing something obvious here?
I am sure it will come out if I can just get some purchase on it as it was greased about 10k ago.
BBloody ridiculous piece of design this 😔
#30 steve27bha
  • 797 posts
Posted 06 February 2020 - 12:03 am
You need the correct type of Rawlbolt, the tubular one not the cast.
See pix and comment in this post by me back in 2014:-
http://www.carpe-tdm...=29452&p=291710
I've got other posts later in that thread on page 2 illustrating another type of expanding insert, and a fix for the problem with the Rawlbolt.
Edited by steve27bha, 06 February 2020 - 12:13 am.
#31 Robk321
Robk321
  • 28 posts
Posted 06 February 2020 - 03:16 pm
Thanks Steve, will try and source one.
Frustating thing is this would be a 1 hr job if you could just push it out from the right hand side!
#32 Robk321
Robk321
  • 28 posts
Posted 23 February 2020 - 08:11 pm
Nah, can't get the bugger out. Tried all sorts of bolts just can't get ay purchase on the inside of the Bush. Whatever I use just pulls out. Must mean that it is really stuck.
Very frustrating, just going to have to reassemble and hope for the best.
Might try the easy out tap method next first though..
#33 dablik
  • 10,892 posts
Posted 24 February 2020 - 11:55 am
Careful Rob if it's very stuck you'll chance breaking the swinger, looks like you may need to grind that fecker out..
#34 steve27bha
  • 797 posts
Posted 24 February 2020 - 04:49 pm
To be more accurate you stand the chance of breaking off one or both of the lugs on the frame. That's really serious whereas swingarms are easily replaced.
You need to read all the posts, there are several threads with relevant content IIRC.
#35 AliG
Posted 27 February 2020 - 02:20 am
Hi all,
I got some from Toolstation that fitted perfectly (the first one from B&Q wouldn't fit). PM me your name and address and I'll stick one in the post to you. I had to buy a pack of ten so have plenty. I coated liberally with plusgas, applied some heat with a heat gun and then gently tapped the end of the rawlbolt with a bolt from the rhs and it just eased out. Ali
#36 Rallyist
Posted 27 February 2020 - 08:09 am
Ali PM sent. :good: :good:
#37 Robk321
Robk321
  • 28 posts
Posted 29 February 2020 - 03:22 pm
Hi guys, thanks for all the tips and offers of help had one last go today with a sleeve anchor from selco, plenty of wd 40 and heat from the wifes hairdryer.
It is out!! Had to gently tap from the blind side but once it was moving all was good. Bit of corrosion on where it passes through the left lug. Any longer and i reckon it would have seized up totally.
Phew.... very pleased with myself, time for a beer 😁
Edited by Robk321, 29 February 2020 - 03:23 pm.
#38 dapleb
  • 18,376 posts
Posted 29 February 2020 - 03:27 pm
Good skills wob.
#39 Studley Ramrod
Posted 29 February 2020 - 07:42 pm
Well done :drinks:
#40 Hombre
Hombre
  • 449 posts
Posted 05 July 2021 - 09:28 pm
New rear tyre time and a chance to clean up and service the linkage.
All done bar the usual suspect
IMG Pvt
Tackled it with this 10mm cap head set-up + a lot of heat
IMG xtractr
Nothing moved, nada, zilch. :isurrender:
It is supposed to be tight so that it does not rotate so that the bearing does.  The bearing is smooth in action.
Will have super plan in place for next tyre change time. :putemup:
