Tdm900 Rear Suspension Linkage Service
43 replies to this topic
#1 Riggers
Riggers
  • 531 posts
Posted 17 October 2016 - 01:23 pm
Hi guys,
I thought it's about time I overhauled the rear linkage on my 900. I'm sure somewhere on the forum is a step by step guide to the job, together with a few tips at removing that pesky blind ended frame mount bearing.
Snag is I can't for the life of me find it despite all sorts of searches.
Any chance anyone can put the 'link' up for me (assuming it's still around somewhere).
Many thanks all.
Riggers.
#2 dablik
  • 10,892 posts
Posted 17 October 2016 - 03:18 pm
Here's one of em Riggers
#3 Riggers
Riggers
  • 531 posts
Posted 17 October 2016 - 04:22 pm
Thanks dablik. I'm sure someone posted up showing how you can use a wall bolt to remove the said pesky bearing. :-)
#4 Studley Ramrod
Posted 17 October 2016 - 04:29 pm
Said linkydink shows pics of using a rawlbolt to remove the bush.  A few pages on from 1st post.
http://www.carpe-tdm...=30735&p=308017
And anudder wan.
http://www.carpe-tdm...=29452&p=291710
#5 Riggers
Riggers
  • 531 posts
Posted 17 October 2016 - 05:06 pm
And anudder wan.
Thanks mate. Spot on!
#6 Riggers
Riggers
  • 531 posts
Posted 25 October 2016 - 02:35 pm
Attached File  IMG_36161.JPG   102.64KB   2 downloadsHi again guys. Well I'm in the middle of the removing the 'pesky pin' from the rear suspension linkage. All my reading on the subject suggests an M6 rawl bolt for the job but as the pic shows it seems too larger diameter by maybe one or even two mm.
Have I missed something here or have I fallen into a trap known to all except me? :-(
Any ideas guys?
This is what I bought...
Edited by Riggers, 25 October 2016 - 03:40 pm.
#7 steve27bha
  • 797 posts
Posted 26 October 2016 - 02:21 pm
In post #14 of the second link given by Studley I commented that one needs the tubular version of the Rawlbolt, not the cast one. There is even a pic of what I used.
#8 Riggers
Riggers
  • 531 posts
Posted 26 October 2016 - 04:02 pm
Yep thanks Steve on re-reading I noticed that, and managed to get hold of one today. Unfortunately I can't get it to grip the inside of the pin despite my best efforts. I'm now waiting for  another rawl bolt to arrive from e.bay and keeping my fingers crossed!
Thanks for your reply mate.
#9 tr7dan
tr7dan
  • 120 posts
Posted 27 October 2016 - 11:51 am
 a bit more info....
#10 Riggers
Riggers
  • 531 posts
Posted 27 October 2016 - 04:28 pm
Many thanks for that mate. I'll give your method a go as I can't get a standard rawl bolt to grip the inside of the pin.  :good:
#11 Riggers
Riggers
  • 531 posts
Posted 28 October 2016 - 05:39 pm
With thanks to all on the forum who have contributed to this topic, by using a combination of everyone's methods I managed to get the rear suspension 'blind pin' removed. And a good thing I did too as it was just starting to corrode away merrily as it nested tightly in the frame lug.
I eventually got a suitable 10mm rawl bolt from B & Q, but couldn't get one long enough to use as a puller. So I tightened it up really well inside the pin and then applied some gentle heat to the left side lug (no need to heat the right hand side one as the pin doesn't enter it).
After getting the lug reasonably hot I used a screwdriver as a drift to tap the pin out from the right hand side of the bike. By using a screw driver I was able to carefully only tap the bolt of the rawl bolt and not the sleeve, and thus the more I tapped the tighter it became lodged inside the pin.
I kept up a combination of heat and tapping, heat and tapping, ever conscious of the horror stories of breaking off the frame lug, and eventually out it came.
The pin was a bit corroded, but by far the worst was the one at the top of the dog bones.
Here are a few pictures of the job in progress.
 Attached File  IMG_36341.JPG   115.27KB   6 downloads
The pin starting to corrode.
Attached File  IMG_36351.JPG   83.81KB   6 downloads
The rawl bolt came out without trouble
Attached File  IMG_36391.JPG   123.85KB   4 downloads
The top dog bone bolt was the worst corroded.
Attached File  IMG_36421.JPG   110.34KB   12 downloads
The stupid design means the pin doesn't locate into the right hand lug at all!
Attached File  IMG_36451.JPG   81.03KB   8 downloads
Job done!
Edited by Riggers, 28 October 2016 - 05:42 pm.
#12 Catteeclan
  • 2,561 posts
Posted 28 October 2016 - 06:06 pm
:good: Well done. I'm sure this will assist others, prob inc me as I haven't done mine yet.
#13 Studley Ramrod
Posted 28 October 2016 - 06:08 pm
Nice job Riggers. :good:
#14 Latestarter
Latestarter
  • 676 posts
Posted 28 October 2016 - 06:51 pm
I know myself it's a pig of a job and I was just drinking coffee watching Mr Henty when he done mine earlier this year at his place
#15 Riggers
Riggers
  • 531 posts
Posted 28 October 2016 - 07:04 pm
Lucky you!  :)
#16 AliG
Posted 28 October 2016 - 08:29 pm
The trick now is that it has been done, to do once a year and it is literally a 20 minute to half an hour job. Do one bolt/sleeve at a time, coat liberally in moly grease and put back on..
Ali
#17 dmmsta
dmmsta
  • 3,627 posts
Posted 28 October 2016 - 08:39 pm
really should do mine now that there's photo's, and a large tin of Moly in the shed!
#18 Riggers
Riggers
  • 531 posts
Posted 29 October 2016 - 09:12 am
I think it would be a good idea if the moderator (dableb?) would pull all the different threads and piccies together and put them in Knowledge Base, as it's such an important maintenance task. Currently it's a bit hit and miss when trying to find all the contributions.
If a few agree I'll put a request in.........
Riggers.
#19 dmmsta
dmmsta
  • 3,627 posts
Posted 29 October 2016 - 10:40 am
:good:
#20 Studley Ramrod
Posted 29 October 2016 - 10:48 am
Riggers.
I'm sure we could sort summat out. :good:   Might help us hard working admins if you could stick with the same topic instead of posting up a noo wan on the same subject, please. :)  Also makes finding contributions much easier.
Sorted now. :good:
