Loose gearbox Sprockets
27 replies to this topic
#21 dapleb
  • 18,399 posts
Posted 22 November 2007 - 10:30 pm
mkI has no shoulder. http://www.carpe-tdm...?showtopic=4421 , see GG's post and click linky dink.
#22 tdm850rider
Posted 22 November 2007 - 10:32 pm
Just a thought... could the 'reverse torque' from downshifting (to slow the bike) contribute to sprocket loosening?
Seems a possibility. What do you think?
#23 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 22 November 2007 - 10:39 pm
QUOTE(tdm850rider @ Thu 22nd Nov 2007, 10:17 PM) <{POST_SNAPBACK}>
only if you are drowning and looking for a straw!
currently owned ....
#24 lemonentrails
lemonentrails
  • 149 posts
Posted 22 November 2007 - 11:18 pm
a very good point and quite likely...
as for the tab washer ,its there as much to stop the nut coming all the way off as it is to stop the nut loosening, they do allow the nut to slacken in my experience,.Thats why i always use loctite.
Having looked at a new shaft closely I think the 2nd gear bush thing is a red herring. This bush seems to be fixed to the shaft and doesnt move ,if so how can it wear to allow lateral movement? also the oil seal spacer doesnt move or come loose which it would have to do to allow the sprocket to wobble without slackening the nut .
its the nut that comes loose for whatever reason so just loctite the bugger.
Just my observations and opinion.
Just looking at the parts list again , it sure does look like there's a step/shoulder in the shaft before the 2nd gear bush . its a bit blurred but its there IMO. The unobtainable bearing must fit up against this shoulder making everyting nice and solid
Edited by lemonentrails, 23 November 2007 - 01:12 am.
Mk1black ()60+k,micron system, nice but not naughty,k&n,dynojet stage 1. port job, polished head and pistons . lowered h/bars.lowered yokes 7mm ish ,Avon Storms ,top bannanas!EBC DISCs and damned fine they are too!!!..rust an all...oh and a cracked frame.Now welded up and so far so good .....Mk1 with squire sidecar sidecar,metmachex deep brace swing arm, suzuki 6" rim &car tyre , whole plot lowered a bit.sidecar heater to keep madam cosy! LL forks coming to a bike near me soon.
#25 Readmarx
Readmarx
  • 461 posts
Posted 23 November 2007 - 08:50 am
Interesting. I'll check my own sprocket next week. my front is an aftermatket j&t and I don't remember there being a step on it and I've been using aftermarket sprockets for a few years and have had the nuts coming loose. what stormy says about spacing out the sprocket makes sense to me entirely. what depth of spacing is necessary? I have a couple of old nut washers I could use.
mother nature rides a biker
#26 wicklamulla
Posted 23 November 2007 - 10:04 am
i have tried using an aftermarket sprocket afore and it was too thick and would not permit me to fit a locking tab washer so i sent it back to the suplier and they sent me a genuine yam one instead, problem solved. will post a pic of a fr. sprocket laters xxxxxxxxxxx
#27 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 23 November 2007 - 01:48 pm
QUOTE(lemonentrails @ Thu 22nd Nov 2007, 11:03 PM) <{POST_SNAPBACK}>
On the shaft that I have been fettling ......... (hang on, think I'll rephrase that!) ....
On the shaft from my bikes' gearbox, there is no shoulder. About one third distance from the sprocket end, there is a shoulder where a locating washer sits to make a shoulder for the gear wheel to butt up against. Once the gearwheel is fitted, together with its inner bearing shell, the main ball bearing is then pressed up against the gearwheel hub, and it contacts at the inner race diameter. Then the oil seal spacer is fitted (over the top of the "o" ring) and that butts up against the outside of the main bearings' inner race diameter.
Then you'd fit a correct sprocket, a new tab washer and ideally a new nut.
Then you'd go fer a ride.
Edited by stormy, 23 November 2007 - 01:51 pm.
#28 dandywarhol
Posted 23 November 2007 - 06:26 pm
QUOTE(stormy @ Fri 23rd Nov 2007, 01:33 PM) <{POST_SNAPBACK}>
