Fuel Injection setting
60 replies to this topic
#41 Toraneko
Toraneko
  • 364 posts
Posted 12 November 2008 - 10:19 pm
QUOTE(athula wilson @ Wed 22nd Oct 2008, 11:45 PM) <{POST_SNAPBACK}>
There is an operating temperature difference between C1 and C2. C2 runs hotter than the C1.
It is nothing to do with the Fuel injection or carb issue, whatever setting you tries, the C2 will run hotter than the C1 and it is to do with the 270 crank. I have had it with a TRX850 and the now with the 900.
Is quite clear from the uneven discoloring of the two header pipes and I had a laser temperature gauge pointed at the headers that quite clearly shown this.
OK. so what did your laser temp' gauge tell you the temperatures for C1 & C2 were? I for one am interested to know. waiting.gif
BTW, so far both my header pipes look identical in colour, but she only has 3000k on the clock. C1=14 C2=16
cheers, Shane from Tassie
#42 alloypiston
alloypiston
  • 123 posts
Posted 13 November 2008 - 01:24 pm
Give it a few more miles,
a
Edited by athula wilson, 13 November 2008 - 01:25 pm.
TDM 900
XJR1300SP
SRX6
SRX4
TZR250 Reverse Cylinder
YX600 Radian
BROS 650
SDR 200
#43 GuyM
GuyM
  • 12 posts
Posted 04 December 2008 - 11:45 pm
I had been a bit puzzled by fuel economy on my TDM900 and I have also had extra baffles fitted to the after market exhaust to quieten it down a bit. My typical short spurts of riding through the hills at 120-150 kmh usually result in the fuel level warning flash at about 300 km. So I checked the CO settings and found C1=22 C2=17 so I dropped C1 back to 15. I went for a ride yesterday which was entirely flat freeway riding at 80-110 kmh. I did 250 km and still have half a tank of fuel left going by the bar indicators. Do CO settings have much effect on fuel consumption or is this more an indication of the effect the right hand has?
#44 alloypiston
alloypiston
  • 123 posts
Posted 05 December 2008 - 09:13 am
[/quote]
My feeling is that you speed difference (120-150 & 80-120) is what is making the difference, not the CO setting. I have not seen any differenc ein engine operation when altering CO setting, lets say 10 units up or down,
TDM 900
XJR1300SP
SRX6
SRX4
YX600 Radian
BROS 650
SDR 200
#45 alloypiston
alloypiston
  • 123 posts
Posted 05 December 2008 - 09:18 am
QUOTE(athula wilson @ Fri 5th Dec 2008, 09:13 AM) <{POST_SNAPBACK}>
TDM 900
XJR1300SP
SRX6
SRX4
YX600 Radian
BROS 650
SDR 200
#46 allan
allan
  • 178 posts
Posted 07 December 2008 - 11:04 am
Had TPS done and noticed no difference still very jerky between 2-4k ,then following instruction from the site set CO to c1=1 and c2=6(from c1=1,c2=-124) it now runs very smoothly,so it really did make a big difference,many thanks to you all.
#47 robelst
robelst
  • 1,844 posts
Posted 07 December 2008 - 02:29 pm
Silly me had always been thinking that the clever FI electronics were there to make life easier in sorting out the best fueling conditions rolleyes.gif
That was not a banana, Dougal
#48 AussieTeeDeeMmm
AussieTeeDeeMmm
  • 56 posts
Posted 08 December 2008 - 10:37 am
Hi all, just picked up my new to me 2003 TDM900 with 12,000k and first did the airbox flap mod #2 was easy and tonight checked the CO and found C1 at -7 and C2 at 124 so i have altered to C1 10 and C2 15 and tomorrow we shall see how she goes.
Thanks for all the info and look forward to catching up again.
Rick
#49 dandywarhol
Posted 08 December 2008 - 02:57 pm
I've seen it making a difference when hooked up to a gas analyser rolleyes.gif
I've also seen mine jump to 126 for no apparant reason other than the battery voltage being too low to start the engine. Thats when the clock resets to 1.00 pm - I wonder if the ECU resets itself at the same time unsure.gif
#50 Guest_trevini_*
Guest_trevini_*
Posted 08 December 2008 - 03:51 pm
I set mine up with a co meter a while back. Runs smooth as silk now. No jerky hesitation etc. I even undid the airbox mod as it's not necessary now. Before adjustment, mine was set at 8 and 12. After adjustment with co set at spot on 3.5% ended up with -9 and -7. Definitely the way to go. Should have done it years ago! The economy has always been good, but now regularly returns 225-230 before reserve unless riding it like a total madman and then it drops to about 210.
Edited by trevini, 08 December 2008 - 03:52 pm.
#51 TDMick
Posted 08 December 2008 - 04:50 pm
QUOTE(robelst @ Sun 7th Dec 2008, 02:29 PM) <{POST_SNAPBACK}>
Mick
#52 dandywarhol
Posted 08 December 2008 - 06:32 pm
QUOTE(trevini @ Mon 8th Dec 2008, 03:51 PM) <{POST_SNAPBACK}>
Hi Trevini
Did you sample yours before the catalizers? And did you disable the air correction valve? Are you using stock exhausts? rolleyes.gif
#53 Guest_trevini_*
Guest_trevini_*
Posted 08 December 2008 - 07:43 pm
Sampled mine with the probe in which ever exhaust I was setting with the air valve blocked off (as per w/shop manual). I had Remus grand prix cans fitted, so no cats. I didn't bring one cylinder down first and then the other in one big jump. I made gradual small adjustments alternating between the cylinders until I got to the desired levels.
I also set up with no airbox mod and power commander disconnected/ removed. My pc has developed a fault where it will misfire after about 20 mins riding, whichever map is installed, however I ride, hence setting the system up properly without it. Switch it off for about 30 secs restart and then the whole process repeats itself. Tried it again after co had been set up and it still did it, so I'm guessing something electronic is breaking down internally. Since removing it the bike hasn't missed a beat. PC is now in the bin and having ridden the bike set up properly, I don't think I'd bother with the expense of another. Yes it did go better in terms of throttle response, but not that much really. What it demonstrated was how badly set up the bike was by the main dealer when they did the servicing for the first 18000 miles!
#54 dandywarhol
Posted 09 December 2008 - 05:58 pm
Cheers for the info - I did the same with my CCC cans and also ended up in the minus figures with the P Commander fitted.
#55 Guest_trevini_*
Guest_trevini_*
Posted 09 December 2008 - 06:02 pm
That's interesting. What did yours end up set at and did you try without pc connected?
#56 Toraneko
Toraneko
  • 364 posts
Posted 24 December 2008 - 08:35 am
QUOTE(athula wilson @ Fri 14th Nov 2008, 12:24 AM) <{POST_SNAPBACK}>
a
#57 Dante
Dante
  • 83 posts
Posted 25 December 2008 - 08:55 pm
each TDM needs a different setting...you must visit the service guys to make a check for the right CO1 and CO2's
TDM 900 '05 - Diamond Black
IPB Image
#58 Stratman
Stratman
  • 312 posts
Posted 13 September 2010 - 08:21 am
Hi. When Trevini refers to disabling the air valve - I can see what I think is meant by this in the Service Manual (page 7-31?) but not sure how I would disable this. I have a friendly MOT tester and want to try setting the CO in the same way.
Edited by Stratman, 13 September 2010 - 08:28 am.
Two bikes, still only four cylinders!
#59 Kurtjohnson
Kurtjohnson
  • 1 posts
Posted 19 June 2018 - 12:04 am
Hi can any tell me what is the factory setting for the TDM 900 injectores when I brought my bike it was not set correctly thanks in advance
#60 JBX
Posted 19 June 2018 - 01:14 am
Look up two posts above yours : #57...  ;)
