Tdm Skips Under Load
258 replies to this topic
#101 Studley Ramrod
Posted 18 January 2013 - 06:52 pm
eh wa ?
#102 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 18 January 2013 - 07:17 pm
eh wa ?
I was concerned that there would be too great a language divide between here and there.
But you could always use Google Translate.
"Bonjour Monsieur Singe. Aimez-vous le fromage? Ah! Bon. Je voudrais une boite de vitesse pour ma moto"
Edited by TYREDNGRUMPEE, 19 January 2013 - 10:14 am.
#103 RolfieB
RolfieB
  • 1,069 posts
Posted 18 January 2013 - 07:26 pm
I've used them a few times & have always found the service excellent.
Now I just fly everywhere.
Gone to new owner.
Black Mk2a
#104 alexk243
alexk243
  • 230 posts
Posted 18 January 2013 - 11:44 pm
I contacted the online seller for shipping cost using google translator and I heard back from the ebay seller and he does not have a selector barrel for the gearbox.
1992 Yamaha TDM 850
2006 BMW F650GS
#105 tdm850rider
Posted 19 January 2013 - 12:36 am
Still if you could get everything you need except the selector barrel... that is only 1 new bit you need to buy.
#106 alexk243
alexk243
  • 230 posts
Posted 19 January 2013 - 03:55 am
Would it hurt to mix and match with used parts thought (used gears/shifter forks from one bike and a used selector barrel from another)?
1992 Yamaha TDM 850
2006 BMW F650GS
#107 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 19 January 2013 - 10:26 am
I would not advise this, unless you can be sure in your own mind that what you have is serviceable and are prepared to discover that the problem still exists after reassembly..
The selector barrel sits in the middle of the apparent symptoms your gearbox is experiencing.
If the ebay example is in good order then it is just...........
like Thomas says, only one part to buy.
(Can't believe they haven't kept it together with the rest of the box though. That is shoddy. Muppets!) :locco:
To my shame, I was being flippant with the French offering that Studley highlighted.
But the above photo demonstrates that these guys know what they're talking about and reinforces my point regards replacing the unit whole to avoid any unexpected complications.
To get the best results and save overall.
Buy used, serviceable and complete.
Edited by TYREDNGRUMPEE, 19 January 2013 - 10:39 am.
#108 Studley Ramrod
Posted 19 January 2013 - 11:52 am
These guys are well respected amongst the French TDM comoonidi. :) Also, a later gearbox is better than an early one.
#109 alexk243
alexk243
  • 230 posts
Posted 19 January 2013 - 11:57 pm
So ebay is $150 shipped and the french site is $300 shipped...
1992 Yamaha TDM 850
2006 BMW F650GS
#110 alexk243
alexk243
  • 230 posts
Posted 20 January 2013 - 09:15 pm
Need some advice. I cant get the lower trans shaft out of the gearbox. I got the clutch taken off and the three torx bolts off and it slides out towards clutch side, but I cant get it off the shift fork. Any knowledge on removing this part?
1992 Yamaha TDM 850
2006 BMW F650GS
#111 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 20 January 2013 - 10:47 pm
Haynes Manual.
Remove the selector drum retainer plate.
That should allow the selector fork shafts to be removed as well as the selector drum.
Which will mean you should have no forks restricting removal.
Keep the forks on the corresponding shafts. There's some fiddly springs in there too, so make a note of where everything comes from.
#112 alexk243
alexk243
  • 230 posts
Posted 23 January 2013 - 05:22 pm
So I am kinda stuck and cant commit on purchasing the parts. The one on ebay is from a 1991 so I am afraid that will just run into the same issues as the one I have in there now. The other one is almost out of my price range. I may have to wait till I start making a bit more money to order that one.
Until then I am going to do some other work on my TDM, such as R1 fuel pump, repaint rims, replace tires, bondo and repair fairings, and a few other things. Here is that post.
Edited by alexk243, 23 January 2013 - 05:43 pm.
1992 Yamaha TDM 850
2006 BMW F650GS
#113 alexk243
alexk243
  • 230 posts
Posted 02 March 2013 - 08:46 pm
Sorry Guys, I have been gone for a while. Just started a new job and have to move very quickly into a new city and get everything organized. The job is kinda consuming my life right now and unfortunately I had to leave the TDM at home (2 hours away) in pieces. Either way I do have more money now so I want to start acquiring the pieces to make it work for this summer. I am going to try and locate a TDM/TRX trans now that is post 1993 I believe. If you guys spot any give me a heads up. I am going to try and knock out reassembly in a weekend.
1992 Yamaha TDM 850
2006 BMW F650GS
#114 alexk243
alexk243
  • 230 posts
Posted 22 January 2014 - 04:49 am
I'm Back!
As I stated before I got hired about a week or two after taking the TDM down to the gear box.... and there it sat...  I have some more free time off and I am doing ok i'm my new job so I want to try and tackle this before the summer. Does anyone have any write ups on how to put the gearbox back together or any good photos of what its suppose to look like?
Unfortunately this bike has sat in pieces for about a year now and its gonna be a pain to remember how to put back together... not idea, but the job was huge for me and unfortunately a priority over the bike.
Any help would be greatly appreciated as I am feeling lost on this one...
Also I should add: I do have all the pieced to put it back together I believe.
Edited by alexk243, 22 January 2014 - 04:49 am.
1992 Yamaha TDM 850
2006 BMW F650GS
#115 dablik
  • 10,893 posts
Posted 22 January 2014 - 10:01 am
Hi Alex, check out studleyramrod's blog, it's a mk2 gotta be similar if not the same, we also had a Merkin member living in Switzerland who posted with pics some years ago, least i'm sure it was gearbox related... er Brian !!!think his name was, that needs a search i reckon.
#116 Studley Ramrod
Posted 22 January 2014 - 11:27 am
I managed with using the Haynes manual and a copy of the mk2 service manual by Yamaha.  Re-aquaint yourself with the job by having a good read of the haynes aforehand and you should find it all slots back into the casings with little bother.  It's more a question of putting the parts back, in the correct order, than it is about technical knowledge.
Take your time, check and double check, eats lots of cake and you'll be fine. :)
Any problems just post up. :good:
EDIT:  BrianVG's mk1 rebuild photos here  http://picasaweb.goo...G/TDM850Rebuild#
#117 dapleb
  • 18,385 posts
Posted 22 January 2014 - 11:29 am
:wifgeni:
If you have any specific probs then post em ooop.
#118 alexk243
alexk243
  • 230 posts
Posted 22 January 2014 - 05:19 pm
Is there any forum or write up that goes along with this?
Also I cant find studleyramrod's blog on here.
Also I have a pdf of a 1996 TDM 850 service manual, will that work?
1992 Yamaha TDM 850
2006 BMW F650GS
#119 Studley Ramrod
Posted 22 January 2014 - 05:31 pm
Think there is a write up but I don't think it's a comprehensive one.  Will go see if I can find it.
The link is in my sig. :)  Here it is anyway.  http://www.carpe-tdm...=blog&blogid=26
Yes, '96 service manual is fine for the bottom end rebuild, it's basically the valve timing that differs.
#120 dablik
  • 10,893 posts
Posted 22 January 2014 - 06:10 pm
You da man Studs  :good:  i'm sure you and daps have a stash of them post's somewhere  :lol: with the porn maybe  ;)
