Winter Project
405 replies to this topic
#101 Studley Ramrod
Posted 05 December 2018 - 07:09 pm
What's your process for stripping and painting the engine Ian ?  As in, method fer stripping and what type of paint please. :)
#102 ramo
ramo
  • 1,189 posts
Posted 05 December 2018 - 10:09 pm
mmmm
are you thinking about removing and painting a niner enjun studs????
that rings a bell  :P
#103 Studley Ramrod
Posted 06 December 2018 - 09:12 pm
Ha, not really Steve. :lol:  I was thinking of how to paint mine once I've fixed the 3rd gear.
#104 Coxylaad
Coxylaad
  • 517 posts
Posted 10 December 2018 - 12:12 pm
The stripping and painting process is still at the think tank stage.
Got the engine out of the bike at the weekend.
daily commuting is not good for bikes! The gunge was 40mm thick in places.
I attacked it with some degreaser a wallpaper scraper and about 3 full kitchen rolls.
frame is on the way to being clean:
The engine doesn't have much in way of paint left on the front face of it. I am currently half way through getting all the crap off it.
had a quick look inside at the ported head, and managed to accidentally drop some mud down onto the back of the valves:
I will recover that later.
Now that I have made a start I think I am going to persevere with these larger throttle bodies. the majority of the port matching will be done in the throttle to head adapter. I've got them so why not.
Edited by Coxylaad, 10 December 2018 - 12:16 pm.
#105 fixitsan
  • 4,851 posts
Posted 10 December 2018 - 12:32 pm
Looking good. I'm surprised to see the valve guides untouched (more or less) in a ported head. Was it ported with the guides in place ? (not a bad idea by any means)
#106 dandywarhol
Posted 10 December 2018 - 01:33 pm
It looks like the guides have had a little work on them. I don't believe the guides were ever out. The head (and engine) was tuned by TTS at Silverstone. I like the fact that the finish isn't too smooth.
That's the first time I've seen down the ports - I just rode it for around 30,000 miles. The fact it is still going so well after 90 odd thousand is testimony to the base engine and the mild tuning work TTS did to it. From memory it put out around 85 BHP at the wheel.
It would be worth doing a leak down test to se if the valve seats/guides are ok
It'll probably be a missile now there are kilos of crap cleaned off it  :pimp:  :rolleyes:
Edited by dandywarhol, 10 December 2018 - 01:35 pm.
#107 fixitsan
  • 4,851 posts
Posted 10 December 2018 - 01:56 pm
Yes you've done a good cleanup job
#108 Studley Ramrod
Posted 10 December 2018 - 10:06 pm
Getting there eh. :)  Took me ages cleaning and prepping the mk2 engine I painted a few years ago.
#109 Coxylaad
Coxylaad
  • 517 posts
Posted 12 December 2018 - 09:11 am
Bosh. in for a penny, the whole bike is apart now.
ming
Now I just have to cover up the bearing races and its ready to be sent off for powder coat.
start on the engine next.
#110 fixitsan
  • 4,851 posts
Posted 12 December 2018 - 09:42 am
Good work
I've always disliked the welds on the frame in the upper mid section. What about grinding them flat (just on the outside) before powder coating....or is that asking for trouble ?
#111 Coxylaad
Coxylaad
  • 517 posts
Posted 12 December 2018 - 04:28 pm
I thought about that. I would be shitting myself that it just fell in half when I was out riding :D
#112 fixitsan
  • 4,851 posts
Posted 12 December 2018 - 06:43 pm
lol...probably best to leave it then
#113 dandywarhol
Posted 12 December 2018 - 07:21 pm
I see where the bastards forced the steering lock!  :sorry:
#114 Coxylaad
Coxylaad
  • 517 posts
Posted 12 December 2018 - 10:42 pm
has anyone removed the bell crank/relay shock linkage thing from the bottom of the frame?
It looks like a sleeve has been pressed in from one side. It got a bit late for me to start investigating but it looks like I am going to have to somehow knock it out with a drift?
#115 dablik
  • 10,893 posts
Posted 12 December 2018 - 10:45 pm
Yep it only comes out one side Coxy, be careful wacking it with a drift fella, if you wack a bit to hard it's a new frame unless you can weld Aluminium, lots on the site about it..
Edit... Linkydink
Edited by dablik, 12 December 2018 - 10:50 pm.
#116 Coxylaad
Coxylaad
  • 517 posts
Posted 12 December 2018 - 10:51 pm
im looking but i cant find anything?
the sleeve seems completely siezed up
#117 dablik
  • 10,893 posts
Posted 12 December 2018 - 10:53 pm
Scroll through the pages, if it's really siezed up you might be better buying a replacement otherwise your gonna have to drill it out, i'll have a look sure it's in somewhere.
#118 Coxylaad
Coxylaad
  • 517 posts
Posted 12 December 2018 - 10:55 pm
found something. so a rawl bolt is the best solution to turn it out?
#119 dablik
  • 10,893 posts
Posted 12 December 2018 - 11:04 pm
Well most have come out with a rawl bolt so worth a try but, mine was so bad Lee Henty had to dremel it nearly all the way through and then break it up to come out, you might get lucky ! the sleeve is case hardened also in case you resort to a dremel.
Youll find some part numbers in this post if a need them, scroll down.
#120 fixitsan
  • 4,851 posts
Posted 13 December 2018 - 08:55 am
It comes out of the left side. I managed to free up a stuck one by using a long punch and a hammer...inserted the punch in the hole in the left  right side and caught a lip of the pin just enough to start it off
Edited by fixitsan, 13 December 2018 - 09:09 am.
