Another Loose Sprocket Nut
161 replies to this topic
#141 dapleb
  • 18,399 posts
Posted 29 July 2008 - 10:32 am
BOTH these things (638 spline and locknseal nut) can easily be done and we are not talking about something that needs to be done every week/month usually and its not exactly a time consuming complex task. So, for me it made sense to do BOTH and it seems to have worked, now maybe I wasted 30seconds and £3 doing one of these things unnecessarily, but even a tight wad loike me'sen would rather do that than risk a knackered output shaft.
Have unpinned the mkII topic and welded it to the mkI topic and bunged em both in Knowledgebase as this seems to be a frequent enough occurrence to merit it.
b0ooooooooo0o0o00oo00o0o0o0o0p
#142 kitt
kitt
  • 39 posts
Posted 17 August 2008 - 05:07 pm
After nut came loose on mk2 while in europe, it rattled around un-noticed being kept on the shaft by the plastic cover. When discovered, it had knackered the thread so a new nut would not screw up tight. Sorted it with 3 spots of weld, had to change chain and sprockets, quick grind off of weld, new sprocket, 3 more spot welds and been threr for last 15k, no problem.
1998 TDM850 (24k), 1996 TDM850(58k), 1989 XTZ 750(29k), 1999 XJR1300(13k) no more room in garage ! XJR gone to ex, so 1988 zx10 fills space
#143 finto
finto
  • 212 posts
Posted 07 October 2009 - 02:09 pm
Just out of pig ignorance here. What happens if the front nut does come loose. Are you talking a slide along the road. Or does the sprocket take the form of a ninja star and tear the calf off you.?
Only asking cause mine is loose and I will get it sorted sooner if I know im in trouble... smile.gif
#144 TonyDevil
Posted 07 October 2009 - 02:21 pm
when they come off they sit in the thread of the outputshaft
the cover stops it coming right the way off, so other than losing all drive to the rear wheel its not that dangerous
but AND THIS IS THE WORST BIT, while your output shaft is spinning round a a few thousand RPM the sprocket is sitting on the thread wearing it away, this stops you securing the next sprocket as the thread becomes unusable as the new nut just pulls straight over it
i would not ride a bike with a loose front sprocket
#145 finto
finto
  • 212 posts
Posted 07 October 2009 - 02:47 pm
Ah ok I get it. Its more damage to the bike than the rider. Fair Nuff. Ill get it sorted the weekend. Cheers Tony
#146 wicklamulla
Posted 10 October 2009 - 05:36 pm
QUOTE(TonyDevil @ Wed 7th Oct 2009, 03:21 PM) <{POST_SNAPBACK}>
No drive then.....? !
#147 timoc
timoc
  • 265 posts
Posted 07 March 2013 - 10:06 am
Does this affect 900's?
No more a TDM owner :sorry: moved on to the Tracer :)
#148 ChrisG
Posted 07 March 2013 - 10:45 am
I'm not aware of anyone having trouble with the 900 sprocket nuts
#149 JollyGiant
Posted 07 March 2013 - 10:50 am
House of Henty does a thicker one!
#150 chill
chill
  • 151 posts
Posted 04 August 2013 - 05:46 am
I just checked mine after 30k km. It was loose, I know when I fitted it it was done to 85Nm and lockwasher.
I used a Yammy sprocket but reused the washer and nut.
I could not see any damage to threads on nut or sharft.
Sprocket and chain are still in good condition.
Will change at about 40k. This time I will change the nut and washer as well as chain and sprockets.
#151 dapleb
  • 18,399 posts
Posted 04 August 2013 - 06:05 am
Might be worth trying a henty nut and loctite hawaai 5 0 then chill.
#152 masterbrewer
Posted 04 August 2013 - 10:11 am
Why not use 2 washers?   :um:
#153 chill
chill
  • 151 posts
Posted 05 August 2013 - 08:27 am
What if a Henty nut ???????????
scus my Ignorance.
#154 dapleb
  • 18,399 posts
Posted 05 August 2013 - 08:49 am
Hmm it aint listified in his list'o'bits but I am sure he does one (cous oi think oi gots one somewhere)... http://www.carpe-tdm...tainless&page=2
An alternative is the wider nut from a YZF details ear:http://www.carpe-tdm...?showtopic=9244
The loctite is mentioned earlier in this ear thread, think its 638 or summat.  Have been using that for a while now after many years of no probs I got a slightly loose nut.  After a coupla thousand moiles to Scotland and back it was very slightly loose again.  Having gone through the pain of completely rebuilding an enjun oi decided that I would invest in the loctite and no probs since.
#155 wicklamulla
Posted 06 August 2013 - 05:28 am
chill yew got a TDM 900 or an 850 ?
#156 masterbrewer
Posted 06 August 2013 - 09:50 am
Unless you own an 850  :good:
The thrill of riding a real bike gives you loose nuts & a big smile  :rotflmmfao:
#157 jdelfino
jdelfino
  • 603 posts
  • Location:Benalmadena Spain no more, The Hague no more, now Hampshire
Posted 06 August 2013 - 01:59 pm
not just loose nuts, my wife says that I'm missing some screws too..  :um:
Sent from my secret Dick Tracy watch
#158 chill
chill
  • 151 posts
Posted 07 August 2013 - 01:30 am
I have an 2002 900, the bikes done 110k km.
This is the second chain I have fitted. The first chain I found the nut was still tight when I changed it.
But after reading the post about LOOSE NUTS I decided to check and found the nut was loose. Lock washer was still in place so I do not know were the free play came from. Undid nut and checked thread on nut and sharft no problem so refitted torqued and locktabed.
Will check it again soon to see if it changes.
#159 curlylegend
curlylegend
  • 331 posts
Posted 24 February 2025 - 09:57 pm
So if the sprocket is secured onto the shaft with Loctite 638, does that mean that the nut itself is of less importance ?
In other words does the nut really do much if the sprocket is bonded onto the shaft ?
#160 leehenty
  • 5,326 posts
Posted 26 February 2025 - 07:44 pm
The 900s dont usually have any issues with sprocket nuts
