Worn Gearbox Cog Dogs ?
16 replies to this topic
#1 Studley Ramrod
Posted 30 November 2012 - 08:34 pm
Anyone experienced enough to give their onions on the state of wear to the cog dogs highlighted with the red arrows in me pic please ? :)
minimal ? moderate ? well fook'd ? :unsure2:
#2 leehenty
  • 5,321 posts
Posted 30 November 2012 - 10:04 pm
are they pitted ? need also to look at the opposite number with which they engage see how they are.
The M18 x 1 shaft thread could do with a gentle clean up too.
Edited by leehenty, 30 November 2012 - 10:05 pm.
#3 Studley Ramrod
Posted 01 December 2012 - 12:06 am
No pitting Lee, and the opposite number side thingys have hardly any wear at all.
#4 TinTin
TinTin
  • 1,296 posts
Posted 01 December 2012 - 10:18 am
Seen a lot worse than that and still in use. Why the shafts & bearings so rusty. Have they been rescued from the Thames.
Edited by yamahasam, 01 December 2012 - 10:41 am.
#5 leehenty
  • 5,321 posts
Posted 01 December 2012 - 11:06 am
They look ok to me if no there is no pitting or chipping which is what usually happens.
I'm concerned about the big open cage bearing though, It will need a thorough clean out before putting it back.
#6 Studley Ramrod
Posted 01 December 2012 - 11:55 am
Cheers Sam, yeah, I think the engine it belonged to musta been left without the side covers on in at some point in it's previous life, it's only the ends that have rust.
Lee, I've just spun the axle and it was a tad rough. Shouldn't be a problem for the intended new owner as he's basically only after the 3rd gear cogs. That said, it may not even be a problem once it's cleaned an loobed.
#7 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 01 December 2012 - 03:32 pm
Look at this link and be the judge ie. (rounded off is not good)
http://www.yzf600r.c...hp?f=21&t=48251
#8 Matt101
Matt101
  • 2,391 posts
Posted 01 December 2012 - 03:46 pm
They are no where near that bad on the dogs!! I'll have mine out at some point this week so will know what a bad one looks like.
#9 Studley Ramrod
Posted 01 December 2012 - 05:31 pm
Cheers mr Grumpee :) good to know what state they get to when they're failing.
Does anyone know if these dogs can be rebuilt/re-profiled ?
Not very warm out is it Matt ? :lol: So it'll be next weekend, or beyond, afore I get the 3D jigsaw delivered then ? Suits me better if it is actually. :unsure2:
#10 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 01 December 2012 - 05:41 pm
This will provide a good reference point for TDM owners. I have had to replace three EXUP gearboxes that would jump out of second gear.
The wear on the dogs and recesses was barely perceptible, but I was able to cure the problem in every case.
Thanks Studders. I liked the commentary the author gave too. These are defo fooketyfooked
This
#11 Studley Ramrod
Posted 01 December 2012 - 05:51 pm
Ha yeah, I read the commentary but couldn't help thinking some pocket-rocket clutchless gearshifts mighta also been a contributing factor.
How did you go about curing the problem ?
#12 tdm850rider
Posted 01 December 2012 - 07:00 pm
Goes straight from 1st to 3rd.
#13 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 01 December 2012 - 08:03 pm
Biting the bullet and replacing three x 2 complete shaft assemblies that I knew were reliable, as I didn't want to have to go back inside again.
A parts guy at Fowlers was feeling generous and had a load of surplus rotary Norton F1 gearboxes = FZR1000. Super cheap at £125.00 complete. Should have bought the lot. Doh! Those were the days. Trevor Nation, Rocket Ron.
The others I sourced from blown ThunderAce engines, the gearboxes of which were much improved.
I recommend you replace the entire shebang when it comes to second hand kit.. Shafts,selector barrel,forks as they are a matching fit.
I don't know whether dogs can be rebuilt, but I'm guessing that given the stresses and that everything has to be a perfect match, then odds are they can't, economically.
If you could find a totalled/lo-mileage/spares/repairs TDM with a history and keep the collection/total costs below £150-£175 I'd take that route.
#14 TinTin
TinTin
  • 1,296 posts
Posted 02 December 2012 - 10:47 am
The ones on the pink towel are shagged but I still say Studleys are just normal wear and tear & have life in them yet.
#15 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 02 December 2012 - 04:22 pm
If he knows they worked before they were removed from the crankcase then I'd agree.
Like I've said earlier, terminal wear on an FZR gearbox is invisible compared to the example here and Studders unit.
I wonder how bad it can get on a TDM before it does the jumping out of second thing?
That's why we need photos as soon as a faulty gearbox is removed.
#16 Studley Ramrod
Posted 02 December 2012 - 07:07 pm
Is it possible that the FZR also had a bent fork selector contributing to the problem ? It'd explain why they slip but don't show much wear. :dunno:
But yeah, ideally a photo of an 'only just started slipping' cog would be good.
#17 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 02 December 2012 - 07:37 pm
Or worn channels in the gear selector barrel. Hence best policy, get a complete good'un to make allowances for wear. (Wear)ever it may be in the system.
Actually, now that I've mentioned it, you haz jogged my memory. My main issues in at least 2 cases were with the channels in the gear selector barrel. This just goes to show that a problem could be caused by wear at any point in the system. When you get there, I should scrutinize every component, like your bank balance depended on it.
Edited by TYREDNGRUMPEE, 02 December 2012 - 07:46 pm.
