I got these out of ebay
IMG_0635c.jpg 106.14KB
29 downloads
IMG_0636c.jpg 79.34KB
54 downloadsthese are 2" and came with all the ballasts and wiring including the relay.
First you need to get the headlight housing off the bike, I took the fairing off to do this.
once off take the bulbs out and remove the spring clips from around the join.
Then make sure your wife/girlfriend/significant other is out and put the housing in the oven at 80 degC for around 15mins.
it should be hot but not too hot to touch with your bare hands.
once out of the oven pull the two halves apart starting from one end.
mine came apart very easily, if it doesn't, put it back in for 5 mins or so.
you then should have this
IMG_0421.JPG 136.87KB
77 downloadstotally loosen off the beam adjusting screws then
Pull the projector and reflector off the ball and socket fixing screws
undo the screws attaching the projector lens to its reflector
IMG_0422.JPG 138.31KB
63 downloadsthrow the reflector away and cut the lens holder off the backplate, and file the backplate flat, then make up a plate to cover the large hole in the backplate fixing it through the holes that took the reflector, then drill a hole in the centre to fix the new projector.
IMG_0423.JPG 132.34KB
42 downloads
IMG_0427.JPG 129.55KB
33 downloadsThen turn your attention to the large reflector,
file down the lugs on the back that held the bulb and drill a 10mm hole for the projector leads ( in the pic I have drilled this hole in the wrong place (projector was upside down) the hole needs drilling at 1 o'clock in the pic not 7 o'clock)
IMG_0425.JPG 136.64KB
32 downloads
IMG_0426.JPG 97.53KB
37 downloadsthe surface needs to be flat for the locknut to tighten on.
then paint em matt black (you can see the extra hole in the reflector)
IMG_0428.JPG 174.96KB
42 downloadsThen mount the new reflectors, they tighten onto the large rubber washers to keep them steady. make sure that the CCFL ring gap is at the bottom when fitting (you can tell which way up everything is by fitting into the housing the plate and reflector will only fit one way.
IMG_0429.JPG 144.12KB
42 downloadsMake sure all the leads go through the hole in the reflector
IMG_0430.JPG 145.29KB
41 downloadsAgain make sure the wife is out and also the bulbs and put it back into the oven
when its out press the two halves together again and re-attach the clips
IMG_0433.JPG 146.48KB
38 downloadsput the bulbs back in and put the caps on the back
IMG_0434.JPG 124.03KB
32 downloadsnow install the housing back onto the bike.
next the hard bit. the wiring (only joking that's part two I need to go photo the wiring)
Edited by moodygaz, 02 July 2013 - 08:23 pm.
