Valve Clearance , Coolant Pipe O-Ring Needed --- Where From
29 replies to this topic
#1 Geordie Guy
Posted 07 September 2014 - 02:07 pm
Did the valve clearances, 24,000 service, new spark plugs (iridium) k&N filter.
Started it up and it purrs !!!!!
Looked down water pissing everywhere.
The coolant pipe on the top of the head, was a bastard to get it, when I took it apart, I had pushed the o-ring down the hole !!
Got a wire and fished it out, it looks ok , but I want to replace it to be sure.
Part is http://www.manualsli...?page=15#manual  24  Prt No 93210−18417
But where the feck do you get them from, every google search ends up in the states. on another site I found this they where buying them from DIY shops at a fraction of the cost ......
The ones I came up with are #14 O-ring (15/16" OD x 3/4" ID x 3/32") equivalent to p/n 93210-18417-00
So, where can I get one ??????
cheers, Ivan
#2 ChrisG
Posted 07 September 2014 - 02:15 pm
Fowlers in Bristol will post you the right one seeing as you already know the part number
http://www.fowlers.co.uk/parts/
Alternatively Halfords or most motor factors usually sell packs of multiple sizes which should cover it for similar money to one genuine yamaha one.
#3 Studley Ramrod
Posted 07 September 2014 - 03:03 pm
Put a bit o loob on yer ring afore you push/wiggle yer pipe in the hole, it'll make ferra smoother entry.  chorkle chorkle !
Got me a box of various sized o rings from poundland, Halfords and most other motor factors should sell similar. :good:
#4 Geordie Guy
Posted 07 September 2014 - 03:06 pm
Thanks Chris,
Mr Henity suggested Fowlers but when I looked I could not find a page for TDM.
Will ring them tomorrow.
:good:
#5 Studley Ramrod
Posted 07 September 2014 - 03:09 pm
Oh yeah, congratulations on doin' the valves !  :drinks:
#6 bigmick1981
bigmick1981
  • 80 posts
Posted 07 September 2014 - 06:41 pm
Lidl or aldi had packs as a special buy a week ago if i remember correctly, pack contained rubber o'rings, copper washers and plastic washers
#7 leehenty
  • 5,325 posts
Posted 07 September 2014 - 09:58 pm
19mm inner hole and 2.5mm section o ring should do it. The should be about 24 mm on the outside.
You order 'o' rings by the inner hole dia x the section.
Edited by leehenty, 07 September 2014 - 10:02 pm.
#8 Geordie Guy
Posted 08 September 2014 - 05:37 am
Here's a question.
Do you put the ring in the hole first or do you slide it onto the tube and then put the whole assembly in?
#9 Matt101
Matt101
  • 2,391 posts
Posted 08 September 2014 - 05:53 am
Put it over the tube with a little silicone grease to help it in.
Edited by Matt101, 08 September 2014 - 05:53 am.
#10 Studley Ramrod
Posted 08 September 2014 - 07:40 am
:wifgeni:  Wiggle the pipe in a circular direction as you press down on it and you should hear it plop in.  Make sure you remove all the crap in the hole afore you do. :)
#11 Geordie Guy
Posted 08 September 2014 - 10:58 am
Bought 2 from Fowlers this morning, got a spare just in case.
Went round a few places this morning before I ordered it and no-one could match the size, but they gave me a few free just to try. I now have 15 o-rings that dont fit ...... :huh:
Fowlers £1.87 each + VAT+ postage £8.50 !!!!!
Should get them wedensday.
#12 Matt101
Matt101
  • 2,391 posts
Posted 08 September 2014 - 01:51 pm
I know it doesn't help but others may want to know.
http://engineersmate...c=100229&pg=110
£1.95 postage
#13 Geordie Guy
Posted 08 September 2014 - 04:42 pm
I will measure the new one and see if there is a match on that web site.
Cheers Matt
#14 Rallyist
Posted 08 September 2014 - 05:51 pm
There isn't Ivan I have allready looked. :sorry:
#15 Matt101
Matt101
  • 2,391 posts
Posted 08 September 2014 - 07:34 pm
According to Mr Hentys sizes.........
http://engineersmate...100229?c=100229
#16 Geordie Guy
Posted 09 September 2014 - 03:26 pm
What sizes are Lee's ?
#17 Riggers
Riggers
  • 531 posts
Posted 09 September 2014 - 06:27 pm
I didn't bother with a Yamaha branded one, but just used a new one I happened to have around.
As mentioned make sure all the crap and crud is carefully cleaned away and use a bit of silicone gasket cement and the job should be a good 'un.
To get a good seal just remember three little words ..... CLEAN, CLEAN, CLEAN.
And two more - Good luck.
Riggers.
#18 leehenty
  • 5,325 posts
Posted 09 September 2014 - 08:58 pm
my sizes are about 0.1mm bigger in section, so gives a good tight fit. It will need lube to slide it in there. The sort of silicone grease used for sewage pipes is good.
The tube and groove must be absolutely clean. Use plenty of lube like this. It's blue, so you won't get it mixed up with your other 'lubes'  :lol:
http://www.screwfix....-gel-800g/10631
#19 Geordie Guy
Posted 09 September 2014 - 09:17 pm
:punishment:  I'm sure a big tub like that will come in handy !
#20 pilninggas
pilninggas
  • 181 posts
Posted 09 September 2014 - 09:23 pm
I live 5 mins from fowlers, if I can pick small parts up stick em in a jiffy bag and post, let me know.  Happy to help at anytime
