Exhaust Experience? Not Nuts/studs/snappers
12 replies to this topic
#1 Favs
Posted 10 January 2017 - 05:45 pm
Dear peeps....
I'm looking to replace the 900's OE silencers with alternatives which must be...
Not modifying the original pipework
Compatible with OE mainstand
Lighter than OE (shouldn't be too difficult :lol: )
Stainless steel construction (prefer polished finish)
Not deafening/antisocial :punishment:or with a selection of non-ejecting type baffles
Clear of the Givi E22/E35(6)/E45 panniers when fitted
Not reducing service access to rear wheel/chain adjustment
Not reducing ground clearance
CE or BSI stamped (well er preferably)
So, who amongst us has such a system fitted, cos I've searched past posts in vain?
TIA
#2 Luke
Luke
  • 271 posts
Posted 10 January 2017 - 05:54 pm
Lots of threads on here for exhausts. I'm using Fuel which meets your needs.
#3 nav18tor
nav18tor
  • 596 posts
Posted 10 January 2017 - 05:57 pm
I had Fuel exhaust on mine. Cleared the Givi panniers, sounded good and would recommend
He who dies with the most toys wins
No more 2007 in white
In it's place is a big blue FJR1300
Touring Portugal? this is the perfect base
#4 dablik
  • 10,893 posts
Posted 10 January 2017 - 06:59 pm
Think most anything will be a nuisance re rear wheel removal Favs, Laser Duo-tech springs to mind though.
#5 chrisr
Posted 10 January 2017 - 08:04 pm
My Scorpions also fit the bill, though there's no stop for the centrestand, I think the fuels have one.
#6 nav18tor
nav18tor
  • 596 posts
Posted 10 January 2017 - 08:18 pm
Can confirm that they do
#7 steve27bha
  • 797 posts
Posted 10 January 2017 - 08:42 pm
I'm well pleased with my Ixil 2into1 got 2nd-hand from Ramo on here. It's a quality piece of work.
The only detail I'm not sure of is the fitting with a centre stand since I don't have one. There is no bumper fitted. The fitting instructions do not say to remove a centre stand. The kit is a straight slip-on fit onto the front pipes.
Givi rack shown is for E21s which fit great. Chain access cannot be beaten, of course.
Pix may help - ask for more or pose Qs if needed.
EDIT - E21s replacing E22s above - finger bounce!
Edited by steve27bha, 11 January 2017 - 04:47 pm.
#8 Favs
Posted 11 January 2017 - 08:26 am
Many thanks for your helpful & speedy replies - there are indeed many previous posts about exhausts, but, I could find none or no combination of posts which specifically answered my criteria. I have had a look at the Fuel website images and it has a picture with a pannier fitted (not one I recognise). This pannier looks very very close to the silencer. I have had exhaust heat destroy the base of a Craven(glassfibre)pannier and melt my sleeping bag and toothbrush together (1980 hacking through the Lyon traffic heading for the eye-watering, throat cramping & infamously poorly ventilated tunnel), I am cautious about the proximity of expensive Givi plastic & hot gases/metal. Anyone got or wouldn't mind taking & posting a pic of their Fuel silencers with Givi E45 & or E22 fitted please? BTW I have mine fitted with a wingrack not tubular frames if there is a locational difference (I don't know). Thanks again. Favs
#9 fixitsan
  • 4,851 posts
Posted 11 January 2017 - 08:31 am
What about self adhesive aluminium tape on the underside of vulnerable panniers, to reflect the heat ?
#10 Johnners
Johnners
  • 120 posts
Posted 11 January 2017 - 09:15 am
Hi Favs,
You might also want to consider Simmi cans - they meet all the criteria you've stated including OE centre stand bump stop and as long as you order the 400mm cans, they also fit under E22s with no heat problems.
Just a thought.  :)
#11 ChrisG
Posted 11 January 2017 - 10:07 am
I've got Fuels's with the PL whatever side racks and use E22's and E35's with no issue, plenty of clearance.
It was a toss up between Fuels and MTC but the MTC's didn't have a center stand stop (though I understand they now do) and in the end I found a cheap pair of Fuels on e-bay.
#12 hallrob1
hallrob1
  • 1,112 posts
Posted 11 January 2017 - 12:38 pm
I've had Laser Duo Techs on both of mine and although they were quite close I never had a problem with heat with my E21's although I did fit some heat reflective tape. I've just replaced the panniers with the E22 model and they give even more clearance.
The Duo techs have two positions but I've always kept them at the highest setting and they fulfill all your other requirements - pretty expensive now though, nearly double the Fuels IIRC but they have lasted 10 years, 2 bikes and about 60 - 70,000 miles.
#13 TinTin
TinTin
  • 1,296 posts
Posted 12 January 2017 - 03:38 pm
Favs email Fuel Exhausts direct. They have pictures they dont put on the web and they are very very helpful.Attached File  2011-08-08 14.21.47.jpg   222.49KB   0 downloads
I have a Fuel Diablo on the Tiumph & there will be one on the SV when I recover financially frim Christmas
They sound exactly the same as road legal Remus ones at a fraction of the price.
Edited by TinTin, 12 January 2017 - 03:40 pm.
