Time For A Gearing Change ?
34 replies to this topic
#1 thelodger
thelodger
  • 150 posts
Posted 07 May 2018 - 08:44 am
I am going to fit a new chain and sprocket . I haven't had my TDM 900 long but I did do a lot of miles over weekend and got the feeling that the bike would benefit from a change in the gearing so that it does more revs per mph .  This would help particularly in town riding when I seem to be in first most of the time and second would be better and also keep the revs out of the 3.5k to 4k zone more of the time.  I understand that standard gearing is 16 front and 42 rear . I am thinking of going 15 front . Has anyone else done this with positive results ?
#2 poppykle
poppykle
  • 88 posts
Posted 07 May 2018 - 09:54 am
I dropped one tooth on the KLE when I had it and it made a world of difference particularly commuting around town. I'm thinking of doing the same when I change the chain and sprockets on my 900. The extra revs are no real disadvantage at highway speeds either.
#3 Bjørge
  • 1,894 posts
Posted 07 May 2018 - 11:08 am
Check out this: https://www.gearingcommander.com/ ... so that you don't make a mistake when choosing sprockets (espeically at the bottom of page - chain wear)
#4 Favs
Posted 07 May 2018 - 12:23 pm
Not a hijack - anyone fitted a 39 teeth rear sprocket to a 9er? Wazzit like?
Ta.
#5 Hombre
Hombre
  • 449 posts
Posted 07 May 2018 - 09:19 pm
On a 9er, the speedo will be sensitive to the gearing.
Edited by Hombre, 07 May 2018 - 09:19 pm.
#6 Kenyun
Kenyun
  • 36 posts
Posted 07 May 2018 - 10:15 pm
Not if it has ABS.
#7 thelodger
thelodger
  • 150 posts
Posted 08 May 2018 - 08:45 am
Mine's non-abs so any gearing change is going to affect the speedo reading. I'm guessing that standard speedo error is that it reads fast and if my thinking is correct then dropping a tooth on the front sprocket will make the speedo read even faster . I suppose this might affect my insurance if I have an accident but I would also want to know how fast I am going so for these reasons I am going to stick to standard gearing.
#8 fixitsan
  • 4,849 posts
Posted 08 May 2018 - 09:05 am
I don't think it would affect insurance unless it over reads by more than the 10% the construction and use regulations allows for those earlier years. They've tightened up on it with later vehicles but I don't know the year off the top of my head. The regs state that a speedo must never under read. Also, the speedo is not an MOT item !
#9 thelodger
thelodger
  • 150 posts
Posted 08 May 2018 - 09:09 am
Does anyone have a road test which shows the accuracy of the speedo ?
Edited by thelodger, 08 May 2018 - 09:54 am.
#10 CrashTestDuffy
CrashTestDuffy
  • 125 posts
Posted 08 May 2018 - 09:34 am
GPS app on phone on a motorway stretch should give a fairly accurate speed I think.
#11 fixitsan
  • 4,849 posts
Posted 08 May 2018 - 10:24 am
+1  GPS on a straight and level road
#12 Hombre
Hombre
  • 449 posts
Posted 08 May 2018 - 08:46 pm
My 9er speedo over-reads against GPS speed.
#13 spike240
spike240
  • 91 posts
Posted 20 June 2018 - 07:16 am
Hi - reading through this thread, as sometime in future I am thinking of a 15 tooth front sprocket. A friend reckons it will make the 900 more useable. A couple of questions - someone said the speedo  error wouldn't affect the ABS models - why is this?
And Lodger -  did you end up swapping cogs? If so - what do you think? And where did you source the sprocket - oh and what make is it?
Many thanks.
PS The TDM is growing on me - I am learning how to ride it. :lol:
#14 Nog
Nog
  • 527 posts
Posted 20 June 2018 - 07:24 am
Because on ABS bikes the speed is taken from the ABS sensor, which is on the wheels and so unaffected by gearing changes, since the gearing will be changed before the final reading (if that makes sense).  Only a change in wheel size would make a difference to that speed reading.
Normally they take the speed off the output shaft from the gearbox, which means any final gearing changes are after the speed is taken and therefore will mis-read,
#15 madmopedracer
madmopedracer
  • 473 posts
Posted 20 June 2018 - 10:59 am
would the speedo reading be out by much just drooping 1 tooth on the sprocket
if you can the calibrate with gps for the important speeds 30,40,50 and 70 mph
#16 Kenyun
Kenyun
  • 36 posts
Posted 20 June 2018 - 12:47 pm
I wouldn't be overly concerned about speedo readings, I haven't altered the gearing on my TDM900, but on my other bikes 1 tooth [extra] on the front sprocket alters the speedo reading by only about 2.5%.
#17 thelodger
thelodger
  • 150 posts
Posted 20 June 2018 - 03:47 pm
I stuck with the standard size sprockets.  I think dropping a tooth on the gearbox sprocket is likely to make the speedo over read by at least 10% ). I reckon standard over read is  c5%  and then at least another 5% from the "one less tooth ".
I fitted Ognibene sprockets front and rear as they have rubber damping rings ( original Yamaha front had one  but not the rear ) .  Italian made and much better than the usual JT sprockets.  They also look cool and stupidly I like their name !!  Chain is  DID  VX525 gold X ring.
#18 spike240
spike240
  • 91 posts
Posted 20 June 2018 - 08:22 pm
Ok thanks for the comments. Personally I am not too bothered about the speedo as mine is ABS, I also nearly always have gps in front of me and I can confirm the standard speedo set up is very optimistic.
Is anyone else using a 15 tooth sprocket?
#19 Bjørge
  • 1,894 posts
Posted 21 June 2018 - 09:48 am
If standard sprocket is 16 teeth, then dropping to 15 would give (16/15) - 1 = 6.67% lower speed with same output shaft speed (also,.speedo reading)
#20 spike240
spike240
  • 91 posts
Posted 21 June 2018 - 12:36 pm
Hi and thanks. There is a link earlier in the thread to a site gearingcommander which is very very good. It does all the maths for you, but there's nothing like experiencing the change - if you know what I mean. Can't help thinking if  a 15 tooth sprocket was better than standard 16 then Yamaha would have done it. Having said that, my mate (mentioned earlier) is a dinosaur biker/racer/mechanic and reckons for the losses on top speed the bike will be more useable.
So for the cost of a sprocket I will try it (don't know when tho). When I have done it, and  road-tested it I will be sure to let you know.
atb
