Mot Rules And Regs
11 replies to this topic
#1 Riggers
Riggers
  • 531 posts
Posted 18 April 2019 - 07:48 am
Got my 9er booked in next week for its MOT. She's an '09' reg with relatively low mileage of 17,000. Last year I took her to a different garage where the mechanic really did go over the bike with a fine tooth comb. Nowt wrong with that me thinks as if there's something wrong I'd like to know about it. Anyway after a new tyre valve was fitted I got the pass certificate.
BUT he said that if I'd taken the bike in a month later 'when the new rules come in' he would have failed it on discoloured brake fluid and the drive chain 'because it looks a bit loose on the sprocket'.
IMHO the brake fluid looks perfectly normal to me and the chain seems fine, I don't go around doing wheelies and these days prefer my license to cheap thrills.
So basically just asking if anyone is across these new rules and with a week to go what should I be checking?
Cheers guys.
Riggers.
#2 fixitsan
  • 4,850 posts
Posted 18 April 2019 - 08:23 am
All here Riggers. https://www.mot-test...anuals/class12/
It only mentions brake fluid which is 'contaminated', but I'm not sure if that has always been the standard ?
Edited by fixitsan, 18 April 2019 - 08:24 am.
#3 dablik
  • 10,892 posts
Posted 18 April 2019 - 08:25 am
I think the "chain to loose" as mentioned to me last year by a new mot station will prevail, maybe take along the manual to show them and perhaps prevent a fail.
#4 AliG
Posted 18 April 2019 - 09:37 am
Yep. I had the chain comment made to me and that was at a Yamaha garage. I pointed out that the chain was set correctly as per Yamaha's manual and that it was a TDM, not an R1. He accepted that as he knew I had 2 TDMs and the bikes were mechanically excellent. For a non-Yam tester, a copy of the manual would be a good back-up. Good idea, as my next MOT will be at a new garage, so I won't know what to expect.
#5 muddy
Posted 18 April 2019 - 09:49 am
The chain slack thing came up with me last year and it was a tad slacker than it should be. I was lucky in that I chose a 'back street' MOT station and rather than fail me, we adjusted it there and then. If the slack is in spec, just be sure to bring the TDM manual with you when you go to show the tester.
Edited by muddy, 18 April 2019 - 03:26 pm.
#6 Riggers
Riggers
  • 531 posts
Posted 18 April 2019 - 10:01 am
Great! many thanks :good:
Thanks for the tips guys, very helpful as always. Good idea to take the manual.
#7 dapleb
  • 18,382 posts
Posted 18 April 2019 - 04:18 pm
MOT test tyre kicking exercise, covering the very very very basics. Aways makes me chuckle to read "bike flew through its MOT test" ..... Well would be summat glaringly obvious if it didn't!!!
Brake fluid.....not sure easy to tell what is site glass mud or fluid contamination unless you is gonna open up the res and lick it. Chain, lolzio. Sit on boike and ask if loose on sprocket now. :0)
Be grateful for anyone who does more than a half arsed attempt at the test. Gives a second observation on the basics.
#8 TKH
  • 2,201 posts
Posted 21 April 2019 - 09:34 pm
One of the fails on mine last time was he didn't like the look of the rear tyre valve. It was a few weeks old and absolutely nothing up with it.
#9 Riggers
Riggers
  • 531 posts
Posted 24 April 2019 - 07:37 am
Glad so say she passed her MOT yesterday. Interestingly though he DID mention the chain slack (carefully set at 50mm) so thanks to the forum I was able to show him the owner's manual.
Other 'mentions' were tyres nearing their end (which was fair enough), discoloured brake fluid (booked in with same garage for Friday), and 'bit noisy exhaust' (Deamon pipes from SP Performance). But none of these caused a failure.
On the plus side he said I had the best brakes he's ever come across on a Yamaha! Totally smooth and progressive - well, well, well.
Once again thanks for tips guys.
Riggers.
#10 dapleb
  • 18,382 posts
Posted 24 April 2019 - 08:50 am
Well done wiggers.
#11 mh1848
mh1848
  • 507 posts
Posted 24 April 2019 - 05:52 pm
It seems to becoming more and more subjective and in the hands of tester - exhaust noise, horn, chain slack, brake fluid discoloration and as far as aware still only a valid test on day of issue
#12 TKH
  • 2,201 posts
Posted 24 April 2019 - 07:07 pm
Agreed, include HIDs in with that as well.
