Breaking 98 Tdm850
Spoked wheels panniers shock ignitech. bits
30 replies to this topic
#1 rcmad
rcmad
  • 15 posts
Posted 26 August 2019 - 05:57 pm
As above. Due to a 3rd gear issue and lack of spare parts i've decided to break My TDM. Bit gutted TBH as it was a good looking bike.
Attached File  08houbihj bhojipk.jpg   385.03KB   1 downloads
link to photos https://photos.app.g...eofuRWNS7zMHju5
Bits with price tags
Ignitech Sparker TCIP4, with plug and play loom for the tdm850 - £50.00 posted
Wiwo Wire / spokd wheels, made to exact same dimensions as stock wheels so bolt right in. Front wheel will need new bearings as i was running a different fork setup (different axle diameter)  will need 2 standard front bearings. Power coated in balck with Stainless spokes / nipples. Disks on front are a year old. Rear is original.  Wiwo have gone the way of the dinousour and i've not seen another TDM with Wire wheels, these may be the only ones in existance? Think i have about £1000 in theses wheels with the powerdercoatign and new spokes. £500.00 pickup only Peterborough
YSS rear shock. £80.00 posted
Pannier setup £100 local pickup - the frames were for a MK but i modified them to fit the MK2, some brackets could do with a strip and spray. Panniers are top loading units similar to pelicans. Keyed identical with locks.
Open to offers on everything else. If theres something that you need and i've not listed let me know.
Other info i can think of
Bike had about 25K miles on it.
Head looks to be in good condition, did a quick check berofe taking the bike apart and most of the valve clearances were within spec.
Cylinder bores have some light vertical scoring on the front and back of engine. Honing still visible in other places
Crankshaft looks like new. Barely any wear on bearing surfaces that i can see, including big end bearings.
Carbs were rebuilt a couple of years ago.
Frame is dirty but complete, no broken brackets - Swingarm has a dent on one side and rust patches underneath. - will come with plate and V5.
Grab rail was drilled to accept an aluminium Givi monokey (i think) baseplate. Been steady as a rock.
Think the centre stand and engine bars are Sw-motech.
Headlight is modded to run two projector style headlights. They have an electrically operated flap in them to swith between low and high beam
Rear light loom was modified by a previous owner to provide provision for secondary brake light
Main loom was modified by previous to provide power tap- fused
Parts sold so far
Cylinder Head inc cams
Centre stand
Headlight
Engine Bars
Edited by rcmad, 28 August 2019 - 06:59 am.
#2 dapleb
  • 18,398 posts
Posted 26 August 2019 - 06:23 pm
Those wheels are mega. Good luck with the breaking, shame.
#3 chrisbee
chrisbee
  • 413 posts
Posted 26 August 2019 - 06:31 pm
How much do you want for the mototech engine guards??
#4 MickC
MickC
  • 432 posts
  • TDM model: 1995
Posted 26 August 2019 - 07:14 pm
rcmad
Explain the wheels if you can,stock hubs drilled?
If 3rd gear is just whining try a loud exhaust :good:
Forget it just read the post again sorry.
Edited by MickC, 26 August 2019 - 07:19 pm.
#5 rcmad
rcmad
  • 15 posts
Posted 26 August 2019 - 07:50 pm
The wheel hubs are custom machined from a block of aluminium so not stock hubs at all. Hubs are stamped Wiwo, a lot of internet searching found out very little, apart from they were a company in Germany that manufactured custom wheels and braking systems for bikes and that they went out of business in the 90's. I should have some pictures kicking about from when I first got them. They were originally on a MK1 bike over in ireland
Chrisbee, £35 posted? I need to find the other rubber bung, will be in the garage somewhere
Edited by rcmad, 26 August 2019 - 07:50 pm.
#6 chrisbee
chrisbee
  • 413 posts
Posted 26 August 2019 - 08:13 pm
I will have the bars👍👍
RCmad, i have sent you a message
#7 wicklamulla
Posted 26 August 2019 - 11:14 pm
RCMAD,  How much for the centre stand the modified headlight and the hand guards and the necessary fitting hardware please?
Can you also tell me if the rear wheel has a cush drive incorporated into the sprocket carrier i wonder?
Edited by wicklamulla, 26 August 2019 - 11:26 pm.
#8 drewpy
  • 1,790 posts
Posted 27 August 2019 - 07:38 am
What does the ignitech thing do?
Fancy the head with caps so I can refurb/ port and do a swap for mine
#9 dablik
Posted 27 August 2019 - 07:47 am
Such a shame, lovely bike especially with those wheels, dont think me budget is gonna stretch that far though..
#10 rcmad
rcmad
  • 15 posts
Posted 27 August 2019 - 07:55 am
There are no handguards but you can have the stand and the Headlight for £85 if that sounds fair to you.
Also the rear sprocket does have a cush drive setup.
Replaces the stock ECU and allows you to alter the ignitiong timing etc. http://www.ignitech.cz/en/.
A complete head sold on ebay recently for £130.  £100 any good to you? its quite heavy so would either have to pickup or i'd have to sort a sturdy box for it.
#11 wicklamulla
Posted 27 August 2019 - 08:48 am
Thanks very much RCMAD £85 is fine.   The reason i asked about the cush drive was some of the smaller Yamaha off road bikes wheels/hubs have no cush drive and it wrecks gearboxes and i incorrectly assumed thas what killed 3rd gear on yer TDM.    Ok i'll private message you regarding payment.  K
#12 danjohnston89
danjohnston89
  • 63 posts
Posted 27 August 2019 - 09:04 pm
Where are you located? If youre not to far away Ill have the luggage set off you
Also would be interested in the rear brake master cylinder, how much for that? Cheers
#13 rcmad
rcmad
  • 15 posts
Posted 28 August 2019 - 06:58 am
danjohnston89, located just north of peterborough.£15 posted for the master cylinder.
#14 Snowbird
  • 1,484 posts
Posted 10 September 2019 - 02:43 pm
I'd like the fuel tap at the right price, assuming it's the on/off/reserve type.
#15 Favs
Posted 10 September 2019 - 07:17 pm
What price is the stator please?
#16 Andy25
Andy25
  • 344 posts
Posted 11 September 2019 - 07:38 pm
Interested in the Front Brake calipers - how much ?
#17 wicklamulla
Posted 11 September 2019 - 09:03 pm
got my items in the post,  thanks very much. K
#18 Snowbird
  • 1,484 posts
Posted 16 September 2019 - 11:33 am
I did send a pm about the calipers on the 10th but not heard anything yet, I assume he's away or something.
#19 wicklamulla
Posted 16 September 2019 - 12:18 pm
i suspect he's on his lolidays at the moment.
#20 Andy25
Andy25
  • 344 posts
Posted 16 September 2019 - 05:00 pm
I've bought a set from Ebay so I'm sorted ( or will be when they arrive )
Hopefully you'll get sorted soon
Hopefully somewhere nice
Also tagged with one or more of these keywords: Spoked wheels, panniers, shock, ignitech., bits
