Speedo Not Working After Wheel Off
7 replies to this topic
#1 JMC
JMC
  • 265 posts
Posted 17 June 2025 - 09:15 am
As above lads, 2000 4tx, had wheel off and not working now, never had an issue before, re checked wheel position and it's fitted correctly is there something else I'm missing before I start ripping at the weekend.
Hunter S. Thompson.
#2 Snowbird
Posted 17 June 2025 - 09:35 am
Tabs on speedo sensor broken or disengaged most likely.
#3 dapleb
  • 18,378 posts
Posted 17 June 2025 - 03:30 pm
Yeah that.
#4 JMC
JMC
  • 265 posts
Posted 20 June 2025 - 08:45 am
 Where it connects to the wheel?
I think the tabs looked ok so wondering if they are broken inside that piece itself or is that whet you mean?
Hunter S. Thompson.
#5 dablik
  • 10,892 posts
Posted 20 June 2025 - 09:26 am
Sometimes the inner cable can loosen a little when you've had the wheel off, so it's then not connected properley behind the clocks !?
#6 Studley Ramrod
Posted 05 July 2025 - 07:06 pm
Yeah, better to connect at wheel, then connect at speedo as the inner cable can slip out of the speedo.
#7 dapleb
  • 18,378 posts
Posted 13 July 2025 - 08:47 pm
Any luck?
#8 JMC
JMC
  • 265 posts
Posted 11 August 2025 - 06:02 pm
i'm hoping this is the problem, it does make sense as it worked fine before I had the wheel off
Any luck?
Been crazy busy so hopefully next week  :hide:
Hunter S. Thompson.
