Non Starter
3 replies to this topic
#1 Muppdog
Muppdog
  • 305 posts
Posted 22 July 2025 - 12:36 pm
Went for a noisy ride to Rostrevor. Or I thought I was. Had a couple of misfires on the way. Never happened before. Then we had to stop to let a bike race pass so I turned the engine off. As you would. After that the bike would not fire up again. Tried to bump start, nothing. Kept trying but no sign of life. Also no smell of unburned fuel. So seat came off and dug out the PC. Did I say I am running a Power Commander? After turning on ignition no lights came on on the PC. Usually it runs the lights up and down the left column on start up.
Before everybody goes to sleep it fired up after about 30 minutes. Lights on on the PC. Keeping the revs around 4k kept me going back homewards. 15 minutes later it ran normally. This w/e the map in the P/C was different. Rough-ish. Replaced with correct map and still not good.
Is the PC knackered? Do they break? Or should I look at the bike's electrics?
I could unplug and run on the STD map once I got the noise stopped. Question is really about reliability of the PC.
Rob
#2 fixitsan
  • 4,850 posts
Posted 22 July 2025 - 05:32 pm
First thing I would do would be to bypass the PC and let the bike's ECU drive the injectors, and run like that in standard configuration for a while.
If you're still getting a problem it's probably  a wiring problem on the bike, if not then it's possibly PC wiring
#3 trevini
trevini
  • 1,890 posts
Posted 22 July 2025 - 05:40 pm
What Chris said… For how quick and easy it is to take the PC out of the loop, I’d do it just to make fault diagnosis easier if it’s still playing up once it’s disconnected. If it runs fine without it, you have your answer.
#4 Muppdog
Muppdog
  • 305 posts
Posted 22 July 2025 - 08:49 pm
Cheers for that. Its the logical way, I suppose. Have to find a place to get into the clutch first. Then do this bit at the same time.
