Difficulty Selecting Neutral. Mk1
8 replies to this topic
#1 dapleb
  • 18,378 posts
Posted 20 September 2025 - 03:05 pm
When coming to a stop triggers broom don't wanna go into neutral. I can go up and down the gears no probs passing neutral but it don't wanna go in.
With enjun stopped it'll go into neutral no probs.
This is a new problem and suspect its summat worn in grrr box.
Any ideas or anyone had similar?
#2 Bjørge
  • 1,894 posts
Posted 20 September 2025 - 09:32 pm
Could be a f'ed clutch. Happened to my Tracer 7.
#3 laughin in a windstorm
  • 861 posts
Posted 21 September 2025 - 03:03 am
if your clutch and gear change lever are ok, sometimes an engine flush and fresh oil can help
#4 dapleb
  • 18,378 posts
Posted 21 September 2025 - 06:21 am
Thanks chaps. I plan on the oil change for winter and will go from there.
Have plenty of clutch plates to test with and will make sure the cable is in spec.
#5 Catteeclan
  • 2,567 posts
Posted 21 September 2025 - 07:01 am
Is this one up in the miles?
Ridges in the clutch basket where the plates contact can cause this.
#6 dapleb
  • 18,378 posts
Posted 21 September 2025 - 07:19 am
Yes def up on miles! Thanks for the info. I will put that on the list of checks.
#7 Bjørge
  • 1,894 posts
Posted 22 September 2025 - 12:01 am
I filed off some ridges on my Mk1, but if it made a diff I don't know. New clutch plates - lovely clutch😎. Some 110k ish kms on the clock
#8 MickC
MickC
  • 432 posts
  • TDM model: 1995
Posted 28 September 2025 - 03:44 pm
Clutch drag will do this..Not releasing properly.
#9 dapleb
  • 18,378 posts
Posted 05 November 2025 - 10:08 pm
Ahhh the clutch cable freeplay spec is 8 to 12 mm ...not miles. That may be the problem! Will know by summer.
