Breakdown - RAC
20 replies to this topic
#1 MarkyMark
MarkyMark
  • 981 posts
Posted 04 May 2007 - 12:01 pm
53 TDM900 = Broke down.
RAC man and myself reckon battery too low to supply lights and fuel pump so. Sugests alternator not working. Jump starts, but less tha 12v accross battery when revving.
RAC phones their "technical people" and he advises buying a new battery. I was slightly suspicious, because they used to scam car drivers with battery sales a few years ago,
Anyway, RAC takes me to George white in Slough. I buy new battery £75 and we fit it. Same problems. Battery not getting anythin into it when engine revving.
Sugests alternator problem (just like before battery purchased) ranting.gif , so RAC man gets me recovered home. £75 quid wasted.
Is this an alternator problem? Is there a rectifier? I know rectifiers burn out. That sounds cheeper than an alternator.
Anyway, I now have to convince RAC to refund £75 for unneeded battery.
XT1200Z - Big and bouncy
GTR1400 - Chaufer the wife.
XT660Z - Fun and commute.
TDM900 - Yellow.
#2 MarkyMark
MarkyMark
  • 981 posts
Posted 04 May 2007 - 02:44 pm
Well - blow me
Service Manual
- TROUBLE SHOOTING 9-6
- - Faulty Lighting or Signaling System
Headlight Bulb Burnt Out - potential cause = faulty rectifier.
I changed a headlight bulb a week ago.
How come some rectyifiers cost £4.00 and a TDM rectifier costs £90
A rectifier is a rectifier ??????????????????????///
Edited by MarkyMark, 04 May 2007 - 02:49 pm.
TDM900 - Yellow.
#3 TonyDevil
Posted 04 May 2007 - 02:54 pm
QUOTE(MarkyMark @ Fri 4th May 2007, 03:29 PM) <{POST_SNAPBACK}>
Well - blow me
Service Manual
i've got a spare brandnew Electrexs RR98 heavy duty regulator sitting in my garage in Wokingham.
dunno if its the correct one, but its the model that fits the mk1, lemme know if you want it.
#4 MarkyMark
MarkyMark
  • 981 posts
Posted 04 May 2007 - 04:01 pm
Cheers Tonesk - Just found pool of crap watery shite in white side connection - Might just be that. Need Ohm-meter to test Rectifier. Might invest in meter - cheeper than a rectifier
TDM900 - Yellow.
#5 TDMTAM
Posted 04 May 2007 - 08:08 pm
QUOTE(MarkyMark @ Fri 4th May 2007, 04:46 PM) <{POST_SNAPBACK}>
Try this fault flow chart ot see if it is the RR.
http://www.electrosp...ult_finding.pdf
#6 ChrisG
Posted 07 May 2007 - 08:30 am
Most people who've had a regulator fail have had the opposite problem, way too much voltage when revving the engine. Mine was making over 17.5v at 2500 rpm and cooked my battery. If you can get your hands on a meter it's probably worth checking it before replacing. If there's less than 12v across the battery when revving then it sounds like wither the altenator has failed or the regulator has blown completely and nothing is getting through. Volt meter on the cable in to the regulator should tell you something but bear in mind it's AC not DC at that point, most multimeters have built in rectifier though.
#7 MarkyMark
MarkyMark
  • 981 posts
Posted 07 May 2007 - 06:54 pm
Thanks TDMTAM & ChrisG
Cannot start the bike on battery.
Can start with a jump from a car, but as soon as remove jump leads, reading accross the battery terminal starts to drop. Revving has no effect on reading accross terminals.
Still considering what to do. Unfortunately summer bikers have my local George Whites booked up for the next 4 weeks.
Service manual from JBX shows how to test a RR, but only shows 3 connectors. My RR has a black socket with three connectors in, and a white socket with three connectors in. Not sure which side to test.
Probably in too deep with the DIY diagnosis. Will have to fork out cash.
TDM900 - Yellow.
#8 ChrisG
Posted 07 May 2007 - 07:54 pm
Sounds like nothing comming out of regulator, but the question is is anything going in?
Haynes manual reckons trace the wire from the alternator to a plug, should be a 3 pin. Measure the resistance between each of the 3 wires (total 3 readings). Not got figures for a 900 but a Mk1 should be 0.2-0.3 ohms, and a Mk2 0.23-0.35 ohms so 900 is probably similar. Then check resistance of each of the 3 to earth, should be infinate. Anything dodgy there it's likely to be a knackered alternator, if not it's the regulator.
#9 Edman
Edman
  • 157 posts
Posted 08 May 2007 - 07:36 am
QUOTE(MarkyMark @ Fri 4th May 2007, 04:29 PM) <{POST_SNAPBACK}>
Well - blow me
#10 MarkyMark
MarkyMark
  • 981 posts
Posted 08 May 2007 - 07:27 pm
QUOTE(Edman @ Tue 8th May 2007, 08:21 AM) <{POST_SNAPBACK}>
No Edman - Your the first. blink.gif Thanks for the offer. unsure.gif I'll just check with some of the other 900 riders before I make my mind up.
TDM900 - Yellow.
#11 Guinness
Guinness
  • 1,657 posts
Posted 12 June 2007 - 06:19 pm
whats the update?
on the electrics... figured ild better specify.
get them here
#12 MarkyMark
MarkyMark
  • 981 posts
Posted 12 June 2007 - 08:13 pm
Thanks for the interest Guiness
Bike still with George White in swindon. They have diagnosed it as the alternator failure (3 weeks ago) but seem to be having trouble obtaining a replacement from Yamaha.
Sufferring serious bike withdrawal.
Guiness - I was thinking - we aught to track faults with 900s as it is a fairly new model. My alternator failed at 48,000 miles, that could be helpfull to other 900 owners. Are 900 alternators subject to failure. What other major component failures have other 900 owners experienced? Is this a candidate for a sub-topic under the knowledge base?
Begining to worry - RTT only 4 weeks away.
Edited by MarkyMark, 12 June 2007 - 08:14 pm.
TDM900 - Yellow.
#13 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 17 June 2007 - 05:46 pm
QUOTE(MarkyMark @ Tue 12th Jun 2007, 08:58 PM) <{POST_SNAPBACK}>
Over on ThumperTalk, I read a thread where a DRZ had suffered an alternator failure
the Board's acknowledged expert, and general all round expert, reckoned not changing the oil at recommended service interval can cause the alternator to fail to due the oil becoming thin and not being able to disapate the heat away (or something like that)
I'm a bit sceptical about it, but I thought I'd throw it in just as an idea
#14 TonyDevil
Posted 18 June 2007 - 09:09 am
will they give you a courtesy bike while yours is being repaired?
#15 MarkyMark
MarkyMark
  • 981 posts
Posted 22 June 2007 - 09:54 am
OK - bike back - good as new. - Couple of commutes Swindon<>Winchester and (touch wood) no problems.
Not that I sit in front of my computer touching wood you understand happy.gif
TDM900 - Yellow.
#16 wicklamulla
Posted 22 June 2007 - 10:11 pm
Mark did it cost ya an arm and a leg or was it ok on the bill front ?
#17 MarkyMark
MarkyMark
  • 981 posts
Posted 23 June 2007 - 10:28 am
Cost £350
Thats £250 parts
£45 labour and £55 VAT
TDM900 - Yellow.
#18 wicklamulla
Posted 23 June 2007 - 10:59 am
QUOTE(MarkyMark @ Sat 23rd Jun 2007, 11:13 AM) <{POST_SNAPBACK}>
Cost £350
Thats £250 parts
ouch ! but at least it's now fixed and your happy. can you weatherproof that connector that got waterlogged that was the possible cause of your woes ?
#19 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 23 June 2007 - 11:31 am
Cost £350
Thats £250 parts
shit - thats expensive
didn't they offer you the chance to have it rewound instead of a new one
I have had many done at much less than the price of a new replacement
#20 MarkyMark
MarkyMark
  • 981 posts
Posted 24 June 2007 - 10:43 am
I am not knowledgeable enough in these things to suggest options to them. But the way the world is it appears it is cheeper to replace than repair these days - simply based on the labour involved.
I spent a few weeks trying to sort it out myself - convinced it was the regulator. So I also laid out £45 quid on a second hand flea-bay rec/reg - in case anyone interested. I assume it is good, cos all the readings from the multi-meter are the same as the one on the bike.
I shall have to stay out of the pub for a couple of Friday nights to get the budget back on track.
Also noticed chain sagging a bit. First chain and sprocket set at 30K, so hope it lasts till 60K. But once it started last time, it went fast. Hope it lasts for another 3/4 K for the RTT.
Can anybody improve my translation??????????????,
"Ver Ish ein Yamaha motorkranken menderkind; Mine chain und sprocket been kaput - Shnell"
TDM900 - Yellow.
