Rear Calipot Overhaul - Tdm850
21 replies to this topic
#1 wicklamulla
Posted 05 May 2007 - 05:32 am
well i split and overhauled me rear clapper during the week, initially i cleaned up the seal grooves and reused the old seals but on pressing the piston back into one half i tore the poor little endangered species......... this made me paranoid as i was then wondering if i had damaged the udder seal on the udder caliper half ???!!!! anyway i took this as an excuse to order some new ones ! i removed the pistons by using the compressed air can you see below in the pics. basically i popped the pistoons into a zipseal bag and into the freezer overnoight, then popped each half of the caliper into a waterproof zip seal bag and immersed them into a basin of boiling water (note; i left the top of the bag open to allow fer steam dispersal as i didn't want damp caliper bodies) ferra bout 15 mins, then rather swiftly removed the caliper and checked twas bone dry, wrapped it up in a tea towel (to retain the heat) rushed up to the shed, removed and inspected the pistons (from freezer) and gave em a quick squirt of brake cleaner and dried em off, fitted me new seals & coated them and the pistons with fresh brake fluid and as gently and as accurately as possible i pressed "them home". some pics below. i basically was concerned about splitting the caliper but i followed GG's example and though "what the hell". ting is i tried reverse bleeding it last night by trying to inject the brake fluid up thru the bleed nipples.....fecking joke that was ! oil prolly give it anudder go this mornin and failing that take it to a dealer to sort!
Edited by dapleb, 24 June 2012 - 07:52 am.
Added model info to title
#2 TDMTAM
Posted 05 May 2007 - 08:22 am
QUOTE(wicklamulla @ Sat 5th May 2007, 06:17 AM) <{POST_SNAPBACK}>
Try sucking it through using the syringe instead.
#3 SteveGlover
SteveGlover
  • 857 posts
Posted 05 May 2007 - 09:06 am
QUOTE(TDMTAM @ Sat 5th May 2007, 09:07 AM) <{POST_SNAPBACK}>
Or just suck it through a long pipe attached to the bleed nipple - once you get the fluid flowing you can usually bleed them easy enough.
Good pictures Wicky, looks a good job.
#4 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 11 May 2007 - 06:15 pm
Why you freezing the pistons, and heating the bodies - they are not (or shouldn't be) and interference fit at room temp.
A bit of brake fluid on the seals and on the leading edge of the piston and it should slide in nicely
don't use anything other than fresh brake fluid to clean the seals and dust seals - anything else can make them swell and expand causing issue with re-assemble / getting them back into the grooves etc
have you dis-assmbled the master cylinder?
you've probably got something crap in their stopping it from bleeding correctly - take out the plastic elbow, where the pipe from the reservior attaches to and make sure there is no crap in there
#5 wicklamulla
Posted 12 May 2007 - 04:32 am
will do, cheers GG.
#6 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 12 May 2007 - 06:20 pm
QUOTE(wicklamulla @ Sat 12th May 2007, 05:17 AM) <{POST_SNAPBACK}>
will do, cheers GG.
what ya doin up at 5:17am?
not still trying to get your brakes bled are you?
#7 laughin in a windstorm
  • 864 posts
Posted 13 May 2007 - 05:43 am
ah ha so the man who once told me he couldn't can, good job fellow humany thing
#8 wicklamulla
Posted 13 May 2007 - 12:53 pm
LOL @ LIAW !!! ya i hadda have a go some time i suppose !
GG i was up all noight int garage playing/stroking/pawing/gnawing/caressing No.7 ! wife was happy when i rubbed me cowld blue knob against her left buttock cheek at that time................anyway we awoke "some time later" as the cats were farting in me face and meowing fer breakfast.............FFS tis only 7.15 am !!! so not much sleep afterall.
#9 tdm850rider
Posted 14 May 2007 - 05:49 pm
TMI
#10 roadrunner
roadrunner
  • 2 posts
Posted 03 September 2008 - 07:47 pm
good bit of ifo i picked up ere mate cheers
#11 dapleb
  • 18,392 posts
Posted 24 October 2012 - 07:57 pm
powerhouse-uk on ebay now sell a kit which includes the calipot half 'o'-rings. Got a set to try oot, will report back when fitted...2013 ish maybe. They look and feel exactly the same as the OEM seals.
#12 wicklamulla
Posted 25 October 2012 - 09:35 pm
thas handy infermation indedy doo daah.
#13 LewisBlackburn
LewisBlackburn
  • 1,748 posts
Posted 25 October 2012 - 11:41 pm
I could probably do with doing this, especially when i have the advantage of a full spare rear line so have no excuses.
Im LAZYY !! OK !
#14 wicklamulla
Posted 08 August 2016 - 12:48 pm
Hello all,     just revisiting this again as i tink the rear caliper cud do with anudder overhaul.   Anyone ever managed to get the rear pistons in stainless steel ?
#15 wicklamulla
Posted 08 August 2016 - 12:56 pm
ahhhh i just phoned powerhouse-uk on 01246 260665 (cheers Dapleb)  and ordered a seal kit and 2 stainless pissedons.
#16 dapleb
  • 18,392 posts
Posted 08 August 2016 - 02:44 pm
They is bloody helpful that company.
Hmmm wonder if my post above aboot reporting back means I have a rear brake rebuild kit somewhere!!! Anyways the front pistons and seals were from them and went back together fine.
#17 wicklamulla
Posted 08 August 2016 - 04:06 pm
de ting is the rear pistons on No.7 are 16 year old now and may well be a bit 'weathered' so i ordered the stainless versions at £22 each.
#18 dapleb
  • 18,392 posts
Posted 08 August 2016 - 04:08 pm
When ewe finished cleanin up yer old calipots they looked a lot loike a cat! Thats a neat trick!
#19 wicklamulla
Posted 14 August 2016 - 11:31 pm
well the overhaul kit is pricey but quite impressive i guess!    will see how it goes.
#20 fixitsan
  • 4,852 posts
Posted 15 August 2016 - 09:59 am
I've got a seal kit coming for mine. I got the calpot from a 1980 something FZ something (3HE iirc)
I'll check in if i get stuck
