Gearbox bearings
18 replies to this topic
#1 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 19 November 2007 - 10:39 pm
The two shafts in the gearbox both have a bearing at either end. Four bearings in total, but Yamaha say that only 3 are replaceable.
On the output shft (one with the sprocket on eventually), apparently the larger bearing isn't replaceable with a new one.
Is this right?
Mike
currently owned ....
#2 dandywarhol
Posted 19 November 2007 - 10:42 pm
QUOTE(stormy @ Mon 19th Nov 2007, 10:24 PM) <{POST_SNAPBACK}>
Is this right?
Mike
#3 dapleb
  • 18,377 posts
Posted 20 November 2007 - 09:22 am
Did they say why? Bearing not available? Not possible to remove/fit?
Didn't remove mine.....but if the other end is replaceable dunt see why sprocket end ain't!?
Attached File  oshaft_storm.JPG   90.74KB   47 downloads
#4 lemonentrails
lemonentrails
  • 149 posts
Posted 20 November 2007 - 10:57 am
I beleive output shaft and bearing come as one part.The bearing will come off but sourcing from anywhere but Yam may be a pain, as the bearing has a locating clip groove and and a small roll pin in the outer race. 3vd models anyhow.
Mk1black ()60+k,micron system, nice but not naughty,k&n,dynojet stage 1. port job, polished head and pistons . lowered h/bars.lowered yokes 7mm ish ,Avon Storms ,top bannanas!EBC DISCs and damned fine they are too!!!..rust an all...oh and a cracked frame.Now welded up and so far so good .....Mk1 with squire sidecar sidecar,metmachex deep brace swing arm, suzuki 6" rim &car tyre , whole plot lowered a bit.sidecar heater to keep madam cosy! LL forks coming to a bike near me soon.
#5 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 20 November 2007 - 11:49 am
QUOTE(lemonentrails @ Tue 20th Nov 2007, 10:42 AM) <{POST_SNAPBACK}>
I believe output shaft and bearing come as one part.The bearing will come off but sourcing from anywhere but Yam may be a pain, as the bearing has a locating clip groove and and a small roll pin in the outer race. 3vd models anyhow.
Thats what Yamaha are telling me, i.e. it isn't available as a replacement bearing.
However, at the end of the day, it is just a shaft through a bearing. I can get the bearing from a local bearing stockist, i.e. the right size including the groove, and whilst the anti-rotation pin is desirable, its nothing that bearing loctite won't sort. The large bearing is the same size as the large bearing on the other gearbox shaft, so I don't understand why Yamaha are reluctant to sell it for this application.
Let you know how I get on.
Mike
#6 dapleb
  • 18,377 posts
Posted 20 November 2007 - 12:03 pm
What bit of Yamaha are you talking to? Technical dept? Or a dealership?
#7 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 20 November 2007 - 12:34 pm
Those types of bearings (groove and locating peg) are freely available, as they are used on many two-stroke crankshafts including X7, RG250, RD350LC & YPVS
#8 ChrisG
Posted 20 November 2007 - 12:44 pm
Have you had a rummage through the microfiches yourself? Think there's a set in the knowledgebase, if not this site has them but alas not the relevant part numbers.
#9 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 20 November 2007 - 03:04 pm
Well, despite all the warnings from Yamaha techies, I got the whole thing separated. Lots of heat, a hydraulic press and a lickle prayer and hey presto, a pile of bits on the floor!I've sourced a new bearing, a mere £18.75. Better than Yamahas' quote of £191.00 for the shaft and gear and bearing complete.
New bearing does not have the pin, but that is not an issue, as all that does is pevent the outer race turning. Given a liberal dose of Loctite bearing adhesive, plus the circlip in the groove and the cases being clapmed together rather tightly at that point, that race is going nowhere.
That said, it would not be any hardship to drill a small blind hole in the outer case and fit a pin.
Given that this engine obviously had a hard life and then a catastrophic stop due to the bigends failing, the gearbox shows very little wear, just full of metal slivers from the shells.
Photos of a 4TX rebuild will come later if anyone is interested.
Mike
QUOTE(dapleb @ Tue 20th Nov 2007, 11:48 AM) <{POST_SNAPBACK}>
Dealership workshop, but not the one who gave me the run around with the carbs though.
Edited by stormy, 20 November 2007 - 03:05 pm.
#10 wicklamulla
Posted 20 November 2007 - 05:41 pm
PK i wonder if that gearbox shaft thingy i bought would be of any use to Stormy ??
Edited by wicklamulla, 20 November 2007 - 05:42 pm.
#11 dapleb
  • 18,377 posts
Posted 20 November 2007 - 07:33 pm
QUOTE(wicklamulla @ Tue 20th Nov 2007, 05:26 PM) <{POST_SNAPBACK}>
Did it come with bearings (see pic)? Its the wrong shaft....but loike the man says...the big bearings are the same.
#12 Hartside Man
Posted 20 November 2007 - 11:14 pm
QUOTE(stormy @ Tue 20th Nov 2007, 02:49 PM) <{POST_SNAPBACK}>
You might find drilling into the outer race of a bearing a little harder than you think blink.gif (unless of course you have access to some very tough drills tongue.gif )
#13 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 20 November 2007 - 11:35 pm
QUOTE(Hartside Man @ Tue 20th Nov 2007, 10:59 PM) <{POST_SNAPBACK}>
I have!
let you know how I get on.
#14 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 26 November 2007 - 07:46 pm
QUOTE(stormy @ Tue 20th Nov 2007, 11:20 PM) <{POST_SNAPBACK}>
I have!
#15 Hartside Man
Posted 26 November 2007 - 10:33 pm
QUOTE(stormy @ Mon 26th Nov 2007, 07:31 PM) <{POST_SNAPBACK}>
Excellent
#16 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 27 November 2007 - 06:10 pm
QUOTE(Hartside Man @ Mon 26th Nov 2007, 10:18 PM) <{POST_SNAPBACK}>
Excellent
cobalt tipped drill and a lot of cooling oil and a well setup pillar drill.
and patience.
#17 Hartside Man
Posted 27 November 2007 - 08:06 pm
QUOTE(stormy @ Tue 27th Nov 2007, 05:55 PM) <{POST_SNAPBACK}>
and patience.
#18 Guest_E.T._*
Guest_E.T._*
Posted 28 November 2007 - 01:04 pm
#19 stormy
stormy
    RIP stormy
  • 1,637 posts
Posted 29 November 2007 - 01:01 pm
QUOTE(E.T. @ Wed 28th Nov 2007, 12:49 PM) <{POST_SNAPBACK}>
ho ho ho......
but thats what I meant about a well setup drill. Set it up, start it up, set to auto depth, walk away.
come back 30 mins later, job done.
