Fuel Tap Confusion
Fuel
18 replies to this topic
#1 BlueTwin
BlueTwin
  • 37 posts
Posted 28 May 2013 - 12:30 pm
Hi all,
hope you've made good use of the sunny bank holiday weekends!
I wondered if I could pick the collective brain about a 4TX fuel tap.  After stripping down last year to cure a failed pump I noticed there is a tap under the tank AND a tap on the side.  Seemed a bit wierd but I also found that there are some parts of a 4TX3 and it's a 1996 so all bets are off regarding it's pedigree... The under tank one works fine, just use it when the tank has to come off.  However the side OFF/ON/RES doesn't work as expected.  I haven't the bottle to check whether the reserve setting works right yet... because the bike seems to run fine with the tap set to OFF.  I noticed I'd not switched back to ON but only after around 25 miles - too much to be just draining the float chamber.  Tap looks like it's got everything connected sensibly... is there some clever function of the tap which I don't understand or is it kernackered?
cheers y'all
#2 RolfieB
RolfieB
  • 1,069 posts
Posted 28 May 2013 - 02:28 pm
This is the diagram you need. But note that hose no 45 actually goes to the spigot for hose no 31 & vicci vercci.
http://www.yamahamot...FUEL TANK&uID=0
Now I just fly everywhere.
Gone to new owner.
Black Mk2a
#3 Guest_Prof TDM_*
Guest_Prof TDM_*
Posted 28 May 2013 - 03:34 pm
Hi.
My 97 does the same,& works how it should on reserve,although it is connected correctly,do not know if reserve would work if tap was being used in the off position,    tank may be empty?
Cheers.
Prof.
#4 BlueTwin
BlueTwin
  • 37 posts
Posted 28 May 2013 - 03:56 pm
Cheers guys.
Rolfie, sorry to be a bit of a thicky but can you just clarify about the item 31/45 switcharound...
 - the fuel comes from the tank along two hoses item 24 = "on" and 23 = "reserve" from the thingy with two different pipes under the tank
 - they both go into the tap (27) on two of its ports, and the third must be the output (31 on this drawing) to the pump
 - the end of 31 goes into the fuel pump which pumps fuel back down 45 into the carbs.
I guess you switch 45 and 31 at the pump because the drawing is wrong?
Are all of the fuel tap ports correctly identified on this drawing?  Top pipe = ON, Middle pipe = RES, Bottom pipe = OUT.
thanks
#5 Chris
Chris
  • 341 posts
Posted 28 May 2013 - 07:05 pm
I'm watching this with interest as mine is the same.
I notice that the rate of flow is reduced when it is turned off but there's still enough fuel going through for sedate riding.
Reserve operation is still as you would expect - turn it on in a hurry if the engine stutters.
End result is that I don't turn the fuel off but this is a bit concerning as my carbs don't appear to have the extnded pipe in them that allows any excess fuel to drain out.
So, if the float valves weren't sealing properly I would end up with diluted oil!
#6 Guest_Prof TDM_*
Guest_Prof TDM_*
Posted 28 May 2013 - 08:05 pm
Good point, how about disconnecting pipe at carbs to see what flow,pressure like, i must admit i have'nt noticed  any fuel overflowing out of mine so far.
Prof.
#7 RolfieB
RolfieB
  • 1,069 posts
Posted 28 May 2013 - 08:09 pm
I was worried that mine were not connected correctly, so in between looking at this drawing & looking at the service manual I noticed a discrepancy & posted on here my hose positions & the discrepancy. Studley had also picked up on the discrepancy & posted about it but a while ago, but also confirmed my hose positions.
So the top hose on the frame tap (No 24) is your main on (front spigot on tank tap). Middle hose (No 23) is reserve (rear spigot on tank tap), I believe this should have a plastic collar on it to denote reserve, not that it would make any difference if connected correctly. I think it's just for ease of identification.
Bottom hose (No 31) goes to the left spigot on the pump,  Where the diagram shows No 45 (it has an arrow on the pump by the spigot denoting flow).
The next hose attached to the pump (middle spigot) is No 45 which is the vacuum pick up from carbs. This hose is attached in front of the carbs. If you look in the intake section on the link it's No1 joint carb
The last hose on the pump No 48 is the supply to the carbs (attaches in the middle at the back of the carbs if you pull it off watch out for the little in line filter, position is correct in diagram).
If all is connected correctly Then my first guess would be a seal gone in the tap.
Edited by RolfieB, 28 May 2013 - 08:12 pm.
Gone to new owner.
Black Mk2a
#8 Guest_Prof TDM_*
Guest_Prof TDM_*
Posted 28 May 2013 - 08:26 pm
Ok RolfieB.
Does your engine run with tap in off position?  Thanks for above info,
Prof.
#9 RolfieB
RolfieB
  • 1,069 posts
Posted 28 May 2013 - 08:37 pm
Never tried to be honest, wont have chance to try until Saturday as will be in Amsterdam for the rest of the week :clapping: .
I was more concerned that reserve wasn't working as I'd covered 190 miles before bottling it & filling up, rather than finding out they were connected wrongly and running out of fuel. But found out on Saturday that reserve works as it should.
Will check on my return & let you know.
Looking at the diagram I would suspect it's no 28 (valve packing) if anything has gone amiss, not a lot else in the tap.
Edited by RolfieB, 28 May 2013 - 08:45 pm.
Gone to new owner.
Black Mk2a
#10 BlueTwin
BlueTwin
  • 37 posts
Posted 29 May 2013 - 12:05 pm
Ho hum.. checked the oil level this morning, it's gone up again.  Now up to the top of the window and looking thinner than normal - although the apparent viscosity might be down to the outdoor temperature or my imagination.  Will do a sniff test of the filler cap, but I think I know the answer already.  I had the hydraulic lock and petrol in the sump only a few months ago - drained it down, changed the fuel pump, ran some cleaner through the carbs, vowed to leave tap in the off position whenever left for more than 5 minutes... and here we are again.  Looks like fuel tap isn't the only thing that's not playing ball... I love riding this bike, but it's doing my head in at the moment.  Hopefully stripping down the carbs and giving them a good spruce up will also cure the terrible misfire on mid throttle at motorway speeds too...
Thanks for the continued useful info.
#11 Studley Ramrod
Posted 29 May 2013 - 02:42 pm
Was that a new fuel pump you fitted BT ?
#12 BlueTwin
BlueTwin
  • 37 posts
Posted 29 May 2013 - 05:15 pm
Brand spanking new in its Polythene from Weeemoto.  So now I have a part-used spare.  Which is handy.  I also have an old electric pump of a carbed R1, just in case I ever decide to do a conversion.  All the gear, no idea, as they say!
#13 Guest_Prof TDM_*
Guest_Prof TDM_*
Posted 30 May 2013 - 06:46 am
Sorry to read this BT, for the last 5yrs my tap has been like this,may be im pushing my luck,but always keep a close eye,nose on things,hope you get sorted.
Prof.
#14 BlueTwin
BlueTwin
  • 37 posts
Posted 30 May 2013 - 09:07 am
cheers Prof,
had a rummage in the "cupboard of crap" last night and found the fuel tap repair kit which has the funny washer thingy and o-ring.  Away for a few days but will swap them out on my return and post the pics.  Bon weekend tout le monde.
#15 Guest_Prof TDM_*
Guest_Prof TDM_*
Posted 30 May 2013 - 03:08 pm
Hi BT
Also had a rummage  found a spare tap,took front off,looks to me how it works, top is reserve,  not main feed, that is middle spigot, gonna do a wet test as soon as  i can.
Prof.
#16 Guest_Prof TDM_*
Guest_Prof TDM_*
Posted 30 May 2013 - 03:56 pm
Hi BT
Prof.
Yep, it only works this way round, to match the switch,      top =reserve,  middle =main,  bottom=pump with inlet arrow. so 23&24 need to be swopped over in the diagram.
Prof.
#17 Sidarta
Sidarta
  • 845 posts
Posted 30 May 2013 - 05:04 pm
Messrs. good day!
We can not forget that the carburetor float needle, is the principal to control the entry of fuel into the engine. If the needle tip is worn or the float is out of level, there will be excess fuel. In my 4TX 2001 I had the intake manifold cylinder No. 1 (left), totally flooded. The repair torneirinha is new and the fuel pump is in perfect condition. Raised to the level of the float 9 mm. Measuring the flat face of the bowl of the carburetor to the highest part of the float. That's because I could not determine what the water line on the outside of the tank. These references line level for 2001 are different from other models. Also installed new needles and needles headquarters. The carburetor is mounted, but not yet installed on the bike. I'm changing the chain of command and changing the valve shims. Everything is disassembled.
Excess fuel can cause: increased consumption, hydraulic lock and contaminate the oil damaging the engine lubrication. Leaking fuel, stay tuned and find the cause quickly.
Cheers!
Sidarta
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#18 RolfieB
RolfieB
  • 1,069 posts
Posted 01 June 2013 - 09:21 am
Ok RolfieB.
Prof.
Just ran my bike up with the tap in the off position & the results are as they should be, the bike ran for a few minutes then coughed, spluttered & farted then died.
Back to the on position & burst into life again.,
Prof.
Bit confused by this post as in an earlier post you say that reserve works as it should, but now you're saying you need to swap the hoses going to the tank tap :dunno: .
Gone to new owner.
Black Mk2a
#19 Guest_Prof TDM_*
Guest_Prof TDM_*
Posted 01 June 2013 - 11:45 am
Hi RB.
     I was refering to the fuel pipe diagram,24main top   23res  middle,    According to my test,  23 res top  24main middle, this is how mine is.when you look at the inside of the frame tap this does look right,  Hope this makes sense. I did say mine still runs on off,tap needs sorting,  I did this test on a spare tap i didnt realise i had,  will be putting it on a. s. p.
 Prof.
Also tagged with one or more of these keywords: Fuel
