California Fuel System
California Fuel Diagram
5 replies to this topic
#1 MikeyMex
MikeyMex
  • 27 posts
  • Location:Jalisco the birthplace of Tequila and Mariachi
Posted 04 March 2018 - 06:28 pm
Quick question, where does the vacuum hose from the fuel pump get attached too?
I can't find a drawing of this anywhere, I had a fuel problem and I think this may have been incorrectly fitted before which is why I had a fuel/oil issue.  This is a photo of the yamaha sticker on the inside of my fuel tank.
Thank in advance
Mikey
Oh by the way I don't gotta fuel tap, somebody previously disregarded it and now gasoline goes direct from tank to pump to carb without being able to turn the gas off or switch to reserve.
DT50M '78, KH100EX '86, RD350LC (many), RD250LC '83, VF400F '83,  Z200 '77, RD400 '76, LTD450 '88, R45 '80, R100RS '82, GSX750SE KATANA '84, FJ1200 '92, GPZ750A1 '84, R100CS '78, (then came 17 years in Mexico and hundreds of Chinese scooters later.... I finally get another real bike) TDM850 MK1 '91 and a KLR 650 '88 for the rough stuff.
#2 Studley Ramrod
Posted 04 March 2018 - 07:09 pm
It goes to a brass stub on the inlet of no.1 cylinder.
#3 thelodger
thelodger
  • 150 posts
Posted 04 March 2018 - 07:31 pm
Mikey
As the petrol tap has been removed I don't think you would need the vacuum pipe connected but the carb end ( the brass stub referred to above ) should be blanked off as well.
I hope I have this right !
#4 Studley Ramrod
Posted 04 March 2018 - 07:38 pm
Err, yes, you would need the vac pipe connected as it provides vacuum for the mechanical fuel pump.
#5 mh1848
mh1848
  • 507 posts
Posted 05 March 2018 - 12:31 pm
as Studley says you need vacuum to pump - plus you need to ensure other vacuum stub is blanked off - but you also need to be able to connect to it to balance carbs - i have a length of hose attached to unused vacuum stub with a blanking plug so it is easier to connect to manometer
#6 MikeyMex
MikeyMex
  • 27 posts
Posted 11 March 2018 - 03:51 am
Thanks guys,
I will put it where it's supposed to go now.  Yes there is another blanked off hose with I assumed was for balancing.
Gracias a todos.
Mike
Also tagged with one or more of these keywords: California, Fuel, Diagram
