I saw a DIY project for an electronic carburetor balancer on this thread here and decided to give it a go myself with some mixed results.
The original project centered about a Yamaha Venture Royale (with cheese). I've experimented with bar graph displays and a low pass filter to smooth out the readings.
It seemed to work, when it did, but I've managed to damage two sensors on cyl one, twice now.
I think it may be down to a shock the 1 bar sensors experience everytime the engine first starts, due to the 270 firing order and the 425ccs of each cylinder.
The sensor on cylinder one has failed each time. The high peak reading on C1 is the sensor having been overstressed and about to fail.
I think the solution would be to put a restrictor inline with each hose. That or buy 2bar sensors. Ouch.
In the end I opted to use a pair of tall/narrow olive oil bottles. I got the transmission fluid level to stay stable for over 4 mins so I reckon you can't argue with that. Much cheaper too!
Edited by TYREDNGRUMPEE, 15 July 2014 - 08:04 am.
