Header Pipe Flanges
Exhaust
4 replies to this topic
#1 danjohnston89
danjohnston89
  • 63 posts
Posted 25 September 2020 - 01:20 pm
I have a cracked flange on one of the header pipes and although you can buy replacement ones I am struggling to see how they fit onto the downpipes themselves as they come as one piece. Does anybody know how they are supposed to be replaced as they can not slide over the exhaust from any point, thanks. [attachment=13660:685EDD76-FFED-4CFA-903F-324DE7F558C6.jpeg
Edited by danjohnston89, 25 September 2020 - 01:21 pm.
#2 Studley Ramrod
Posted 25 September 2020 - 03:00 pm
You'd have to cut the pipes then weld 'em up after slipping the collars on, sure a local fab shop would do it for you.  From memory, Kawasaki do a 2-piece collar that might fit, save you having to cut n weld the pipes.
#3 Bjørge
  • 1,894 posts
Posted 26 September 2020 - 08:59 am
...or it may be easier to cut'n weld the flanges? A bit more slack then, pipes really need to be welded back to exact position and direction...tack welded in situ would be necessary on pipes
#4 danjohnston89
danjohnston89
  • 63 posts
Posted 26 September 2020 - 10:31 am
Thanks for the reply chaps
#5 dapleb
  • 18,382 posts
Posted 26 September 2020 - 11:14 am
In the pic you can see they have pigeon pooped the exhaust back together.
As SR said, there was some talk of some split collar Kawasaki ones but not sure what happened with them.
Also tagged with one or more of these keywords: Exhaust
