Hello fellow TDM enthousiasts,
I hope you can help me identify the problem with 1995 75k km tdm.
He has developed a backfire through the carbs since a few weeks.
I had a similar problem about a year ago. Then it turned out to be a small coolant leak from the thermostat housing that dripped on the RH sparkplug lead. That caused backfires at low rpm.
Once the leak was fixed, the backfires went away.
Now they are back... in force...
I saw the coolant leak had returned and replaced the o-ring in the thermostat housing. Replacing it made me spill a bit of coolant on the egine.
As my fuel consumption was pretty high, I ordered a full carb rebuild kit from kedo. not only changed out the emulsion tubes and needles,but also all gaskets and jets.
After having reassembled carbs and cooling system, engine started up , but ran very bad.
Diside it could be the spilled coolant, so cleaned the leads, plugs an engine from all coolant residue.
Ran much better. But as soon as I turned of the choke, rpm pick up became irratic.short burst of throtlle cause backfires through the carbs.
once above 3000rpm, the problem goes away.
Any idea's?
Could it be to lean on idle? 3turn out on the idle screw
My tdm is equipped with a devil single silencer.
But has run for over 8000km smooth over 2013
Rubbers between carbs and manifold are cracking, but the "spray test" shows no changes in rpm when spraying on them.
have ordered in new ones to be sure.
valve clearance...??
fuelpump?
airleaks???
Any help would be much appreciated
Thx
Tom
