Carb Identification Tdm 850 - 4Tx?
Carbs 4tx TDM 850
16 replies to this topic
#1 Rockadam666
Rockadam666
  • 7 posts
Posted 16 July 2019 - 09:06 pm
Hi All,
I am new to the TDM family, just bought a TDM 850 a couple of months back. So far havent been off to the best of starts.
I had a running issue around 4k revs, which made the bike buck, bog down, and eventually die, having to have the choke on to make it run again to get it home.
With some investigation I believed I narrowed it down to a couple of things, the airbox not seating correctly, letting a lot more air into the mix. Also, the carbs needed a good service/set up.
Long story short, I serviced the carbs and refitted them took it out for a ride and the same thing was happening. So out with the carbs again and then noticed you could take the full emulsion (what I think is the emulsion tube) sleeve off with a spanner after taking one of the jets out. I then proceeded to try and take the emulsion tubes out and have absolutely f***ed one with my hamfisted annoyance at the whole situation, shortly after realising they were pressed in at the factory....great.
I am now trying to find a replacement carb set:
My carbs are: 4TX4 40 TO21
I found a set on ebay, with the code: 4TX4 40TBY5
Can anyone tell me if they are similar? the same with different numbers? or completely different? I need a bit of help deciphering the codes.
After reading the pinned model list, I believe my bike to be a 1998 registered in 2000.
Any help, would be much appreciated.
Link to my gdrive with some photos in: https://photos.app.g...eszJwHAskpg2vh7
#2 Studley Ramrod
Posted 17 July 2019 - 09:44 am
Going off the video you linked, your carbs are off a '99-'01 which are 4TX4 and for the TDM850 mk2a.  Don't think the other number make any difference.
#3 Rockadam666
Rockadam666
  • 7 posts
Posted 17 July 2019 - 08:41 pm
Awesome, thanks for the information. I will look at getting the ones on ebay then :)
Thank you
#4 Studley Ramrod
Posted 18 July 2019 - 08:33 am
If you drop a link to the carbs on ebay, we'll tell you if they're suitable. :good:
#5 Rockadam666
Rockadam666
  • 7 posts
Posted 22 July 2019 - 08:02 pm
Hi, Apologies for the late reply,
These are the carbs I am looking at getting:
https://www.ebay.co....utorefresh=true
#6 wicklamulla
Posted 22 July 2019 - 11:22 pm
loike the ebay ad says they are fer a 2002 TDM 850 and look rough in my onion.  They will fit a 1999-2002 TDM 850.  I reckon they are not for your 1998 model.
#7 Studley Ramrod
Posted 23 July 2019 - 08:50 am
Seems to be some confusion over the year of the bike.  Carbs off his bike are deffo mk2a carbs, so, either someone swapped the earlier carbs for later wans, or his bike is a '99-'01 mk2a.
Do you have a temp gauge or a fuel gauge Adam ?
#8 wicklamulla
Posted 23 July 2019 - 10:20 am
yep i've seen a few with the 'incorrect' carbs fitted and the TPS wiring bodged to suit,  i reckon people buy a used set of TDM carbs. off the net and only realise the differences once they unbox the packaging then think 'i will make these fit' !
#9 Rockadam666
Rockadam666
  • 7 posts
Posted 23 July 2019 - 04:41 pm
Thanks for the help guys, it is much appreciated.
Yea I don't really want to buy those carbs for that much money as they don't look that great, but I am stuck.
Here attached is a link to some more photos.
Yes it has a fuel gauge.
#10 wicklamulla
Posted 23 July 2019 - 05:10 pm
Ads,   if that pic you attached of the TDM with the fuel gauge is your boike then those carbs on ebay will fit.  Is there a white sticker under the seat and on the nearside frame rail that states 4TX4 i wonder?  Try these people fer spares.  There are a few places in Frants and The Nedderlands that specialise in the TDM/TRX.    https://www.gn-moto.com/
#11 Studley Ramrod
Posted 24 July 2019 - 09:40 am
GNMoto are probably the best place to buy some carbs, their prices are reasonable and they will highlight any faults if there are any.
#12 wicklamulla
Posted 24 July 2019 - 08:48 pm
Studley can ya replace the emulsion tubes and needles on MK2a carbs?  I know ferra fact there was a time you couldn't but i do believe a kit has been produced in recent years to facilitate an overhaul.
#13 dablik
  • 10,892 posts
Posted 25 July 2019 - 08:03 am
If thems a press fit surely you could have them out !! a member mechanic i think from Portugal managed to change em..
#14 Studley Ramrod
Posted 25 July 2019 - 08:40 am
Yes, if you know how to press them out and in.  Kedo.de used to sell the emulsion toobs.  Not seen or heard of a kit though.  NRP Carbs might also have, or be able to obtain, the toobs.  Might need to ask for toobs for the BDSR38 carbs.
#15 Rockadam666
Rockadam666
  • 7 posts
Posted 29 July 2019 - 09:26 pm
Awesome, thanks guys, I have managed to pick up a set of carbs and will try those first. If they do work I will continue with trying to salvage the broken ones as well and report back my findings.
#16 wicklamulla
Posted 30 July 2019 - 11:22 pm
let us know how it goes.  I may be interested in buying yer old set of carbs. if yer selling them.
#17 rednikmarto
rednikmarto
  • 2 posts
Posted 11 September 2019 - 12:09 am
Hi Adam,
Here is a file for you: https://rednikmarto....vice/BDSR36.doc
I assembled it from couple of manuals.
It addresses also our carbs BDSR38/2.
Here are some photos and text i left, basically about required tools to replace needle jets of BDSR38 (my previos bike was TDM 850 4TX).
Suspected my needle jets to be worn. Why ?
Basically the behaviour of throttle handle - acts so sharply, almost no smooth transition from close to open throttle. Second reason - orifices are eliptical.
With BDSR38 the needle jet is hard to pull-out, It is a press-fit. Hmm.
Everything started by realizing a print error in Yamaha manuals.
In specifications of later 4ТX for the needle jets it says "P-O", but in reality "О" is not a letter but a digit "0" which changes all.
I realized that when i found a table with calibrated orifices of Mikuni Needle Jet.
Size "P-0" corresponds to 2.65mm.
So it means that we can tap M3x0.5mm thread in it and pull it out using the threaded section.
This "kit" was made for my by a friend (end. Nikolay Petrov - thanks mate).
The threaded rod must be class 8.8 at least, the lower grade do not survive, the section with thread M3x0.5 breaks - i broke a lower grade threaded rod.
Luckily the piece just unwinds easily.
Here are new and old needle jets (emulsion pipes). New are available at Kedo.com.
Here it is M3x0.5 close view and "black" threaded rod, grade 8.8:
The old and new membrane covers of BDSR38 (new are available from Kedo.com, the nylon packages are theirs):
After the threaded rod is screwed into old needle jet right before start to pull it out:
While pulling it, RHS wrench "10" holds, and LHS "10" rotates, Needle Jet starts to get out with creaky noise:
The mandrel has dual functions.
At its front a tap M3x0.5 is mounted, the grub screws (smaller hex) fix it, at the tail of the mandrel some lever is required for tapping (larger hex):
The new needle jets are mounted, close view of mandrel.
The new needle jets must survive the "press fit", the mandrel should touch only outer periphery of the needle jet:
These are my slide valves.
The white marker shows wear.
Rest of the wear is only on the surface.
But the worn edges are not something i would like.
New parts are expensive, ~ 70 EUR / piece.
Good luck and Cheers friends!
Edited by rednikmarto, 17 January 2025 - 02:18 am.
Also tagged with one or more of these keywords: Carbs, 4tx, TDM 850
